Old 09-01-2010, 08:49 PM   #1
saturnrings
saturnrings is on a distinguished road
Default Weird Noise
Recently, my car has been occasionally making a weird grinding noise. It's not the same squealing noise that one hears when brakes are bad, but it's a "grrr" sound. And admittedly, it's rather random. I don't hear it when I'm braking on the highway, but I've only heard it when applying the brake to slow down on local streets.
Does anybody have an idea of what could be causing the noise?
Add to saturnrings's Reputation
Rate the quality of this post and help saturnrings reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnrings is offline   Reply With Quote
Old 09-01-2010, 09:04 PM   #2
off-track
off-track's Avatar
Default Re: Weird Noise
Not enough information..
Only when braking? Can you localize it (front/rear/left/right)? Try to find a situation where you can repeatedly duplicate the problem.
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 09-01-2010, 09:59 PM   #3
saturnrings
It's nearly impossible to replicate it. I tried doing so on the way home from a friend's house after I heard the noise and nothing.
BTW, the noise is coming from the front passenger tire. And it only happens when I brake. When I release the accelerator and "coast", it doesn't make the noise, nor does it make a noise when I accelerate. It basically only happens when braking normally at low speeds, around 15 to 25 mph.
Old 09-04-2010, 06:21 AM   #4
saturnrings
After driving the car yesterday, I can basically narrow down the noise issue to the front right wheel, with the noise occurring within the first two or three times that I apply the brake under 25 mph after starting the car. Otherwise, it's noise free when I brake whether on the highway or on local roads.
Old 09-04-2010, 12:02 PM   #5
Ruger141
Ruger141 is on a distinguished road
2007 ION-2 Sedan
Wow, I am having this exact same issue. When I get in the car for lunch at work after it sitting for 4 hours and hit the brakes for the first time they sound like they are metal on metal. But it only does this the first two or so times and then is quiet afterwards. What kind of pads do you have, I put the ceramic Raybestos on mine?
Add to Ruger141's Reputation
Rate the quality of this post and help Ruger141 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ruger141 is offline   Reply With Quote
Old 09-04-2010, 01:21 PM   #6
I believe you're both suffering from overnight surface rust on the rotors that are wiped away upon application of firm braking. When this noise disappears for the remainder of the day and reappears the next day on the first drive, its related to overnight rusting on bare metal. I often don't use my car for two days and the first brake application out of the driveway results in the same noise and disappears in one or two more brake applications before I head out on the highway.
Look through the wheels for the rotors before starting up in the morning and you may see surface rust on the rotors. Since you cannot see the inside rotor surface you're missing half the visual inspection. This is common and nothing to worry about. It should be the same for both rotors so if its only one side of the car there may be cause for concern.
Old 09-04-2010, 09:21 PM   #7
saturnrings
Usually, the noise happens with the first two or three times that I brake hard with my car, but it made the same noise after driving for nearly 20 minutes on the highway, and when I released the brake, the noise continued for a minute or two. So, I think it's safe to say that there's a problem...
Old 09-04-2010, 10:31 PM   #8
Well, if this is ocurring at any random braking event then its time to look at them either by you or by your local repair shop. No sense in wondering about it when something's not right.
I usually rotate my wheels and inspect the brakes (all wheel discs) but was caught off guard this past spring when state inspection came around; my front pads were down to nothing and wouldn't pass. Replaced rotors and pads and passed inspection.
Weird noise beensmoked L-Series Tech 1 11-16-2009 07:35 AM
weird noise freedomflame200 S-Series Tech 2 03-03-2006 08:35 AM
weird noise Azn_IoN Ion General 4 07-17-2005 05:37 PM
Weird noise on 95 SC2 sc2095 S-Series Tech 20 02-08-2005 12:14 PM
Weird Noise Kuiawa3 Ion General 9 03-23-2003 08:28 PM
