Astra General Photos |
· · · 2008 - Media Photos 43 photos 8 comments |
· · · Astra - Member Photos 229 photos 77 comments |
· · · 2008 - Saturn Astra Tuner Concept 3 photos 21 comments | ||||||||
Thread Tools | Display Modes | |||
#1 | ||||
![]() Join Date: Mar 2008
2008 Astra XR
2005 ION-2 Sedan
So yeah, my Astra started to sound like death when the A/C was turned on, but ok with it off.
I just let it be due to a lack of free time at the moment, but my check engine light came on this morning. A quick scan revealed code P0496 - "Evaporative Emission System High Purge Flow" Pretty much some valve is going crazy and the car isn't too happy. Does any one have a diagram of where the evap system components (or better yet, the valve in question) are located under the hood? Thanks. ... My audio system thread, how to replace speakers: http://www.saturnfans.com/forums/showthread.php?t=137456 2008 Astra 3 door XR, 5-speed MT Black Sapphire, custom audio system
#2 | ||||
No diagram, but according to my Haynes:
"On 1.4, 1.6, and 1.8 litre Z18XER (ours) engines, the purge valve is mounted on the inlet manifold (see illustration)." Unfortunately, the illustration has the caption "Typical purge valve location" and I'm nowhere near my car so I can't tell if the pic matches what is under the hood. If I had to guess, it would be near the serpentine belt end. But by definition, the valve is a sort of solenoid, which means it should have an electrical connector as well as two vapour hoses attached to it. That should make it easier to spot. One of those hoses should connect to the charcoal cannister, which is supposedly located behind the R/F wheel fender liner near the bottom door hinge. ... "That's a Hruck Bugbear, manufactured in Eastern Europe in the eighties and imported to the States. People mock it as a poor man's Yugo. I consider it the pinnacle of Cold War Balkan engineering."
#3 | ||||
2008 Astra XR
2005 ION-2 Sedan
Awesome, thank you so much. I'll check it out as soon as I get the chance.
#4 | ||||
2008 Astra XR
2005 ION-2 Sedan
Alright, I jumped under the hood, and I believe that I found the solenoid.
Its on the top of the intake manifold, passenger side like you said. Two hoses (one on each side) and a wire harness on the front of it. I'm just not 100% sure that it is the correct valve (although I am about 99% sure it is). It has a red w/blue stripe and brown w/white stripe wire harness connected to it. I found an ecotec forum that had a member with the same problem, and a guy on that form said that the valve had a red/blue wire going to it. My issue about that is not only was it a cobalt, but it had the 2.2L ecotec. Either way, the P/N for the cobalt's valve is 12597567. I tried to run a search for that number for saturns, and nothing came up for the Astra, just the Aura and Vue. Any ideas on the part number? How fun, my warranty expired TWO MILES after this happened ![]() ... My audio system thread, how to replace speakers: http://www.saturnfans.com/forums/showthread.php?t=137456 2008 Astra 3 door XR, 5-speed MT Black Sapphire, custom audio system
#5 | ||||
![]() Join Date: Sep 2009
2009 Astra XE
It seems a lot of people have the code readers for their cars, but how do you know what the code means once you get it? Is there an online database or a manual or something?
I plan on getting one when my car gets near the end of it's warranty, so forgive me for being a nube. ![]() ... ~~Bryan~~ 2009 Astra XE - manual, wired FM mod 2001 SC2 - manual, sunroof (retired)
#6 | |||||
![]() Join Date: Jan 2010
2008 Astra XR
Reading on the P0496 code, I don't know for certain that the solenoid on the manifold is your problem. On my Impala and other GM vehicles, this code is set when the EVAP canister valve, normally located by the fuel fill neck. Perhaps Astra La Vista can take a look in his Haynes manual to see if the Astra has this valve. ... 2008 Astra XR3 2012 Silverado Crew Cab
#7 | |||||
2008 Astra XR
2005 ION-2 Sedan
As for pictures, here ya go: In the engine and unhooked: ![]() ![]() Images out of the car: ![]() ![]() Numbers on it are: On the face of it (says Bosch, made in Germany): 0 280 142 430 FGP 55 353 802 The side has: >CuFe< >PA66-GF25< I'm leaning toward it being the valve because I believe it leaks. I unhooked the 2-wire connector and the left side (connected to the evap. canister) pipe. When I started the car, the valve was still creating a vacuum, which points toward it being the valve. It shouldn't create a vacuum at all. I know the Astra had an issue with the gas tank filler neck that would throw a code, but I couldn't dig up what code that would set. ... My audio system thread, how to replace speakers: http://www.saturnfans.com/forums/showthread.php?t=137456 2008 Astra 3 door XR, 5-speed MT Black Sapphire, custom audio system
#8 | |||||
![]() ... "That's a Hruck Bugbear, manufactured in Eastern Europe in the eighties and imported to the States. People mock it as a poor man's Yugo. I consider it the pinnacle of Cold War Balkan engineering."
#9 | |||||
2008 Astra XR
#10 | ||||
2008 Astra XR
2005 ION-2 Sedan
I didn't exactly come up with that test on my own, the process is in an FSM for another GM vehicle, and the system works the same.
I also checked if the valve could hold a vacuum, which it can't, so it does in fact leak, pointing me toward it being truly defective. Now, if the valve alone is the only problem or if there is something else busted too, I have no idea. I'm going to just get a new valve, and go from there. I believe its no more than $40, and thats the dealership price! ... My audio system thread, how to replace speakers: http://www.saturnfans.com/forums/showthread.php?t=137456 2008 Astra 3 door XR, 5-speed MT Black Sapphire, custom audio system
#11 | ||||
2008 Astra XR
2005 ION-2 Sedan
I ran by the dealership today. As expected, it wasn't in stock.
Good thing, because they wanted nearly $110 for the damned thing! Talk about price gouging. I did get the P/N, its 55562350 if anyone cares. I found it for about $55 from a website on the net, so I think they'll get my business. ... My audio system thread, how to replace speakers: http://www.saturnfans.com/forums/showthread.php?t=137456 2008 Astra 3 door XR, 5-speed MT Black Sapphire, custom audio system
#12 | ||||
![]() Join Date: Jul 2009
You said your warranty was expired, but know that emissions systems components are warranted longer than the 3yr/36,000 standard warranty. Not sure how long but it is significantly longer. You will probably have to argue with the dealer, but they should fix it.
#13 | ||||
2008 Astra XR
2005 ION-2 Sedan
Yes, some parts are, but not the valve in question. The Astra's owner manual has a list of things covered by different warranties, and the valve isn't listed under the emission section.
If this doesn't fix the problem, I will take it to the dealership.
#14 | ||||
2008 Astra XR
2005 ION-2 Sedan
Just to update you all, I got the valve in, swapped it out and put about 100 miles on the car. The code cleared itself and hasn't come on since. So I'm pretty sure that was the issue.
#15 | ||||
![]() Join Date: Oct 2010
What website are you finding these parts on? I'm having a hard time finding them.
#16 | ||||
Nightwalker, you said your car sounded 'like death' with the a/c on. What kind of noise, exactly? If it is a screeeching or squealing noise, have you had the revised generator pulley installed?
#17 | ||||||
2008 Astra XR
2005 ION-2 Sedan
I didn't browse for the part, I just put in the part number and hit search. Quote:
I've apparently needed one for quite a while, I just figured the horrid noise it made was normal (as considering it's been there a while) and it had no effect on performance. With the valve going bad, the car would idle rough, and combined with the faulty pulley, it was just amplified. ... My audio system thread, how to replace speakers: http://www.saturnfans.com/forums/showthread.php?t=137456 2008 Astra 3 door XR, 5-speed MT Black Sapphire, custom audio system
#18 | ||||
Thank you very much!
#19 | ||||
![]() Join Date: Oct 2009
2008 Astra XR
2002 L-Series 2.2L Sedan
I just received this exact code today, but my engine will actually shut off while idling at a full stop. If i put the Astra back into park and crank it again then it'll start right back up. Any ideas?
| Thread Tools | |
| Display Modes | |
| Idle Misfire and Evap system failure | Avitar408 | S-Series Tech | 32 | 06-22-2010 11:11 AM |
| 2003 Vue EVAP error | Droth | Vue General | 2 | 03-02-2010 07:23 PM |
| EVAP System, P0442 revisited | KingRex | S-Series Tech | 2 | 02-23-2010 06:01 PM |
| Error Code 32: EGR System Fault | preythesun | S-Series Tech | 2 | 12-07-2009 01:03 PM |
| EVAP System Small Leak | ddsmithjr | S-Series Tech | 8 | 01-16-2006 09:54 AM |
