#1 | ||||
I have a '95 SL2 automatic. I am looking to replace my 205/50/R16 tires, and I know someone who has an almost new set of Goodyear Assurance Tripletread tires (~$500 new) who will sell them to me for $100. (Seems like a really good deal...) Unfortunately, they're 205/55/R16, not 205/50/R16. First of all--will they even fit without clearance issues?
Given that they do fit, is it a good idea to increase the tire size like this? How much of an impact will it have in performance? I don't race or anything, and obviously at higher rpms it won't matter much, but my SL2 has always been really sluggish accelerating from a stop (often making it difficult to merge into moderate traffic from a stop). I'm not at all an aggressive driver, but because of where I live and drive, I often have to be able to accelerate to around 30mph, from a stop, going up a pretty steep hill, with very little gap in traffic. Will the taller gearing from these tires make much of a difference in off-the-line performance? I assume on the highway, the taller gearing would give me better mileage, assuming it's not slowing the engine down too much...? Technical stuff: the circumference of the OE tires is 76.1", meaning 833 revs/mile (4.6" sidewall). My current tires are 75.6", meaning 838 revs/mile (4.0" sidewall). The 205/55/R16s would be 78.2" in circumference, meaning 811 revs/mile (a difference of 2.7% vs stock) with 4.4" sidewall. Thanks for your suggestions! ... High compression build: .033" shaved/ported head, flat-faced valves; gen3 rods, pistons, tie-plate; OE header, custom CAI, SDA street cams with adjustable sprockets, WBO2, SAFCII, LSD. ASE A1-A8+L1
#2 | ||||
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference 195/60-15 4.6in 12.1in 24.2in 76.1in 833 0.0% 205/50-16 4.0in 12.0in 24.1in 75.6in 838 -0.6% 205/55-16 4.4in 12.4in 24.9in 78.2in 811 2.7% 195/75-14 5.8in 12.8in 25.5in 80.2in 790 5.4% I put studded 195/75R14s on a ~1.3" lowered '93 SL2. Long as I didn't do 70+ 'round corners in 50 (or less) zones it was fine, and it'd tap the wheel wells on the larger bumps at 40+ (rear only). ... My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
#3 | |||||
Also, how much of a difference in performance did the larger tires make? ... High compression build: .033" shaved/ported head, flat-faced valves; gen3 rods, pistons, tie-plate; OE header, custom CAI, SDA street cams with adjustable sprockets, WBO2, SAFCII, LSD. ASE A1-A8+L1
#4 | ||||
![]() Join Date: Dec 2009
1998 SC1
I have 195/65R15 on my front tires and have had no rubbing whatsoever. I cant imagine another centimeter will affect it.
... 1998 SC1 Just another OEM engineer...
#5 | ||||
205/55-16 fit but you'll lose some clearance between the tire and the spring perches. also they make the car look like a monster trunk. I was running 16-inch wheels on my 96 SC2 and ordered a set of 205/50-16 tires. Well someone else's 205/55-16 tires arrived and Discount Tire mounted them on my wheels by mistake. I walked out to my car and took one look and my jaw dropped. So I had them removed and they found my 205/50-16 tires that were stacked next to were the other tires were stacked.
... eRic 02sc2 DR SCCA Solo 2001,2002 1st DSP WHRRi 2007,2010 Fun Run 1st DR SCCA 2008 Triathalon 1st PF DR SCCA Solo 2009 2nd ST DR SCCA Solo 2010 1st ST Crutchfield: pkeqe-6j8e3-d2qqe
#6 | |||||
![]() Join Date: Jul 2006
![]() ... 1995 Saturn SC2 - ST(X)ish 1994 BMW 325i Sport www.furrin.org
| Thread Tools | |
| Display Modes | |
| Hit a tire carcass, trying to get an idea how much repair is going cost | Anubis | S-Series Tech | 2 | 04-04-2010 09:37 PM |
| Seafoam in oil good idea bad idea? | Blind898 | S-Series Tech | 9 | 07-22-2009 12:05 AM |
| 17" Konig Unknown, size? tire size? | 92[SL2] | S-Series Tech | 1 | 05-14-2007 10:45 PM |
| Good turbo idea or not.. | sl2clone | S-Series Mods | 7 | 02-10-2007 10:24 PM |
| good idea | acelondon | Miscellaneous Tech | 0 | 08-03-2004 09:21 AM |
