Old 07-03-2010, 02:14 PM   #1
LJ57
LJ57 is on a distinguished road
Default OBD2 Codes on 2001 Saturn SL1
I just ran the scanner and got the following error codes for my SES light being on :
P0410 - Secondary Air Injection System Malfunction
P0133 - O2 Sensor Circuit Slow Response Bank 1 Sensor
Does anyone know what these mean, and what I would need to do to fix them?
Thanks
2001 Saturn SL1
L4 - 1.9L vin 7 116ci - MFI GAS DOHC
100,000 miles
Add to LJ57's Reputation
Rate the quality of this post and help LJ57 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LJ57 is offline   Reply With Quote
Old 07-03-2010, 03:14 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: OBD2 Codes on 2001 Saturn SL1
http://www.obd-codes.com/p0133 -- p0133
http://www.obd-codes.com/p0410 -- p0133
hopefully these should give you some ideas as to where to start.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 07-03-2010, 03:21 PM   #3
Thanks
The 133 is the O2 sensor in the front exhaust, under the hood. It may be dying but don't replace it till you get the P410 fixed.
Watch this video and find out what is wrong with the AIR system and fix it.
http://www.youtube.com/watch?v=dIrmkxj6wJE
These videos are listed in the How-To Library, first sticky thread.
To reset the codes after fixing just remove the PCM B fuse from the UHJB (engine compartment fuse box) for a minute and replace it.
Old 07-04-2010, 11:20 AM   #4
LJ57
Thanks alot! I'm going to see if I can pinpoint the problems this afternoon. Without this forum and richpin videos, I don't know what I would do. Thanks again!
2001 Saturn SL1
100,000 miles
Old 07-04-2010, 11:28 AM   #5
LJ57
BTW, if I do need to replace the Oxygen sensor, do I need to buy the wires as well? I notice that Bosch oxygen sensors are sold for $18, $79, and $121 (different versions). Is there anything that determines which one I might need?
2001 Saturn SL1
100,000 miles
Old 07-04-2010, 12:05 PM   #6
Cheyne
Cheyne will become famous soon enough
2000 SL2
You want a direct fit instead of a universal. Your best bet would be an NTK or Denso if it comes to that. I wouldn't bother with it until the P0410 has been cleared up, as mentioned above. O2 may be on the way out, but I've seen them go much longer than 100K.
Add to Cheyne's Reputation
Old 07-18-2010, 05:27 PM   #7
LJ57
Ok. After watching the richpin video, I'm about to start trying to figure out what's causing the p0410 code. About four minutes into the video, he says that the pipe going into the exhaust manifold should be inspected for carbon deposits and cleaned if necessary. If there is carbon built up in there, how should I go about cleaning it? Is it difficult to actually remove the exhaust manifold for cleaning?
2001 Saturn SL1
100,000 miles
Old 07-18-2010, 05:35 PM   #8
You clean out the pipe with a coat hanger wire and then about any bristle brush you can find that fits. Soaking in a bucket of diesel fuel helps. Removing the manifold is not difficult but you want to have a new flange gasket and manifold to heads gasket available before doing it. You can unbolt the a/c compressor from the block and then lay the compressor and bracket on the radiator support. Do not stress or bend the hoses any more than necessary as you will cause a leak. It is easier to remove those 4 bolts into the block than it is to put all 6 of the bolts back into the bracket to remount the compressor.
Old 08-31-2010, 12:28 PM   #9
manualman
manualman is on a distinguished road
1995 SL
Timely thread as I tackled a P0410 this weekend. I did the Richpin diagnosis and found everything works fine right up to the exhaust manifold. Little to no exhaust comes out the manifold port when the air pump pipe is removed and the engine is running. I'm guessing this means the passages in the manifold are gunked up.
So I get to track down some gaskets, but let me ask this too: The manifold studs and nuts seem to be a solid mass of rust. What are the odds I actually get them OUT of the manifold without damage? Do people have much luck with that? Any suggestions besides a good dose of PB Blaster? Looks like I should get new studs and nuts too, eh?
While it is off, are there any tricks to cleaning the EGR passages too? My engine seems to make an extraordinary amount of soot (burn 1qt/1,200 miles oil). Looks like a diesel exhaust!
Add to manualman's Reputation
Rate the quality of this post and help manualman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
manualman is offline   Reply With Quote
Old 08-31-2010, 01:12 PM   #10
They are screwed into the aluminum head. So, even if the nut has become one with the stud they come out. They usually unscrew though.
To clean EGR port remove EGR, start engine. That should do it. If not when the manifold is off feed a old speedometer cable back through the EGFR exhaust port into the exhaust port.
PB Blaster usually works. Give it 24 hours and maybe a heat cool cycler also. Wire brush of the corrosion before attempting to remove nuts.
Please help me with these OBD2 codes ..... Hidalgo S-Series Tech 8 02-18-2010 05:15 PM
1998 Saturn Sl1 (Rough Idle)(OBD2 codes 200-300) WadeNKC S-Series Tech 5 04-30-2009 11:56 AM
I need some help with OBD2 codes/ troubleshooting please. WadeNKC S-Series General 4 01-13-2009 04:13 PM
Is a OBD2 suitable Saturn scan tool? goldnugget S-Series Tech 3 03-16-2007 12:03 PM
Broken hose and obd2 codes FraX S-Series Tech 2 03-03-2006 09:47 PM
