Old 05-31-2010, 03:18 PM   #1
Pizza
Pizza is on a distinguished road
Default Saturn 1996 SL2...Incorrect Gear Ratio w/ Transaxle Leak
So i searched the forums to find anyone with the same problem...and I did see a number of questions about codes P0733 and P0734, but I did not see anyone who also had leaking transaxle fluid. The two codes represent an incorrect gear ratio for 3rd and 4th gear. Anyone have any idea if these two situations are possibly interrelated? Or if they pinpoint a problem? Thanks.
Add to Pizza's Reputation
Rate the quality of this post and help Pizza reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Pizza is offline   Reply With Quote
Old 06-01-2010, 12:10 AM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: Saturn 1996 SL2...Incorrect Gear Ratio w/ Transaxle Leak
What symptoms are you getting, aside from the codes? Where is the leak?
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 06-01-2010, 06:27 AM   #3
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
It means the trans is slipping in those gears.
Possibly from low fluid?
P0734 - Incorrect 4th Gear Ratio Qjinx S-Series Tech 9 04-22-2009 06:01 AM
1999 SL2 P0731 Gear 1 Incorrect Ratio Problem EdHasA99 S-Series Tech 20 05-28-2008 02:02 AM
Incorrect gear ratio problem-not resolved vectad S-Series Tech 7 08-06-2007 01:21 PM
Gear 3 Ratio Incorrect? ahspride2003 S-Series Tech 5 01-10-2007 09:56 PM
Incorrect 3rd Gear Ratio code problem katy S-Series Tech 11 05-29-2005 11:23 AM
