Old 09-11-2010, 07:39 PM   #41
Default Re: Beautiful little car...but...
Originally Posted by Silver Gray View Post
I feel like I came back home after a week out of town and a whole new family's moved into my house. And my car's gone, too.
[voice="Majel Barrett"]Warning: your thread has been hijacked.[/voice]
BTW, those are aluminum alloy wheels.
If your top engine mount is aftermarket, and is of the "frowny" design (search here for "frowny mount" for more info; no kidding), it's probably the major cause of your vibration. Try to get an OEM mount, or if you go aftermarket, look inside the box and make sure it's the "solid" design.
Add to madpogue's Reputation
Old 09-11-2010, 07:44 PM   #42
off-track
off-track's Avatar
Originally Posted by alordofchaos View Post
...and Kitt was the Mustang in a bad one-season show
I sure HOPE you meant to format that comment in green?
Silver Gray.. look'n good. Those wheels really set it off! Change your TAM.
edit:.. ha Mad, we crossed yet again!
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 09-11-2010, 07:48 PM   #43
'Sokay; you were busy training for tomorrow's Ironman, right?
Old 09-11-2010, 08:12 PM   #44
off-track
off-track's Avatar
LOL! Well, that isn't happening for sure!
Added OEM CC
Old 09-11-2010, 09:59 PM   #45
Silver Gray
Silver Gray is on a distinguished road
Silver Gray's Avatar
2001 SL2
[voice="Majel Barrett"]Warning: your thread has been hijacked.[/voice]BTW, those are aluminum alloy wheels.
[voice="Majel Barrett"]Affirmative. Irrelevant information has been of interest nonetheless. Existing data bank did not contain specific information regarding specific material of wheels—new data from madpogue has been recorded and duly annotated as much appreciated. Assumption had been made that regardless of elements involved, the surface of aesthetically appealing wheels did and would not readily stain or oxidize.[/voice]
Still a complex problem (as is my whole life). The new top engine mount IS aftermarket, but it is ALSO a SOLID style mount.
So now, I have two issues to decide:
1. Go back to Chevy dealer (the only supplier in my region of Saturn OEM mounts) and have the new aftermarket top mount replaced with a new OEM (with no guarantee of vibration improvement).
2. Go back to Chevy or local (long-term reliable) mechanic in order to check transaxle bracket adjustment as per madpogue's first recommendation.
Just look at this beautiful car! (See my previous post.) I know y'all have got to understand why I (though of limited technological know-how) want to get this fixed! Many thanks for your advice!
SG
Add to Silver Gray's Reputation
Rate the quality of this post and help Silver Gray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Silver Gray is offline   Reply With Quote
Old 09-12-2010, 12:21 PM   #46
Start with #2 (the bracket loosen/tighten), as you should do this after any mount work. This is something you can do in the driveway, if you have ramps. You might even be able to reach under there with the car on the ground. If the vibration persists, _then_ look into an OEM or OEM-style top mount. This is also something you can do in the driveway; you can support the engine with the emergency jack in the trunk, if you can't get your mitts on a floor jack.
Yeah, beautiful car in a beautiful setting. Def. worth solving the vibration issue, esp. when the alternative is a crippling car payment every month.
Old 09-12-2010, 06:11 PM   #47
Silver Gray
2001 SL2
Many thanks, madpogue! You have given me a prioritized plan that relieves my real stress of "what next?". Bracket, then if no help, OEM top mount. Got it.
Got that right! No payments but insurance on this one.
Thanks again,
SG
Old 10-03-2010, 06:18 PM   #48
Silver Gray
2001 SL2
I've completely loosened and retorqued the bracket three times now (right to 37), with the car at different angles. And each time, the vibration when stopped in drive is unimproved.
I know the engineering is supposed to be the same, but there's got to be something very different between my 1995 and my 2001. My '95 was always smooth and silent at a stop light, but this '01 vibrates like a 110V massage chair on 220, no matter what I do. The engine checks out in great shape - all new wiring, plugs, good compression test, new serpentine belt, the works. I even lowered the transmission fluid level as was suggested.
And now I find to my surprise that when the Chevy dealer replaced my transmission mount, they also installed a new "frowny" mount on top, replacing my new solid aftermarket mount (which was really stiff), without even telling me or charging me for it. It doesn't make any difference in the vibration, so what the hey.
Sincere thanks to everyone for your clear and appreciated suggestions, especially to Madpogue.
But I'm giving up. Too much work and money for no change whatsoever. I'll just keep on slipping it into N at stop lights until I can afford an electric car.
SG
Video: GM "Beautiful Blue" Olympic Television Ad Features Saturn Sky, Flextreme Charlie General Saturn Discussion 4 08-11-2008 08:21 AM
It's a beautiful world at the Honda forums... BobbyP Vue General 30 03-20-2007 08:54 PM
[Pic] Ain't this just beautiful TIMSPEED S-Series General 3 10-05-2004 09:09 PM
A Beautiful Thing AZguy General Saturn Discussion 12 10-11-2003 11:41 PM
Beautiful 1997 Pontiac Trans Am for sale crawfordna Classifieds 2 05-30-2002 09:15 AM
