Old 06-30-2010, 08:07 AM   #1
emr131
emr131 is on a distinguished road
Default Replacement exhaust manifold studs/nuts???
So in trying to solve my Saturn problems I had to remove the exhaust manifold to check for clogs. The studs are in HORRIBLE shape and the a couple of the nuts were quite misshaped.
I went to Autozone, Advanced Auto, and National Auto and none of them even had replacement kits LISTED in their computers. So now what? There must be replacements out there.
For reference, 1994 SL2.
Add to emr131's Reputation
Rate the quality of this post and help emr131 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emr131 is offline   Reply With Quote
Old 06-30-2010, 10:55 AM   #2
Default Re: Replacement exhaust manifold studs/nuts???
GetSaturnParts, http://www.trademotion.com/splash/in...?siteid=214643 Those are metric studs and nuts.
Stud Pn. 11518152
Nut Pn. 21006315
You can order a nice new set but they will probably be a bit expensive all considered.
The nuts are flange nuts and somewhat difficult to find at your local hardware store. You can use the proper diameter, thread pitch and length generic studs. these will be found at either a good hardware store or a real autoparts store.
Old 06-30-2010, 01:17 PM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
If you have access to a junkyard, the intake manifold studs are the same. And those are usually free of rust and easy to remove.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 06-30-2010, 02:33 PM   #4
blackeagle1
blackeagle1 is on a distinguished road
blackeagle1's Avatar
2000 SL2
I thought the intake and exhaust manifold nuts/studs might be the same. It's amazing the difference in corrosion between one side of the engine and the other.
Current Fleet:
97 Black Gold SC2 Manual
97 Silver SC2 Auto
98 White SL2 Auto
00 Silver SL2 Auto
03 Pontiac Montana
00 Yamaha SUV1200 Waverunner
Add to blackeagle1's Reputation
Rate the quality of this post and help blackeagle1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blackeagle1 is offline   Reply With Quote
Old 06-30-2010, 04:03 PM   #5
KingRex
KingRex will become famous soon enoughKingRex will become famous soon enough
KingRex's Avatar
Well think about it, the exhaust side sees 100X more heat than the intake. Of course they will look terrible after 16 years of heating and cooling cycles.
"The Homecoming King"
Saturns Saved: 18
Saturns Owned: 2
1999 SL2 HCE 175K
1994 SL2 HCE 135K
1999 SL2 Silver 125K
Add to KingRex's Reputation
Rate the quality of this post and help KingRex reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KingRex is offline   Reply With Quote
Old 06-30-2010, 05:17 PM   #6
sdowney717
sdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of light
using stainless would have helped when it was made. Things like this though not worth the makers bother as by the time they are shot, the car is long past due in many ways, in many areas.
Add to sdowney717's Reputation
Rate the quality of this post and help sdowney717 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sdowney717 is offline   Reply With Quote
Old 06-30-2010, 09:11 PM   #7
Don't use stainless if you ever want to remove them from the head again. Store bought metric studs will be just fine if you can find them. the nuts are tough to find though. On the exhaust side you can use the washer face nuts that are serrated on the washer face if you want. The nuts are called whiz nuts. If you ask for whiz nuts and get a blank look they don't have them.
93' SC1 Catalytic to Exhaust pipe fasteners:Studs or nuts and bolts? gbriceno S-Series Tech 8 04-10-2010 11:34 AM
Exhaust manifold to downpipe studs? jamie930 S-Series Tech 10 08-25-2009 10:06 PM
SL1 - lug nuts & studs 72gssaturn S-Series General 1 10-24-2008 09:27 AM
95 Exhaust Manifold Studs SL2Dreams S-Series General 5 08-05-2005 02:06 PM
Exhaust manifold flange nuts joshjani S-Series Tech 4 07-29-2005 05:55 AM
