Old 08-25-2010, 11:23 AM   #1
djcro
djcro is on a distinguished road
djcro's Avatar
Default Emis fuse blowing
Hello,
I'm new to this forum and hoping someone might have a suggestion as to why my Emis (I assume Emissions) fuse keeps blowing after I turn on the car and let it idle for about a minute.
I have a 2000 Saturn SW-2 DOHC wagon (original owner).
I have the following error codes that keep showing up:
P0037 HO2S heater control circuit low bank 1 sensor 2
P0138 O2 circuit high voltage bank 1 sensor 2
P0410 secondary air injection system
Then it starts repeating - P0037 x2, P0138 x2
O2 sensors (up and downstream) and 2ndary air intake check valve replaced so far, but it sure looks like an electrical issue somewhere in the Emissions circuit. I purchased a Haynes and Chilton Saturn manual and neither have a wiring diagram for the Emissions circuit.
With secondary pump unplugged I only get a P0037 error.
I'm hoping someone here can point me in the right direction.
Any assistance is GREATLY appreciated!!!!!
Many Thanks,
-djcro
Add to djcro's Reputation
Rate the quality of this post and help djcro reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
djcro is offline   Reply With Quote
Old 08-25-2010, 12:00 PM   #2
Default Re: Emis fuse blowing
On the rear O2 sensor. Unplug it and place a plastic bag over both the sensor cable plug and the connector on the cradle rail to keep them clean. Reset your codes and see what happens. If the p0037 and the p0138 come back then the +12v heater is shorted to the O2 sensor sensing element wire in the harness between the plug on the cradle and the PCM. I suspect something or someone has crushed the wiring harness. You have one branch that goes down to the Rear O2 sensor plug and another branch that goes to the air injection solenoid. Follow both out till they come into a common harness and start from there. Look first as usually crushed is obvious. Schematic will not do a lot of good with this.
With the fuse blowing you definitely have a hard short to ground.
Old 08-25-2010, 02:14 PM   #3
djcro
djcro's Avatar
Old Nuc, thanks for the quick reply! I am very glad I joined this forum. I will definitely try what you suggested and appreciate the time and effort you took in helping me...an average dude with a Saturn... Thanks again!
Old 08-25-2010, 02:55 PM   #4
djcro
djcro's Avatar
I just told my mechanic friend about what you suggested. He asked for an ECU pin out...can anyone help with that please?
Any assistance is greatly appreciated!
Old 08-25-2010, 06:35 PM   #5
You have PM...
Old 08-26-2010, 01:25 PM   #6
djcro
djcro's Avatar
No more error codes!
So we took out the harness...traced the wires, ohmed them out...all looked good. We then dejectedly put the harness back in and started the car back up. Lo and behold, there were no more error codes; no more check engine lights.
I'm a happy person, but perplexed nevertheless.
OldNuc, thanks again for all of your help and support!
Ign 3 Fuse keeps blowing...Help! 04 ION QC2 S-Series Tech 19 05-12-2015 01:40 PM
hi and need help. blowing fuse allen57 S-Series Tech 1 04-15-2007 09:42 PM
Fuse keeps blowing...WTF Wifey's Ride S-Series Mods 9 04-20-2006 08:22 PM
Keep blowing fuse devolic S-Series General 3 08-06-2005 11:58 PM
fuse blowing` garyh_rosies S-Series Tech 3 12-24-2003 05:36 PM
