#1 | ||||
![]() Join Date: Jun 2010
Hello everyone; I have recently purchased a used 2003 Ion 3. Today for the first time since owning it (approx. 2 months) it failed to start when I was leaving a parking lot at a local drug store. All of the dash lights were illuminated when I turned the ignition key however, absolutely nothing happened when the key reached the start position (all quiet). I have seen a video on U Tube where some frustrated Ion owners have cut a white wire on the connector at the ignition switch. I believe this disables the vehicles "passlock" security system. Has anyone tried this ? If so does this procedure eliminate the security system completely or simply disable the feature of someone trying to use a wrong key or screwdriver etc. to steal the car?
Thanks
#2 | ||||
cutting this wire will render the security system useless and will leave your car impossibly easy to steal. or you could fix it for like $30.
... 2007 Saturn Ion 2 2003 Chevrolet venture lt trifecta dealer for the U.P. and WI. There is no two door ion. Proudly driving one of the last saturns produced before gm killed the brand.
#3 | ||||
![]() Join Date: May 2007
2003 ION-1 Sedan
If you replace the ignition switch with a new unit, that will solve the problem for the most part.
I replaced mine last year, and I have had only 1 non start issue so far... I just sat in the car for five minutes, and it started right up..
| Thread Tools | |
| Display Modes | |
| 93 sc2 Single wire or dual wire 02 sensor | sctuner89 | S-Series Tech | 3 | 08-05-2009 07:10 PM |
| White Ashy Deposits on Spark Plug Wire Boot | The Critic | S-Series Tech | 2 | 03-25-2009 07:44 AM |
| Saturn alternators: 1-wire, 2-wire, 3-wire? | JohnHupp | S-Series Tech | 5 | 11-25-2008 06:10 PM |
| ignition wire/spark plug wire - resistance/ohms | Heartbeat - '95 SL2 | S-Series Tech | 3 | 10-17-2005 01:09 PM |
| Wire Diagram to Wire in hitch wiring | agr1093 | Vue General | 3 | 01-14-2005 07:34 AM |
