Old 07-26-2010, 06:49 PM   #1
Dawggy
Dawggy is on a distinguished road
Default 1996 sl2 wont start or crank...
went to the store in ol trusty rusty 1996 sl2 DOHC 1.9 liter everything working fine... came out loaded with groceries and turn the key and nothing... it does not even attempt to crank... battery is fully charged....tried different battery....tried putting it in neutral...starter is only 2 yrs old.. any ideas? theres so many things it could be but I am disabled and cannot go hunting what it could be so hoping somebody has an idea.... any help is appreciated, thanks.
Add to Dawggy's Reputation
Rate the quality of this post and help Dawggy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dawggy is offline   Reply With Quote
Old 07-26-2010, 08:57 PM   #2
PlasticCarsRock
PlasticCarsRock's Avatar
Default Re: 1996 sl2 wont start or crank...
You're right--could be a lot of things. Check all of the power and ground connections that feed the starter (the connections on the battery and the ones on the chassis, engine, starter, etc.
When you turn the key, do other accessories (radio, blower motor, etc) work, or is everything dead? If there's a loose connection on the battery, everything else will probably work until you try to start the car, and then everything will go dead.
Old 07-26-2010, 11:22 PM   #3
adventureoflink
adventureoflink's Avatar
Just to be sure, did you check your oil and coolant?
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 07-26-2010, 11:34 PM   #4
Dawggy
Everything else works fine....lights radio ac etc etc... full of oil and coolant to answer the other post gonna have er towed home tomorrow sounds to Me like a wire broke or came loose on the starter.. in past cars when starter or celenoid went bad I would always get atleast a click or a whining noise but its like the starter isnt connected at all.
Old 07-27-2010, 08:41 AM   #5
Grab the positive cable from the battery and try to flex it a bit. If it feels "crunchy" you have severe corrosion and it needs to be replaced. I don't think that is your problem, but this is a free, two second test
You might have a problem at the contacts in the ignition key cylinder, too
Old 07-27-2010, 10:03 AM   #6
Do the SES and "Wrench" lights come on when you turn the key to RUN?
Try holding the key in the START position, and (here's the tricky part) moving the shifter from Neutral toward Reverse and toward Drive. If that gets the starter to catch, then the Neutral Safety Switch (actually, it's the whole Trans Selector switch) needs to be adjusted or replaced.
Add to madpogue's Reputation
Old 07-27-2010, 02:49 PM   #7
bitterlemons
bitterlemons is on a distinguished road
2006 VUE 2.2L
My 2000 SW2 seems to be having the same problem. Left my wife stranded. I'm about to take a bus across town to see if I can get it going again. Hopefully one of these tips will get me back on the road.
Add to bitterlemons's Reputation
Rate the quality of this post and help bitterlemons reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bitterlemons is offline   Reply With Quote
Old 07-27-2010, 10:58 PM   #8
Dawggy
So...... had the car towed home on a flatbed today... and when the driver left... just for grins I tried to start it and it started right up.... so I have to have some sort of a short somewhere in ol trusty rusty
Old 07-27-2010, 11:11 PM   #9
Mgg4591
Mgg4591 is on a distinguished road
Mgg4591's Avatar
Could be your neutral safety switch. I know when i had my auto i needed to put it in D or N relatively hard to get it to start sometimes. And this was after i replaced the starter.
2002 Mitsubishi Galant 2.4, 94,500 miles
2007 Toyota Camry 2.4, 29,600 miles
1999 Saturn SL2 1.9, 93,700 miles
Add to Mgg4591's Reputation
Rate the quality of this post and help Mgg4591 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mgg4591 is offline   Reply With Quote
Old 07-27-2010, 11:19 PM   #10
^^^^ This is where the "nudge it toward Reverse and Drive" test applies (see above).
Old 07-28-2010, 08:52 AM   #11
95SL1/2
95SL1/2 is on a distinguished road
I seem to be having the same problem with my 95 sl1 with a twin cam swap, everything was working fine , then on sunday I couldnt get the starter to work right, and push started it to get it home. I pulled a starter that i had laying around had it tested and slapped it on same condition, bypassed the clutch safety switch and same result. I am at whits end and am tired of having to park on curbs and push my car just to leave somewhere.I have checked the wire as described above , i have double checked connections at the starter to make sure they are all tight. Sorry to hijack but i didnt see the need in creating another post for the same condition.
Add to 95SL1/2's Reputation
Rate the quality of this post and help 95SL1/2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
95SL1/2 is offline   Reply With Quote
Old 07-28-2010, 09:53 AM   #12
Time to start narrowing down. Put a voltmeter between your clutch switch bypass and a ground. Turn the key to START. If you get voltage, the problem is downstream - wire from there to the starter, starter itself, solenoid, connection. If you don't get voltage, the problem is upstream - ignition switch, wiring from (underhood?) fuse box to ignition switch, wire from ignition switch to clutch switch bypass. From there just keep doing the "divide and conquer" routine with the voltmeter and an assistant turning the key to START.
Old 08-25-2010, 01:26 AM   #13
Dawggy
Sorry it took so long to reply... thanks for all the tips... being disabled I had to wait till My brother could come over and look into the problem.
It was a small wire that clips onto a small clip near the bolt on the starter. it had came loose and the clip end on the wire was just about off.. He replaced the clip on the wire and secured it a little better and that fixed er right up.
Now if I could get it to stop slamming into 2nd and 3rd gear lol... did the reverse slam fix a few years back and it fixed it but its back and the reverse slam fix didnt fix it this time.
97 sc dohc- getting gas & spark, wont crank without ether, wont stay cranked after??? P.Johnston85 S-Series Tech 37 06-07-2010 05:29 PM
2000 Ls2 was running fine... now wont start!! Will crank, not turn over... dustinv123 L-Series Tech 5 12-02-2009 12:28 AM
Thinking about buying a '96 SL2 that wont start/crank & is low on oil... 1999_Saturn_SC2 S-Series General 6 11-21-2009 10:35 PM
1997 Saturn sl-1 will crank but wont start danlew10 L-Series Tech 2 05-17-2007 05:46 PM
sc2 alarm went off last night now remote wont work & car wont start kre8ive_kustomz S-Series Tech 1 03-27-2007 07:46 PM
