Old 06-19-2010, 04:27 PM   #1
bxxpeace
bxxpeace is on a distinguished road
Default Possible Throttle Body damage??
I thought I had fixed a p0410 a few months ago but it recently came back. As I was diagnosing the issue, I decided to check if the throttle body needed cleaning. I cleaned it about 2 months ago but the inside of the pivot plate was caked with carbon and soot. Upon removing the throttle body to inspect the icv, I noticed some pitting in the chamber next to where the tip of the icv spindle sits. I've posted pictures but couldn't get in there close enough and have it be worth looking at.
Anyone know what's caused this? I can't say it wasn't there in the past but this is the first time I'm noticing it. I'd assume some massive amounts of heat are to blame, but I've the therm and ects and temp gauge are all working properly...any ideas?
Also, what's the best way to clean out the top part of the injection system (what the throttle body leads into)?
I'm thinking that the 410 is caused by clogged exhaust ports though the car blows exhaust out the tailpipe ok - just assuming since the throttle body is caked.
bxxpeace is offline   Reply With Quote
Old 06-19-2010, 06:46 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: Possible Throttle Body damage??
First of all, the throttlebody. That pitting is probably just a non-smooth area of the casting of the throttlebody. That section has no need to be smooth, since it's just an air passage.
The buildup of oily crud in the throttlebody and intake manifold (what you called the "top part of the injection system") is normal for the S-Series, a result of the EGR system, the valve cover system, and the PCV system. There isn't a simple way to thoroughly clean the intake manifold, but the buildup normally doesn't cause problems.
SaturnSeries.net owner
Old 06-23-2010, 04:10 AM   #3
bxxpeace
Thanks for the reply.
How to know if throttle body is bad? hd071502 Vue Tech 11 03-12-2009 11:14 AM
Body Damage Low Speed Backing POS S-Series Tech 10 01-19-2009 09:06 PM
Throttle sticks - not throttle body - help! dannysm213 S-Series Tech 2 12-10-2006 05:20 PM
Repairing Body Damage carl S-Series General 13 10-08-2006 12:08 AM
Body Damage-Accident RicSC2 General Saturn Discussion 6 01-23-2003 11:25 PM
