Old 07-15-2010, 05:10 PM   #1
saturngirl81
saturngirl81 is on a distinguished road
Default Hazard lights button pushed in
I have a 2004 Vue and the button that you push to turn your hazard lights has pushed into the dash and I can no longer turn on my hazard lights...does anybody know how I can fix this?
Add to saturngirl81's Reputation
Rate the quality of this post and help saturngirl81 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturngirl81 is offline   Reply With Quote
Old 07-15-2010, 05:24 PM   #2
The Math God
The Math God is on a distinguished road
The Math God's Avatar
Default Re: Hazard lights button pushed in
common problem
if you pull the plastic trim you will find the button has a small plastic clip on it that needs replaced
if you do a forum search you should find more info
mine has pushed in 2 times and I opted to let the dealer fix it instead of taking a chance on breaking all the plastic trim pieces
2007 Vue -- AWD 3.5 Honda
2005 Vue -- AWD 3.5 Honda
2007 Ion 2 -- 2.2
2005 L300 -- 6 cyl
Gone but not forgotten
2003 Vue -- 105K-traded in
2000 LS 2 --140 K-totaled
1994 SL-- 100K-sold
Add to The Math God's Reputation
Rate the quality of this post and help The Math God reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
The Math God is offline   Reply With Quote
Old 07-15-2010, 05:50 PM   #3
saturngirl81
Is that something that would be covered under the warranty? If not how much is it?
Old 07-15-2010, 06:13 PM   #4
XRL
XRL's Avatar
2004 VUE Red Line
Hot glue the piece back in place, that's what I did. It's a common problem.
Welcome to GM. You will learn to "love" your little common problems. It's "personality", not poor design or build qualities.
Add to XRL's Reputation
Old 07-15-2010, 09:20 PM   #5
ricksLS1
ricksLS1 has a spectacular aura aboutricksLS1 has a spectacular aura about
ricksLS1's Avatar
I'd say poor design. Taking off the plastic trim is easy. Mine went and the piece broke. I just wrapped with some electrical tape and it was still fine for 6 months before the VTi died. My Equinox uses an electronic control to engage the hazards .. Not a push button which is nice
Add to ricksLS1's Reputation
Rate the quality of this post and help ricksLS1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ricksLS1 is offline   Reply With Quote
Old 07-17-2010, 12:37 AM   #6
sierrap615
sierrap615's Avatar
the bezel/bracket is p/n 22702075, saturn unique. $15-$20 range, i've sold plenty of them
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline   Reply With Quote
Old 07-17-2010, 11:58 AM   #7
burlyvue2
burlyvue2 has a spectacular aura aboutburlyvue2 has a spectacular aura aboutburlyvue2 has a spectacular aura about
2004 VUE 3.5L
2000 L-Series 3.0L Wagon
Flimsy plastic bracket. Must be gentle with it. I bet I've only touched that button twice in the vehicles life, and with a feather's touch at that.
Add to burlyvue2's Reputation
Rate the quality of this post and help burlyvue2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
burlyvue2 is offline   Reply With Quote
Old 07-17-2010, 03:11 PM   #8
LastL4Banger
LastL4Banger is on a distinguished road
2004 L-Series 2.2L Sedan
Default Re: Hazard lights button pushed in--been there done that
It is a flimsly little piece of plastic that holds the hazard switch. The best thing is duct tape. I've had this happen to two different vues. I actually did this the second time one week ago. There are threads here to tell you how to get the bezels out. Pulling the bezels (center and console) out is easy. The electrical connectors are ridiculously complicated. You dont have to disconnect all the window switches. But disconnect all the electrical connects on the center bezel. with the center bezel out, give the hazard switch and crappy connector a good couple of wraps with duct tape.
fyi before you disconnect all the center bezel switches, turn all the switches (fan, dimmer, temp) to one direction. When re installing make sure you turn the switches back to that direction.
Add to LastL4Banger's Reputation
Rate the quality of this post and help LastL4Banger reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LastL4Banger is offline   Reply With Quote
Old 07-18-2010, 02:58 PM   #9
termite
termite is a jewel in the roughtermite is a jewel in the roughtermite is a jewel in the rough
termite's Avatar
I used a small set screw in the bracket to keep the switch in. http://www.saturnfans.com/forums/sho...hazzard+switch I have had no problems since. If you get a new bracket it will just break again!
It's GOOD to have a spare!
Add to termite's Reputation
Rate the quality of this post and help termite reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
termite is offline   Reply With Quote
Caution/hazard light button MMarlin Vue General 7 06-05-2010 08:14 PM
Dash mounted hazard button onesicsaturn Vue Tech 3 07-13-2008 12:08 PM
2k2 SL2 with BAD Hazard button / switch, best way to fix? Joe SL2 S-Series Tech 9 01-27-2008 05:58 PM
Hazard Button broke help ashmaxwill Vue Tech 3 10-13-2007 08:56 PM
Hazard button help needed The Math God Vue General 12 10-04-2004 08:48 PM
