Old 09-06-2010, 08:52 PM   #1
jim_tim
jim_tim is on a distinguished road
2002 SL
Default saturn sl fog lamp install
i bought a 2002 saturn sl and want to put fog lamps in it from an sl2. has anyone done this and what are some tips and how hard is it?
Add to jim_tim's Reputation
Rate the quality of this post and help jim_tim reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jim_tim is offline   Reply With Quote
Old 09-07-2010, 01:17 AM   #2
PlasticCarsRock
PlasticCarsRock's Avatar
Default Re: saturn sl fog lamp install
It's not bad if you have a few hours and some basic electrical skills. http://saturnwiki.net/index.php/Seco...rcuit_retrofit. Your car should already have wiring from the switch location to the fusebox. You just need to install the switch, the necessary jumpers in the fusebox to plug in the fuse and relay, and add the single (+) wire to power them (make sure it's appropriately sized--16 should be the smallest gauge, I'd recommend 14 to be safe if you're using 50 watt bulbs (the larger the wire, the brighter the lights will be because there is less of a voltage drop due to resistance). I used 12 gauge, but I wanted the option of adding a second pair of lights on the same circuit if I ever wanted to.
As for the lights themselves, I recommend OE lights from a junkyard car. Many people will recommend aftermarket, but they're typically not legal ("for off road use only"), and the beam pattern is rarely as good as OE; if you can find good aftermarket ones, the beam pattern should be much better, but the factory one is acceptable, and much better than any of the cheap aftermarket ones I've seen.
If you go the JY route, make sure you grab the plugs from the end of the wiring harness (you could actually take the entire harness, but it's probably easier/faster to make your own (just need to add one wire to the existing one)). You can ground to anywhere on the chassis. I put mine right on the battery to chassis ground bolt from the factory (under the intake; be sure to remove any corrosion to get a good connection).
If you want them to be reliable, be sure to make proper wire connections (solder and shirnkwrap). Do not rely on splice or crimp connections, or just twist the wires together (as in the tutorial); they will work fine for a bit, but eventually, they'll stop working (go out completely, or start blinking over bumps), and finding out why is a pain.
Old 10-04-2013, 09:42 AM   #3
SL19302
SL19302's Avatar
2002 SL1
Its actually simple, obtain the fog lamps w/ brackets remove the covers on the lower part of the bumper, I didnt remove my bumpers I put the cars on ramps to mount them, They mount to the two end 13mm bolts on the support, Go to your local salvage yard and remove the entire front harness from a fog lamp equipped car, fog lamp relay, fuse, along with the switch on the dash to operate them, Also you will need to remove the 6 electrical pins in the fuse box (2) for the 10 amp fuse and (4) for the Relay and transplant them into your fuse box, everything is all plug and play, I installed fog lamps on both my S-Series Saturns, I did one of them one afternoon and the other the next afternoon, both weren't equipped with them from the factory.
Add to SL19302's Reputation
Old 05-15-2016, 03:33 PM   #4
hudypete1
hudypete1 is a jewel in the roughhudypete1 is a jewel in the roughhudypete1 is a jewel in the rough
2007 ION-3 Sedan
Lots of fog lights available if you troll the junkyards.
Add to hudypete1's Reputation
Rate the quality of this post and help hudypete1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hudypete1 is offline   Reply With Quote
Old 10-12-2016, 12:12 PM   #5
Finkle
Finkle is on a distinguished road
This is an old thread, but I wanted to post up my favorite fog lights to retro on.
I use 2000+ celica fog lights. They are projectors that take H3 bulbs, I think they have very good output, are smaller, and have an easy bracket to mount to other cars. Plus the bracket has a vertical adjustment screw built in. I have them on my 02sl, and three or four other cars in the past. Whenever I see a pair in the junkyard, I grab them for future use.
Add to Finkle's Reputation
Rate the quality of this post and help Finkle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Finkle is offline   Reply With Quote
Saturn SC 1997 fog lamp konissan S-Series Tech 0 04-02-2008 02:23 AM
Fog Lamp install for 4cyl auto mellissam Vue Mods 5 07-15-2006 03:51 AM
2002 Saturn SL-2 Oil Sensor Lamp doublea S-Series Tech 9 04-26-2006 03:13 PM
Saturn Fog lamp wiring - aftermarket? Rozzwell S-Series General 1 01-31-2005 11:22 AM
Help - Malfunction Indicator Lamp on. '04 Saturn Vue badkitty3804 Vue Tech 9 01-21-2005 08:32 PM
