Old 08-14-2010, 11:18 PM   #1
Summiteer
Summiteer is on a distinguished road
Default Trouble diagnosing an SL1 start problem
After changing the oil in my '98 SL1 the other night, it will no longer start. Turning the key past the accessories position didn't seem to do anything. The power windows and a/c don't work (but the "accessories" like the radio still did). Because the ignition has acted funny for months (dinging that the keys were left in even when they weren't) I figured the ignition switch had gone out and replaced it.
After replacing the switch, however, the problem is similar, but slightly different. The accessories still work, and when I try starting the car the accessories (radio, wipers, etc) turn off as expected. However, it doesn't even try to turn the engine over, and the power windows and a/c still don't work.
Any ideas about what might be going on?
Thanks in advance!
Curtis
Add to Summiteer's Reputation
Rate the quality of this post and help Summiteer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Summiteer is offline   Reply With Quote
Old 08-15-2010, 12:06 AM   #2
Default Re: Trouble diagnosing an SL1 start problem
Before spending money and time, and committing to two keys, on the ignition switch, did you TEST (not just visually check, but TEST with an ohmmeter / continuity tester) EVERY fuse in BOTH fuse boxes? This sounds like a blown IGN 3 fuse.
Add to madpogue's Reputation
Old 08-19-2010, 12:53 PM   #3
Summiteer
That was exactly the problem. I guess it pays to start with the simple things first. Anyway, thank you so much for your help!
Need help diagnosing a Problem AllenA S-Series Tech 1 05-30-2010 12:23 AM
Diagnosing no start 99 sc2 zenmodo S-Series Tech 4 12-06-2008 05:41 AM
Need Help on diagnosing problem caterpillar S-Series Tech 9 12-24-2007 10:54 AM
Need Help Diagnosing a '95 SL2 Clutch Problem Bob K S-Series General 19 11-24-2007 10:54 AM
96 SC2 Need Help Diagnosing Problem Matt_Fontenot S-Series Tech 4 03-16-2007 08:53 PM
