#1 | ||||
Would a bad neutral safety switch cause a Saturn not to start? It is a 99 saturn 1.9 dohc, it cranks but will not start. It does have spark and fuel. Could a bad neutral safety switch be the problem?
... 92 SL2, 5 speed 91 Lx 5.0
#2 | ||||
A faulty n/s switch will not even allow the starter to power up!? Its part of the starter circuit to allow the ignition START signal to reach the starter solenoid in order to power the starter motor. You are already cranking the engine over so this means the n/s switch is already working correctly. Think of the n/s switch as the same switch like the clutch safety switch; if an auto shift lever isn't in Park or Neutral, the switch won't close to allow the starter to operate when the ignition switch is turned to START. The clutch safety switch is attached to the clutch pedal swing arm bracket; if the pedal isn't floored the switch stays open, preventing the starter from operating. Both are safety devices.
Having fuel and ignition doesn't necesssarily mean the injectors are pulsing; just fuel to the injectors. You'll have to check the fuel injector fuse as this supplies HOT 12v to each injector; the pcm switches the ground at the appropriate time to open the injectors. You can also pull the plugs to see and/or smell for fuel. Are you sure the cylinder aren't flooded? An original coolant sensor can fail and cause flooding, rich running conditions. Done a compression test? ... *The CPS is the heart of the entire EFI system. No cps = dead EFI system* *There's more to a/c than just a few cans of refrigerant* *There's more to brakes than just replacing parts*
| Thread Tools | |
| Display Modes | |
| Neutral safety switch help | Highmile | S-Series Tech | 2 | 12-15-2009 12:15 PM |
| Neutral Safety Switch????? | Clickety_Clack | S-Series General | 10 | 12-03-2008 08:24 PM |
| Neutral safety switch bad? | chevy57 | S-Series Tech | 6 | 02-05-2008 03:45 PM |
| Transaxle Range Switch\Neutral Start Safety Switch | lonelywolf8588 | S-Series Tech | 2 | 07-20-2006 07:55 AM |
| Neutral Safety Switch | Marlin Liew | S-Series Tech | 7 | 11-03-2004 10:55 PM |
