Old 06-05-2010, 07:12 PM   #1
medium1
medium1 is on a distinguished road
Default Is the AC clutch supposed to cycle?
Is the AC clutch supposed to cycle on and off on a 2000 sl2 or is it a variable compressor like the V5 compressor?
Add to medium1's Reputation
Rate the quality of this post and help medium1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
medium1 is offline   Reply With Quote
Old 06-05-2010, 08:18 PM   #2
Default Re: Is the AC clutch supposed to cycle?
In one word, no.
The Saturn compressor is a variable displacement rotary vane type pump. The rotor assembly houses five lightweight vanes that extend outward contacting the cylinder wall creating the compression area. The compressor has an internal control valve that allows it to change its pumping capacity or displacement, reacting to heat loads on the air conditioning system. The range of displacement can vary from 5 percent (5.5 cc) to 100 percent (110 cc). The compressor's natural or resting state is at minimum displacement.
Old 06-05-2010, 08:21 PM   #3
Saturn AC compressor clutches don't cycle with normal operation.
Add to ssicarman's Reputation
Old 06-06-2010, 01:18 AM   #4
ahimsa1
ahimsa1 is on a distinguished road
1997 SW1
A likely cause of cycling a lot is a system that is low on refrigerant. A manifold gauge should be able to tell you if that is the case; Richpin has a video on s-series a/c troubleshooting on youtube that you might want to check out.
97 SW1 Auto 174k
Add to ahimsa1's Reputation
Rate the quality of this post and help ahimsa1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ahimsa1 is offline   Reply With Quote
Old 06-07-2010, 08:08 PM   #5
rusty7983
rusty7983 is on a distinguished road
its low on refrigerant. easy fix, but use gauges to make sure it has the correct amount in the system.
Add to rusty7983's Reputation
Rate the quality of this post and help rusty7983 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rusty7983 is offline   Reply With Quote
Wipers cycle by themselves while driving me04096 S-Series Tech 4 03-28-2010 07:38 PM
drive cycle hdnick01 S-Series Tech 7 02-16-2010 07:45 AM
98 SW2 AC Clutch doesn't cycle. halmiles S-Series Tech 4 05-12-2009 03:06 PM
What tool are you supposed to use to get the A/C clutch off? JC316 S-Series Tech 8 05-23-2008 03:15 PM
Saturn Cycle Racers win prof General Saturn Discussion 2 07-10-2001 12:46 AM
