#1 | ||||
![]() I had the "engine light" come on the other day. I plugged in the computer and this code came up (P1516).
Description: manufacturer control speed Idle speed control Aux imputs After looking up the code on the Actron website, it broke it down as: Throttle actuator control module (TAC) Throttle actuator position performance Funny thing is., I cleared the code out, and the "engine light" hasn't come on again since. The car drives perfect. Any ideas why on this would come on?? ![]() And if it does happen to pop up again., I'm guessing replacing the "TAC" wouldn't be a "affordable" replacement. That s**t just SOUNDS expensive. I'm just hoping that kind of thing is covered under my extended warranty.
#2 | ||||
![]() it's your gas pedal. you can try working the connector on the pedal and cleaning it with sensor cleaner (make sure you let it dry before plugging it back in). and yes, it is expensive.
... 2007 Saturn Ion 2 2003 Chevrolet venture lt trifecta dealer for the U.P. and WI. There is no two door ion. Proudly driving one of the last saturns produced before gm killed the brand.
#3 | |||||
![]() Quote:
Thanks so much for the reply!! ![]()
#4 | ||||
![]() Join Date: May 2008
2006 ION-3 Sedan
![]() I had the same error code come up on my wife's 06 Ion2. The car was idling high so I cleaned the MAF sensor and the Throttle body and that didn't do it. Instead of spending money replacing parts just for the hell of it I took it to the dealership. Saturn has extended the warranty on the PCM for 8 years/80,000 miles. Mine was bad so the dealer replaced it for free. Worth a try!
#5 | ||||
![]() ![]() ![]() Join Date: Feb 2017
![]() It's likely your electronic throttle control module. Buy one at the parts store and replace it. four bolts a couple of hose clamps and an electrical connection.
#6 | |||||
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2006
2007 ION-2 Quad Coupe
![]() Quote:
![]() ... 2007 Ion 2 Quad Coupe 5-speed manual 177K miles 2007 Chevy Equinox LT 180K miles
Codes P0121, P2101, P1516 | davesaturn | Ion Tech | 26 | 05-10-2010 05:56 PM |
egr error | bdobraj | S-Series General | 6 | 09-14-2009 07:55 AM |
DVD error | wantasaturn | Outlook General | 6 | 04-15-2009 05:05 AM |
P1516/p2101 | atlas4711 | Ion General | 1 | 12-08-2008 10:48 PM |
94 SW1 CD error | Roadmaster | S-Series General | 5 | 05-24-2005 10:57 PM |
