Old 01-28-2003, 11:39 PM   #1
cmswq3
cmswq3 is on a distinguished road
cmswq3's Avatar
Default Changing / Replacing Serpentine Belt
Well it appears that when you have one problem, a million more come in behind it. So now today my belt starts screeching at me until it warms up. So I have changed millions of belts but never on a saturn. I hear its easy though, also the tensioner was replaced 2 years ago do I need to replace this again?
So just some simple instructions to give me an idea how my weekend will go.
cmswq3 is offline
Old 01-29-2003, 12:55 AM   #2
wolfman
wolfman's Avatar
Default
Tensioner is probably fine. To replace the belt...the "easiest" way. Jack up the car and remove the passenger side wheel and inner splash shield. You will now be able to see the bolt that runs through the tensioner's pulley. Place a box end wrench (15mm or 9/16 will do) and turn the bolt as if you were trying to TIGHTEN it. The tensioner arm will move and release pressure on the belt, with the tension released (wrench held in place) slip the belt off just ONE pulley, you can now release the wrench and remove the belt. Route the new belt in place according to the diagram on the radiator support under the hood saving the CRANKSHAFT pulley for last. Release the tensioner pressure as you did before as FAR AS POSSIBLE, then slide the belt over the crankshaft pulley and slowly release the tensioner. Check to make sure it has not slipped off...it should be fitting tightly if as is well. Start car to confirm proper function. Reinstall splash shield and tire/wheel..you're done. Expect about a 30 minute job for a first timer, ten minutes tops for old hands. Hardest part is keeping the new belt in place while trying to get it over the last pulley and release the tension. There is a way to "cheat" if you have a "double box end wrench". Run a length of rope through the end you won't be using on the bolt. Turn the other end on the tensioner bolt as described FROM ABOVE to release the tension, and then tie the rope to the hood bumper or radiator support to hold the wrench/ tensioner in the released position while you remove/install the bolt. Then untie the rope and release the tensioner one the new belt's in place.
wolfman is offline
Old 01-29-2003, 09:16 AM   #3
BlackBirdRacing
BlackBirdRacing is on a distinguished road
BlackBirdRacing's Avatar
Default
I just get at it from the top.
It's harder to do that way but I'm used to it.
BlackBirdRacing is offline
Old 01-29-2003, 09:55 AM   #4
Mark G
Mark G is on a distinguished road
Default
I have replaced it from the top and from the wheel well, and the wheel well is much easier.
Mark G is offline
Old 01-29-2003, 10:41 AM   #5
Luke
Luke's Avatar
Default
Wolf's Comment:
And one hour for Luke..LOL
Luke is offline
Old 01-29-2003, 10:59 AM   #6
eRic 02sc2
eRic 02sc2's Avatar
Default
changing the serpentine belt on the s-series is easy. wait til the engine is cold and reach in an use a 14(?)mm wrench on the tensioner to create some slack then slide off the old belt and install the new belt. one i did this at the drag strip when i swapped the regular belt for the short belt than bypasses the a/c. btw no, it wasn't worth it. saturns a/c pulley spins free enough when it's off to not make a huge diff.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 01-30-2003, 12:29 PM   #7
irish56
irish56 is just really niceirish56 is just really niceirish56 is just really niceirish56 is just really niceirish56 is just really nice
irish56's Avatar
1999 SC1
Default Get a buddy to help!
Wolfman said a mouthful:
"Hardest part is keeping the new belt in place while trying to get it over the last pulley and release the tension."
You can do this job by yourself, but it will go much faster and you'll swear a lot less if you have a buddy to stand by the car and make sure the belt stays wrapped around the upper pulleys while you route it around the lower pulleys from the wheel well, then release the tension. I've done this job both ways (on the 95 SL1 and the 98 SL2) and it went MUCH faster with a helper.
Incidentally, this should be a one-beer or one-Whopper job for the helper -- he doesn't even have to get his hands dirty.
(back to lurk mode)
irish56 is offline
Replacing serpentine belt on 2003 V6 mr weather Vue Tech 7 10-03-2019 08:07 AM
Changing the serpentine belt on the Ecotec David 93 SL2m How-To Library 19 07-05-2019 07:04 AM
Changing the v6 serpentine belt binkers L-Series Tech 17 12-05-2009 08:48 AM
Changing Serpentine Belt Laga Ion Tech 6 01-11-2007 02:54 PM
Replacing serpentine belt pulleys... jzack S-Series Tech 10 07-31-2006 03:31 PM
