Old 06-03-2010, 04:08 PM   #1
justin_zink
justin_zink is on a distinguished road
1995 SL
Default pcm swap issue
I have a 95 saturn sl and a 95 saturn sl2. At this time I am putting the SOHC engine in the sl2 body. I know some one is going to ask why, so to answer them before they ask, the sohc engine is good but the uni-body rotted out and the DOHC engine was dead. Now to the question, I know I have to swap the pcm, I have found other threads on here that say I do not have to swap the harness. The problem is that the rejection tabs on the connectors do not line up. Is there something I am missing or do I have to swap the harness. Also the wires for the alternator were cut off the connector, I have another connector and the pin layout, The only problem is that both of the wires are the same color. I am wondering, seeing as one of the wires comes from the ign. will that have 12 volts on it with the key on, and if not is there another way to find out which wire is what. Thank you in advance for any help.
Add to justin_zink's Reputation
Rate the quality of this post and help justin_zink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
justin_zink is offline   Reply With Quote
Old 06-05-2010, 10:58 AM   #2
Low Saturn
Low Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to all
Low Saturn's Avatar
2008 AURA XE
Default Re: pcm swap issue
This is correct.
Take a new, sharp razor blade and cut off the tabs.
They're actually different. One is brown, one is brown with a white stripe.
With the key in the run position, the brown/white one (cavity F) will get 12 volts. The brown wire (cavity L) goes to the instrument cluster.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevy Suburban
-2008 Saturn Aura XE V6
Im out of EGR adaptors & ECTS connectors.
96 sc2... which years of window regulators will swap? not found in swap guide... DJboozeAlot S-Series Tech 3 08-07-2012 04:45 PM
3.0L Oil Cooler issue NOT fixed & steering issue Partymmudasti L-Series Tech 5 08-08-2008 08:48 AM
steering wheel issue??suspension issue?? i'm dumbfounded VTVUE Vue General 8 06-17-2008 06:54 AM
91/92 Engine Swap SOHC Issue! chicago L-Series Tech 1 06-21-2007 10:05 AM
01 PCM swap issue remedys S-Series Mods 0 07-11-2006 10:29 PM
