Old 07-28-2010, 06:41 PM   #1
pala22
pala22 is on a distinguished road
2004 VUE 3.5L
2004 SL1
Default 04 saturn vue liftgate won't open
Can anyone offer info. on how I can open the liftgate of my 04 saturn vue? It does not have a manual insert key, have wireless key remote which successfully opens/locks all doors, except the rear tailgate. Also, is there a fuse that can be replaced? I noticed an electrical diagram that shows the link to the liftgate but if there is a fuse, I cannot locate it. Please help!
Add to pala22's Reputation
Rate the quality of this post and help pala22 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pala22 is offline   Reply With Quote
Old 07-28-2010, 08:22 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 04 saturn vue liftgate won't open
This has happened to others - there's no separate fuse - I recall one member cutting a hole in cover near the lock to release the latch.
Visit the follow thread for more information:
http://saturnfans3.saturnfans.com/~s...h+won%27t+open
Old 07-29-2010, 06:09 PM   #3
termite
termite is a jewel in the roughtermite is a jewel in the roughtermite is a jewel in the rough
termite's Avatar
I recently enlarged the hole and used one of those round metal plugs to fill it. It makes it easier to use and to make the hole match whats behind it. I would get the plug first and be careful not to make the hole too big! I painted the mechanism inside to see it better. Just put a screwdriver in the hole and move it (can't remember which way) but it unlocks it! I took these pictures from inside to give a better idea how it works and if you can't open the rear hatch now, this is how it would look to you while working on it.
It's GOOD to have a spare!
Add to termite's Reputation
Rate the quality of this post and help termite reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
termite is offline   Reply With Quote
Old 07-29-2010, 06:19 PM   #4
termite
termite's Avatar
I should add I did not have a problem with my rear hatch when I added this hole, but I figured this would be good insurance in case I did have a problem in the future. Its not a bad idea for anyone with this same rear hatch to do this.
Old 07-29-2010, 09:35 PM   #5
far2grumpy
far2grumpy's Avatar
Termite ... you are one clever fellow.
Your superior planning makes the rest of us look bad.
I'll be cutting the hole in my hatch ASAP.
Probably much larger than you suggest because I have a new roll of duct tape.
Old 09-01-2010, 10:05 AM   #6
POORBOYZ
POORBOYZ is on a distinguished road
I'm having the same problem in my 06 Vue but I lucked out and it stopped working in the unlocked position. This is a great fix but it seems we still have not figured out what the problem. Is it the wiring, lock mechanism? This is more or less a band-aid fix and I would like to know if anyone has figured out what the actual problem is so we can all go back to locking and unlocking the tail gate with our key pads.
2006 VUE FWD V6
2001 BMW 330Ci
1996 FORD FUll SIZE Bronco 550WHP
1991 BMW 325i
Add to POORBOYZ's Reputation
Rate the quality of this post and help POORBOYZ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
POORBOYZ is offline   Reply With Quote
Old 09-01-2010, 10:48 AM   #7
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
One of the SUV's I rented earlier this year already had an access plug. I believe it was the Dodge Journey. I popped the plug and saw the slot to operate the lock mechanism.
poorboyz do you hear the solenoid inside the liftgate operate when you use the key fob?
Add to BobbyP's Reputation
Old 09-05-2010, 07:49 AM   #8
POORBOYZ
I don't hear anything...it's completely dead. I'll probably go buy a new mechanism. I also have to fix the strut mounts (for the 2nd time) and I just finished redoing the AC system (changed compressor) on a 58k mile car.
2006 VUE FWD V6
2001 BMW 330Ci
1991 BMW 325i
Old 09-05-2010, 06:24 PM   #9
termite
termite's Avatar
Did you use a DVM to check for voltage when you press the key fob button?
Old 06-26-2011, 05:11 PM   #10
DCSipp
DCSipp is on a distinguished road
My Thanks also. This allowed me to get the hatch open. I believe my mechanism is bad. Looking for P\N and a place to buy a replacement.
Regards,
DSipp
Add to DCSipp's Reputation
Rate the quality of this post and help DCSipp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DCSipp is offline   Reply With Quote
GM apointed Saturn dealer to stay open! cam General Saturn Discussion 6 12-17-2009 07:54 PM
GMSC Bash, now open to all Saturn Compacts! schill32 Events 0 04-20-2005 02:32 PM
Class in now open for Saturn owners Garciavision L-Series General 4 02-04-2005 08:51 PM
Open Letter to Saturn About Ion Red Line cris_thomas Ion Red Line 9 02-19-2004 11:01 PM
