Old 09-12-2010, 11:34 PM   #1
GristleBear
GristleBear is on a distinguished road
2002 VUE 3.0L
2003 ION-2 Sedan
Default '02 Vue: PSCM, Tach, Speedo Problems
Hello,
My trusty 02 Vue has me scratching my head. I have been living with an intermittent trio of problems...until recently when they became full-time, that is. At first the PS would sometimes not work when I started the Vue. The Service light would be on and then, when the light went out, the PS would work. Somewhere about the same time the tach and speedo began acting strange. Again, once they started to work they were fine for the rest of the trip. Now, however, the tach and speedo are totally inop. The PS is mostly so... for the trip to church this AM it worked. For the trip home it didn't.
The voltages at the PSCM are a bit high...14.0 VDC. The ground shows no resistance and no voltage drop.
...Oh yes, I should probably also mention that when I put the Vue in drive the high beam indicator, and the headlights, flash about 8 times and then go out. The green headlight dash lamp is always on. Turning on the high beams does not show a high bean indicator on the dash.
I have not metered the BCM yet...I need to get the pinout. However, the nature of these problems makes me suspect that it is going kaput.
This leads me to several questions I'm hoping someone on this forum can help me answer: 1) How critical is the voltage supply TO the PSCM? Is it possible that an over-voltage situation has damaged it? (IE. the regulator in the alternator is malfunctioning and IT TOO needs replacing!) 2) Does the BCM tie into the PSCM in some way? Could a failure of the BCM make the PSCM act strange in turn? And finally, 3) If I replace the BCM myself will the Vue be drivable so that I could get it to the dealer to be programmed?
Hey there Way2Grumpy...got any ideas for me?
Regards,
Andy Cook
Add to GristleBear's Reputation
Rate the quality of this post and help GristleBear reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GristleBear is offline   Reply With Quote
Old 09-13-2010, 05:53 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: '02 Vue: PSCM, Tach, Speedo Problems
Originally Posted by GristleBear View Post
Hello,
Regards,
Andy Cook
Andy ... you may want to check battery voltage with ignition off just to make sure your problems are not power related. I'd say 14 volts alternator output is sign of healthy generator system.
Why don't you disconnect the battery ground cable for about 20 minutes to see if any symptoms change. I've noted a few posts where members bought a bit more time with the old BCM.
Visit post #13 of following thread for 2003 Vue BCM pin-put data and ground points data:
http://saturnfans3.saturnfans.com/~s...d.php?t=155079
All Vue modules are connected in some form of fashion. I've attached two FSM extracts (for 05 Vue - doubt if yours is fundamentally different).
I bet the Vue is interesting to herd with no PS.
All the instrument panel lighting and gauge functions are provided by the BCM so it it ain't happy, ain't no one happy.
I'll zoom in on the single green headlamp light you refer to ... this indicates daytime running lights are active on my 05. Its on when engine running and transmission out of park (with parking brake OFF and auto-headlamps not on).
You can buy used BCM's but I understand dealers have to program them in your Vue. I've heard many dealers will hassle you about inputting old mileage in the new BCM.
You can usually find one or more eBay vendors who'll program mileage if you have the correct legal document and money.
Let me read your list again - sounds tough the first time through.
Lets hope Way2Grumpy is a lot smarter than we are.
reprgram PSCM Rob Leigh Vue Tech 4 02-07-2010 05:12 PM
Speedo/Tach issues Keeter S-Series Tech 1 10-11-2009 05:11 PM
has anyone swapped the speedo with the tach Tom S2 Astra General 8 06-27-2009 09:17 PM
Speedo & Tach "Strange" behaviour? surprisinguy S-Series Tech 0 06-15-2009 10:04 AM
No Tach, speedo or engine temp hammand S-Series Tech 4 09-05-2006 06:37 PM
