#1 | ||||
![]() Join Date: May 2003
2004 VUE 2.2L
Blower (fan) does not come on. A/C engages when switch is turned on and stays on throughout all 4 speed settings. Removed blower motor & put 12VDC to it & motor runs fine. Getting 12VDC at blower motor connector so I think the ground is OK. Switched out relays with power window relay & that checks out fine. Blower doesn't work on high which would eliminate resistor card. My only other option is the control switch. Am I missing something? (before I replace the switch) Thanks so much for everyone's help!!
#2 | |||||
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2008
http://saturnfans3.saturnfans.com/~s...d.php?t=144044 ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
#3 | |||||
2004 VUE 2.2L
#4 | ||||
Check for ground again.
... *The CPS is the heart of the entire EFI system. No cps = dead EFI system* *There's more to a/c than just a few cans of refrigerant* *There's more to brakes than just replacing parts*
#5 | ||||
2004 VUE 2.2L
#6 | ||||
You measured for 12v and found it on the connector but ground for the blower motor goes through the black wire to someplace close by and attached to the chassis. Measure the return wire to frame (anywhere frame/metal) using resistance - a continuity test to find out whether the ground is connected or not. All current goes through one ground connection and its been found that the blower ground wire can be loose resulting in cooked wiring as indicated by burned insulation.
#7 | |||||
OP mentioned swapping the relay with nothing gained so I assumed he meant the HVAC BLO relay and I agreed the switch could be kaput. uhlemd ... did you substitute for the HVAC BLO relay? If no, then try another relay. If you did try another relay, I suggest you remove the relay and note the location of which sockets correspond to pins 30 and 87 on relay. Use a heavy piece of wire - with one end connected to ground and carefully insert the other end into the socket for pin 30. See if fan runs with ignition ON and any speed selected. If fan does not run insert the wire in pin 87 and check for run. (Check and double-check to avoid putting the ground on pin 85 or pin 86). If fan does not run, the problem would be in wiring between the relay and HVAC controller, or inside controller. If fan does run it indicates the wire between the HVAC BLO relay and ground is probably open at / near ground-point G203. I can give you a location for this ground if this is the culprit. Good luck! ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
#8 | ||||
![]() Join Date: Apr 2006
i had this same problem, the power wire going to blower motor shorted, had to run a new wire bypassing fuse box underhood. once new power was ran ac works perfectly
| Thread Tools | |
| Display Modes | |
| Blower Control Switch | t&m | S-Series Tech | 1 | 02-11-2010 12:05 PM |
| 2004 L300 Blower Motor Problem | JGra | L-Series Tech | 4 | 12-29-2009 06:42 AM |
| 01 L200 Melting Blower Switch | Adamgh | L-Series Tech | 1 | 10-21-2008 07:16 PM |
| 2002 SL1 Heater-A/C blower speed switch | flythatway | S-Series Tech | 1 | 07-01-2008 04:15 PM |
| HAVC blower switch | sebc | S-Series Tech | 1 | 11-14-2003 02:09 AM |
