Old 06-27-2010, 04:39 PM   #1
PortugalFocus
PortugalFocus's Avatar
Default V6 Airbag and Steering Wheel is Now Installed with Pics!!!
It's a fairly straight forward swap.
1. Disconnect the battery and remove the Air Bag fuse. I then plugged in my phone to the car charger port and turned on the headlights to make sure there was no "loose" voltage in the system anywhere.
2. Remove the upper and lower column covers. There are 3 small screws attaching the lower cover to the column.
3. Unhook the four clips holding the 4c ylinder bag and it pops out.
4. Remove the two airbag connectors (pink and white).
5. Disconnect the cruise control plug.
6. Use a 21mm socket to remove the nut holding the steering wheel to the column. Some wheels are on tighter than others. I did not need a wheel puller, just a firm tug and it came loose.
6. Make all the connections behind the bag. There is only ONE additional connection different from the 4cyl bag. The V6 bag has it's own ground terminated on the bag. You don't have to splice anything or cut any wires, just make sure it's connected or the horn won't work.
7. Reverse the installation process. Just make sure the steering wheels is properly lined up and the clock spring does not make any additional revolutions.
Enjoy.
Sticky anyone? Am I the first to do this?
Add to PortugalFocus's Reputation
Rate the quality of this post and help PortugalFocus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-27-2010, 05:29 PM   #2
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Default Re: V6 Airbag and Steering Wheel is Now Installed with Pics!!!
Awesome! I've always wanted to do it, but never did. Looks great.
Where did you get your parts? Ebay or a local junkyard or something?
Not a Saturn.
Add to Tom92SCm's Reputation
Old 06-27-2010, 09:06 PM   #3
pyroom
pyroom is on a distinguished road
pyroom's Avatar
2004 VUE 3.5L
Looks factory! Glad to see it all came together fine.
2004 Vue 3.5L AWD
Add to pyroom's Reputation
Rate the quality of this post and help pyroom reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pyroom is offline   Reply With Quote
Old 06-27-2010, 11:18 PM   #4
PortugalFocus
I got it from my local salvage yard. I got a great deal. I couldn't pass it up.
Old 06-28-2010, 11:01 AM   #5
nitroussaturn
nitroussaturn will become famous soon enough
nitroussaturn's Avatar
since i have a redline i have the steering wheel you swapped too.
but i need to wrap the center peice with carbon fiber fabric,not the horn button...it looks like it has two screws that go in the backside of the wheel and it will just pop off,am i right?since you've dealt with taking them off i figured you would know how to get that peice off,let me know
2004 REDLINE FWD TONS OF MODS..CLICK HERE http://www.cardomain.com/ride/3144619
1999 MERCEDES BENZ AMG E55,MY DD VETTE KILLER
2000 328I M3 RIMS
Add to nitroussaturn's Reputation
Rate the quality of this post and help nitroussaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nitroussaturn is offline   Reply With Quote
Old 06-28-2010, 05:05 PM   #6
PortugalFocus
Leave the screws in place they don't have anything to do with the bag.
There are three clips that hold the bag in place. They are under each spoke of the steering wheel. All you need to do is use a small flat headed screw driver, position it begin each clip and push inward, toward the center of the bag. It will click and you will see the bag come loose.
I will make a video for the removal of the VUE bag on the 4 Cylinder as soon as I get a chance. If you can follow that, then V6 bag is practically identical. I post the link here. Hopefully by tomorrow I'll have it up on youtube.
Old 06-28-2010, 07:07 PM   #7
nitroussaturn
i dont need to take the bag out to do what i want to do,do I?
re read my post i just need to get the whole front peice of the wheel off so i can rewrap it in carbon fiber,the peice where the cruise control buttons are that whole peice of the wheel i need off
2000 328I M3 RIMS
Old 06-28-2010, 08:02 PM   #8
XRL
XRL's Avatar
2004 VUE Red Line
From my digging, the plastic trim piece should come off with those two screws. Though in all honesty you could probably wrap it fine without taking it off.
I'll probably take it off anyways to wrap it whenever I get around to doing that part.
Add to XRL's Reputation
Old 06-29-2010, 07:25 AM   #9
PortugalFocus
You will have to remove the bag to get that plastic cover you want off. I will post how-to later tonight.
Old 10-14-2010, 11:02 AM   #10
XRL
XRL's Avatar
2004 VUE Red Line
Do you have any information on the cruise control plug itself? How many wires, pictures of the plug, etc.
Trying to see if I can swap a steering wheel from an SRX in with steering wheel controls. If I can make the CC work normally, the radio controls will be a breeze with my aftermarket radio.
Old 10-19-2010, 05:31 PM   #11
hoffman_BMX89
hoffman_BMX89 is on a distinguished road
hoffman_BMX89's Avatar
hey guys i wonder if a 2006 steering wheel with audio controls would work if i would get one of those PAC modules and use it with my pionee avic d3 if it would this is a mod well worth doing
1997 Sl2 447000km sold
1998 Sl2 278000km sold
2005 Vue 178000km current car
Add to hoffman_BMX89's Reputation
Rate the quality of this post and help hoffman_BMX89 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoffman_BMX89 is offline   Reply With Quote
Old 10-24-2010, 08:51 PM   #12
PortugalFocus
Yeah the plug was exactly the same. I believe it was a three wire connector and a single wire for the horn.
Good luck.
Also I don't know think the 06-07 wheel will work if you want to add the audio controls unless your car already has it.
Old 10-25-2010, 10:04 AM   #13
XRL
XRL's Avatar
2004 VUE Red Line
My thought is the Cruise controls might not work, since a lot more of the 06-07 is on the GM LAN setup. The 04 SRX has the same basic wheel as us with the CC at the bottom and radio controls on the sides.
The real trick is going to be getting the wiring out from the wheel in a way that it won't break inside from turning.
Old 02-05-2011, 12:39 AM   #14
BlownL36
BlownL36 is on a distinguished road
2002 VUE 3.0L
are the air bags interchangable from 02 to 05?
2002 Vue 3.0L V6 AWD
2002 GTP-Ton of Mods!
2004 Cobra- Ton of Mods!
Add to BlownL36's Reputation
Rate the quality of this post and help BlownL36 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BlownL36 is offline   Reply With Quote
Old 02-08-2011, 11:12 AM   #15
PortugalFocus
No, the connections are different. 02-03 interchange and 04-05 interchange. I wouldn't mess with re-wiring airbags. Not worth the potential failure in my mind.
Old 02-11-2011, 08:03 PM   #16
BlownL36
2002 VUE 3.0L
its a great mod. just wish the dam steering wheels werent so expensive! every wheel i find doesnt have the bag or airbag cover. lol
Old 02-13-2011, 07:53 PM   #17
PortugalFocus
Yeah, it's pricey, you usually have to buy the pair of bad with the module. It can be $400+. Just check you local LKQ U-Pull it yard for one. They usually have the newest cars in the yard I have found out.
Old 04-27-2011, 01:06 AM   #18
Horsepower2011
Horsepower2011 is on a distinguished road
looks good
Add to Horsepower2011's Reputation
Rate the quality of this post and help Horsepower2011 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Horsepower2011 is offline   Reply With Quote
Old 04-29-2011, 11:27 AM   #19
decipher
decipher has a spectacular aura aboutdecipher has a spectacular aura about
ya hope mine works like that.. I have a 2002 already changed the cluster and have the new wheel. I had to paint the plastic trim as mine was damaged but ive painted it Silver like the newer cars as soon as i get enough posts pics will come.. Along with my rl appearance parts!
Add to decipher's Reputation
Rate the quality of this post and help decipher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
decipher is offline   Reply With Quote
Old 04-30-2011, 07:51 AM   #20
decipher
here is a dual stage airbag in my 02 vue
03 Saturn Vue airbag/steering wheel removal curtisaclark Vue Tech 13 07-24-2012 04:00 PM
Pics of my chrome door handles and steering wheel cover jita1 Aura General 11 12-24-2010 03:09 PM
Air Bag & Steering Wheel Swap. 4cyl Plastic to V6 Leather w/ Pics... PortugalFocus Vue Mods 4 06-27-2010 07:17 PM
Airbag/steering wheel plastics Removal? FGCA_XRL Vue Tech 2 11-09-2008 10:30 AM
need help with steering wheel and airbag BLUEION2 Ion General 1 06-08-2006 07:44 AM
