Old 09-02-2010, 11:11 PM   #1
polycar
polycar is on a distinguished road
Default 2005 Vue Clutch Reservoir Dry = No Clutch. Slave issue???
Looking for opinions - here's the history:
No previous problems with slippage.
Pulling into a parking lot this evening, it was difficult to get the car back into gear, but it went and we parked, went inside, came back to go home.
Car starts fine. There was a little pressure on the clutch but not enough to shift into any gear from neutral. Opened the reservoir to check the fluid level and it was completely empty, and after that there was absolutely no pressure left in the clutch pedal.
Added Dot3 fluid, still no pressure.
Could this fix be as simple as bleeding the line or are we likely looking at a complete hydraulic replacement? Is there a really reliable way to determine if the master and/or slave cylinders need to be replaced?
Add to polycar's Reputation
Rate the quality of this post and help polycar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
polycar is offline   Reply With Quote
Old 09-03-2010, 12:11 AM   #2
emsvitil
emsvitil has a spectacular aura aboutemsvitil has a spectacular aura about
emsvitil's Avatar
Default Re: 2005 Vue Clutch Reservoir Dry = No Clutch. Slave issue???
Your master or slave just died.
Most likely the slave.
You'll have a soaked carpet if it's the master, and brake fluid will be dripping from the engine/tranny if it's the slave.
If it's the slave, replace the clutch (plate & disc) while you're at it.
Ed
Add to emsvitil's Reputation
Rate the quality of this post and help emsvitil reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emsvitil is offline   Reply With Quote
clutch slave issue tombruce S-Series Tech 10 04-21-2010 09:51 AM
Clutch Slave Issue... gs69350 S-Series Tech 13 07-12-2007 12:32 AM
brake and clutch... same fluid reservoir? vue0404 Vue General 4 05-23-2004 11:45 PM
Clutch Fluid Reservoir Psoryan S-Series General 2 05-09-2004 09:38 PM
difference between clutch actuator and clutch master/slave cylinder geartooth94 S-Series Tech 3 06-10-2003 11:36 AM
