Old 05-25-2010, 11:07 AM   #1
jay11789
jay11789 is on a distinguished road
1993 SL1
Default High Idle Issue HELP!
From a previous post......
"I have a 1993 Saturn SL1. 110,000 miles on it. I change the oil (high mileage oil) every 2,000 miles or so. Im always adding oil, so it burns a bit. I travel about 80 miles a day in it. Recently, Ive had an issue where it idles extremely high after a long commute, and especially if its hot out! The morning commute is perfectly fine....then the afternoon commute is when I have the issue. Usually after a long commute of stop n go, on a hot day. The car just idles very high when stopping at a light, and extremely high when in park. "
Update: TPS and ECTS replaced. Issue still exists.
Anyone know what step to take next?
Add to jay11789's Reputation
Rate the quality of this post and help jay11789 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jay11789 is offline   Reply With Quote
Old 05-25-2010, 02:29 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: High Idle Issue HELP!
Maybe either check for lost vaccuum and/or clean/replace your IAC valve, if not clean the throttle body?
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 05-25-2010, 03:28 PM   #3
SilverFox
SilverFox is on a distinguished road
You might also try checking you engine thermostat. The one that feeds the computer, not the gauge (providing you have two). Those can malfunction in some of the older cars and cause the car to think it's cold outside when it's not. Just an idea, but a long shot.
Add to SilverFox's Reputation
Rate the quality of this post and help SilverFox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SilverFox is offline   Reply With Quote
Old 05-25-2010, 05:36 PM   #4
adventureoflink
If you're thinking ECTS, the OP already replaced his. To OP: Did you check and clean/replace the connection as necessary?
and yes, OP having a '93, he has two sensors. Good call on the thermostat though. Get a 195 degree F one (though IIRC the 185 degree F one will work just fine on OBD-1 vehicles).
97 SL2
DOB: 3/19/97
DOB: 2/4/04
2000 SL1 high idle issue huey graphite S-Series Tech 1 10-15-2009 01:39 PM
97 with high idle issue tiger saturn S-Series Tech 2 04-07-2007 09:14 PM
High Idle, AC/Compressor Issue SL1Joe S-Series Tech 5 02-28-2007 05:09 PM
High Idle Issue jjseiler13 S-Series Tech 0 02-06-2007 10:06 AM
High Idle Issue... Neo Ion General 6 01-18-2005 01:51 PM
