Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 06-05-2010, 11:46 PM   #1
lency
lency is on a distinguished road
Default thermostat location
I have 2004 saturn vue 2.2 can you tell me the location of the thermostat if is on the left or on the right of the engine.
Add to lency's Reputation
Rate the quality of this post and help lency reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lency is offline   Reply With Quote
Old 06-06-2010, 07:07 AM   #2
Chazberry
Chazberry's Avatar
Default Re: thermostat location
I don't own one, but Answera.com says:
On the back side of the block. The water pump is on the passenger's side, and the thermostat housing is on the driver's side. It's located under the exhaust manifold.
Add to Chazberry's Reputation
Old 06-08-2010, 12:00 PM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
Is the VUE 2.2 the L61 or L66? Because the thermostats are in two different locations.
On the L61 its behind the exhaust heat shield. And on the L66 its behind or under the battery.
L61:
L66:
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 06-08-2010, 07:52 PM   #4
lency
I replace the thermostate and antifreez bottle cap on my vue 04 with the help from you guys. But is still overheat, a friend of my told me that i need to change the cooling fan that it work too slow. if you put your hand on it when the fan is working you can bearly feel it. you can see the water borling in the bottle. what did you guys think waterpump or fan.
Old 06-08-2010, 08:09 PM   #5
Chazberry
Chazberry's Avatar
What's the Temp Gauge read? Does it run any cooler on the highway than it does sitting still with the fan on?
Old 06-08-2010, 08:30 PM   #6
lency
I did not read the guage all know is that 5-10 mins after starting the car is on guage red. the fan work but you cannot hear it runing. fan is very slow. there is know code for the rad sensor. but there code p0480 that just came up today.
Old 06-08-2010, 08:38 PM   #7
Chazberry
Chazberry's Avatar
See if this thread helps . . .
http://www.saturnfans.com/forums/sho...ighlight=p0480
Your fan does have a high and low speed. See attached pdf for some guidance. Could be a relay problem.
Old 06-08-2010, 09:00 PM   #8
lency
P0480 Cooling Fan Relay 1 Control Circuit. where can i find this lay. also can a car run without thermostat?
Old 06-08-2010, 09:25 PM   #9
Chazberry
Chazberry's Avatar
The relay is probably a 'dealer only' item - any GM dealer should be able to get you one - probably the cheapest thing to try. A car will run without a t'stat - just not very well since the engine won't be operating at the right temperature. It also won't help much if your fan won't go to high speed.
Old 06-09-2010, 08:05 AM   #10
lency
The car have high and low relay. which one did i need to change
Old 06-09-2010, 01:19 PM   #11
Chazberry
Chazberry's Avatar
Do the relays look identical? If so, can you swap them and see if you then just have high speed?
Old 06-09-2010, 06:35 PM   #12
lency
I swap the relay also i replace the rad, bottle cap and the fan also with thermostat yet the car is overheating. the water is just boiling in the antifreeze bottle. You can hear the noise inside the can when the water is boiling.
Old 06-09-2010, 06:41 PM   #13
Chazberry
Chazberry's Avatar
So swapping the relays did NOT give you more fan speed?
Old 06-09-2010, 07:15 PM   #14
Chazberry
Chazberry's Avatar
I trust you checked the High Speed Fan Fuse?
Old 06-09-2010, 10:56 PM   #15
lency
i will check first thing in morning. on the thermostat i just need to 2 bolt`
Old 06-10-2010, 11:45 AM   #16
lency
High Speed Fan Fuse was burn out which i replace this morning. i remove the battery to delete the code. Now my 04 Vue will not start. the car feel like starting but it will not start. Help help
Old 06-11-2010, 08:40 PM   #17
lency
The problem with this car is getting too much for me, today the MECH to me that there is water in the oil cap. but when i check with stick i could not tell. Do you think that is a blow head gasket? i place RAD,FAN,WATER PUMP, THERMOSTAT.
Old 06-11-2010, 08:58 PM   #18
Chazberry
Chazberry's Avatar
You have a new radiator, fan, water pump AND thermostat!?
A little water on the oil cap could be normal condensation.
Old 06-11-2010, 11:57 PM   #19
lency
You said is normal condensation will this cause any problem or will this make it overheat?
Old 06-12-2010, 07:37 AM   #20
Chazberry
Chazberry's Avatar
It won't cause a problem and does not cause overheating. If it's normal condensation, it should disappear after the engine has run for awhile.
2005 Saturn ION Thermostat Location twilson16 Ion Tech 12 01-17-2018 07:51 AM
PCM Location?? kct001 S-Series General 3 01-17-2010 05:26 PM
MAF location rmarmion L-Series Tech 1 10-15-2008 03:37 PM
Location of TPS? Mike1969 S-Series Tech 3 06-27-2006 10:51 AM
ECU location in Vue? saturn-pilgrim Vue Tech 2 01-14-2005 12:13 AM
