Old 10-04-2011, 10:12 PM   #1
paumcd
paumcd is on a distinguished road
Default 1997 Saturn SL2 won't start....
Sometimes it'd start on one turn of the key. Sometimes 3 or 4 in rapid succession. Been doing this for months.
Now it stopped turning over completely. Tried jumping it to no avail. The engine eats oil.
Anything besides the starter I should look at before I replace the starter?
thanks in advance
Add to paumcd's Reputation
Rate the quality of this post and help paumcd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
paumcd is offline   Reply With Quote
Old 10-05-2011, 08:20 AM   #2
acman
acman has a spectacular aura aboutacman has a spectacular aura aboutacman has a spectacular aura about
1999 SC1
Default Re: 1997 Saturn SL2 won't start....
The first step for a "no-crank" condition is to check the battery and battery cables, both the positive and negative. Remove the cables from the battery and inspect for corrosion. Also, check the ground cable connections at the block and frame and the positive cable connection at the starter for tightness and corrosion. Next, charge the battery and load test. If all is good, check for 12 volts at starter solenoid when the ignition is switched to "start." If the vehicles passes all these tests then it is time to replace the starter motor.
1997 SL2, 5 speed
1999 SL1, Automatic
Add to acman's Reputation
Rate the quality of this post and help acman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
acman is offline   Reply With Quote
Old 10-05-2011, 09:09 AM   #3
DonP
Try a rap on the starter with a board. If that cures it for this session it indicates the need for a replacement starter.
Using oil is not unusual, the question is how much - that is how miles per quart of oil. There are many threads on oil consumption.
Add to DonP's Reputation
Rate the quality of this post and help DonP reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1997 Saturn SL2 wont start no click br4nd0n S-Series Tech 1 12-13-2010 04:51 PM
1997 Saturn SC2 won't start tireddad S-Series Tech 3 12-28-2008 04:46 PM
1997 SL2 Does not always start kacee S-Series General 11 06-11-2008 07:53 PM
1997 Saturn sl-1 will crank but wont start danlew10 L-Series Tech 2 05-17-2007 05:46 PM
1997 Saturn SL2 Stalls 5 minutes after start up cdiesel77 L-Series General 3 10-31-2005 11:11 PM
