Old 08-31-2010, 02:17 PM   #1
bigalpha
bigalpha will become famous soon enough
1997 SL1
Default Random No-Start
Looks like I have a good chance at getting that SL-1 I talked about randomly in a previous thread.
My buddy says it's not starting, and that it's been happening for a while, seemingly randomly.
Other than the usual problems (bad battery, loose belts, bad alternator) are there any other common issues that cause a no start? (On Jeeps, it's the CPS).
I plan on hitting the battery with a DMM before and during cranking. If it doesn't start - then jumping it and hitting it with a DMM again to test the alternator.
Add to bigalpha's Reputation
Rate the quality of this post and help bigalpha reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigalpha is offline   Reply With Quote
Old 08-31-2010, 06:04 PM   #2
Default Re: Random No-Start
Usually, if the battery can turn over the engine but the engine randomly won't fire up, its not a battery issue and a boost from another battery won't help. A starter draws the most current from a battery so if it can turn over, something else is wrong that can be either a fuel or ignition issue.
Search for the two procedures to test each one. Its a good troubleshooting method.
Old 08-31-2010, 06:19 PM   #3
bigalpha
1997 SL1
Thanks fdryer.
I know the basics of testing the fuel and fire systems for an engine, thanks to my Jeeps.
Are there any common sensor/wire/harness failures to keep an eye out for?
Old 08-31-2010, 09:19 PM   #4
That may depend on model year and most likely covered throughout these threads.
Old 09-01-2010, 11:23 PM   #5
bigalpha
1997 SL1
Turns out that the battery is just old and crappy. I'm gonna get a new battery for it soon and get the massive exhaust leak fixed.
Help with `92 SC2 - Random Stalls, No Hot Starts, High RPMs on Start WesAlvaro S-Series Tech 30 07-05-2010 01:23 PM
Random no start fixed! Darren1970 L-Series Tech 3 08-25-2009 08:45 AM
Random so start! Darren1970 L-Series Tech 3 08-19-2009 10:46 AM
Saturn SL-1 random failure to start whooki S-Series Tech 6 04-08-2009 04:24 PM
Random no start issue ob1 S-Series General 19 02-12-2009 11:03 AM
