Old 05-30-2010, 04:04 PM   #81
SLCraig
Default Re: What did you do to your S-Series today...
Nothin'
my SL2 spends most of its time just sitting thesedays.
It needs a clutch I think... Hard shifting into first gear still. Not as interested in driving it as I used to be. Although I still use it sometimes.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-30-2010, 04:19 PM   #82
SaturnNJeep
SaturnNJeep is on a distinguished road
SaturnNJeep's Avatar
"Adjusted" the driver's side door main window gear so it would mesh in the middle of the motor pinion instead of on the inner edge and slipping inside of the gear and chewing up the teeth, Worked like a charm!!
Jerry
Add to SaturnNJeep's Reputation
Rate the quality of this post and help SaturnNJeep reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnNJeep is offline   Reply With Quote
Old 05-30-2010, 04:33 PM   #83
Beachbaby902
Beachbaby902 is on a distinguished road
Beachbaby902's Avatar
2007 AURA XE
Looked at all three of my Saturns.
The 94' SL2 went to church and back home. (my aunt drives it to church)
Add to Beachbaby902's Reputation
Rate the quality of this post and help Beachbaby902 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Beachbaby902 is offline   Reply With Quote
Old 05-30-2010, 07:38 PM   #84
02SC2drvr
02SC2drvr is on a distinguished road
02SC2drvr's Avatar
found out my front left brake line got knicked somehow ? spraying fluid everywhere. so i ripped it off and took it to advance auto and i was given 3 8" straight metal lines with fittings. now my sc2 is an 02(if the name didnt give it away) so i dont know how the other years are.. but that brake line looks like one of those crazy straws haha.. so i spent good portion of the day gettin the right bends in it by hand (no pipe bender). everything worked out so i cant complain, but my damn hands hurt! ha
also changed plugs and wires and changed oil with castrol syntech.
Shes a happy car now
Add to 02SC2drvr's Reputation
Rate the quality of this post and help 02SC2drvr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
02SC2drvr is offline   Reply With Quote
Old 05-30-2010, 09:18 PM   #85
Daishi360
Daishi360 is on a distinguished road
Daishi360's Avatar
Not much today (I helped one roommate replace a harmonic balancer on his 99 sable and helped the other roomate with a radiator job on his accord). But on Friday, I changed the transmission fluid in my SL2 5-speed from whatever was in there to Amsoil Torque-drive. Shifting is probably 50% smother now, I highly recommend it.
1998 SL2 5-Speed
I/H/E
AMR Engineering Strut Braces & Rear Sway Bar
AMR Radiator
SDA Dogbones & TAM
Engine Rebuilt at 138K (crankshaft, rering, remanned head)
210K miles
Add to Daishi360's Reputation
Rate the quality of this post and help Daishi360 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Daishi360 is offline   Reply With Quote
Old 05-31-2010, 05:07 PM   #86
Finally got around to replacing my driver side door panel. Replacement panel has been sitting in my garage for about 6 months, but up until a couple of months ago, it was too cold to do anything. I think this was maybe 10-15 minutes
No more duct-tape bodywork from the previous owner
I also replaced a light bulb - the odometer bulb. That was considerably longer - I was on my back a lot so I had to get up and stretch every so often. Took a picture of the back of the cluster so I can plan my LED conversion
It's going to take some time getting used to seeing those bright numbers down there
Then I put a little aerospace 303 on the dash, steering wheel, leather shift knob, front door inner panels and console.
Old 05-31-2010, 07:35 PM   #87
bumpdraft
bumpdraft's Avatar
1998 SW2
Today, finished installing the front Quick Struts on my dad’s 1998 SW2.
For the last week, I replaced a wheel bearing and power washed the rusty inside of the engine cradle on the driver’s side (will undercoat later).
De-scaled, wire wheeled then painted the engine cradle with rusty red and then gloss black.
Re-sealed dried/cracked seam sealer in wheel well using olde tube of WindoWeld. - Then painted everything, including strut mounting surface.
Also painted exposed/rusty brake lines.
New (Chinese) Raybestos Rotors and OEM AC/Delco Pads, including re-lubing the caliper pins.
New Moog Tie Rod Ends
Added more moly grease to OEM Lower Control Arm ends…and painted them (and an old decorative milk can in the yard I'm a paintin' fool).
Painted Knuckles and chipped/filed the rust off the boot sealing surfaces.
Hey! Hey! Hey!:
One side at a time...Using a JC Whitney magnetic camber bubble level, was able to perfectly match camber setting. Put car on hoist, raised it to comfortable height and un-plugged it. Zeroed bubble level on new rotor, then removed rotor to a safe place with bubble level still attached. Used a bubble level across lug nutz to keep JC Whit level perpendicular to the world.
Used same to set Quick Strut back to perfectly same camber.
Tie rod ends:
One side at a time...Using distance from steering rack boot at tie rod to edge of threads on tie rod end...
Made an adjustable gage out of bar stock held with binder clips.
Adjusted new tie rod ends to perfectly match settings prior to removal.
When he tried out his new Quick Struts, he said he could let go of the wheel and the car tracked perfectly down the road. – Steering wheel straight and everything!
Will try the same for the rear set of Quick Struts…
If the alignment is not actually perfect, it's darn close. After the springs have had a chance to settle, at least the alignment tech will only need to tweak it.
Add to bumpdraft's Reputation
Old 05-31-2010, 09:46 PM   #88
MINICooperS
MINICooperS is a jewel in the roughMINICooperS is a jewel in the roughMINICooperS is a jewel in the rough
MINICooperS's Avatar
Put it in storage and started driving a 5-spd Jeep.
Add to MINICooperS's Reputation
Rate the quality of this post and help MINICooperS reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MINICooperS is offline   Reply With Quote
Old 05-31-2010, 10:01 PM   #89
wheatabix
wheatabix is on a distinguished road
Originally Posted by mgordon1100 View Post
Lighting is fixed. Although I cracked the bottom plastic piece covering the steering column. I just couldn't find a 5.5 nut driver anywhere. Nor could I find a 7/32. They are rarities, and Saturn went and put a rarity screw, in a place that's physically impossible to put a socket. Anyhow, after breaking the thing, which happened unintentionally, I just taped up my exposed wires real good. Fuse doesn't blow anymore.
it was a couple years ago, but i found the 5.5 at sears, in a set, handy little set too!
Add to wheatabix's Reputation
Rate the quality of this post and help wheatabix reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wheatabix is offline   Reply With Quote
Old 06-01-2010, 02:24 AM   #90
sw87
sw87 is on a distinguished road
1995 SW2
Yesterday I put the car on the jacks. So for now its waiting for me.
Come friday I'm finally fixing a hole I have in the exhaust. Its actually a failed welding; my idea is to wrap a piece of sheet metal around it and fasten it using steel belts, hopefully it'll hold up. I really dont feel like changing the whole exhaust.
And next project on that day will be to finally finish up my ignition system. I will be installing two switches - one for the instruments and the other for the radio. The starter already has a button, and the crazy part is that sometimes the car would start just by pressing it in, without pressing the cluch in at all... yet sometimes it doesn't work
Add to sw87's Reputation
Rate the quality of this post and help sw87 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sw87 is offline   Reply With Quote
Old 06-01-2010, 02:28 AM   #91
sw87
1995 SW2
I found a 7/32 at Home Depot when I need to wire start the car... unfortunately it wasn't a screwdriver but a nut that sits atop one. It was too big to fit in the whole and I ended up having to break through the plastic. Tough love.
Old 06-01-2010, 05:28 AM   #92
vtsl2
vtsl2 is on a distinguished road
vtsl2's Avatar
I have been having trouble with the right rear window working. Yesterday i pulled the skin off the door. Exposed the wiring to find only a crack in the power wire, so I spliced it just the same(might as well, I had it apart). I also changed the outside handle mech. cause the spring had broke.
Oh and I washed it like I do way to often, I like it to look good all the time. I don't like a dirty car. It will get dirty again today because it just started to rain.
SATURNS ROCK: THATS ALL I HAVE TO SAY
99 sc2m mine
94 sl2m my sons
10 ford Taurus with paddle shift(cool)
99 sw2a converted to manuel
02 chevy Silverado extened cab stepside
99 sl2m retired
Add to vtsl2's Reputation
Rate the quality of this post and help vtsl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vtsl2 is offline   Reply With Quote
Old 06-01-2010, 12:45 PM   #93
bumpdraft
bumpdraft's Avatar
1998 SW2
Tie rod ends:
One side at a time...Using distance from steering rack boot at tie rod to edge of <taper> threads on tie rod end...
knowwhatimean??
Last edited by bumpdraft; 06-01-2010 at 12:48 PM.. Reason: Let's hear it for desperation!
Old 06-01-2010, 02:08 PM   #94
adventureoflink
adventureoflink's Avatar
by five speed, you mean a stick shift, right? (kinda out of touch when it comes to modern-day automatic transmissions.) it'd be interesting if it were a stick...
oh yeah, I took it out a few times today, once to get some groceries, the other to take my dad to work.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 06-01-2010, 03:33 PM   #95
MINICooperS
Definitely! 5-spd stick just like my Saturn SL2. It's a 2.4L 172HP Jeep Patriot, 4WD, twin cam VVT 4 banger. Will probably not make it to 243,000 miles like the SL2, but it may flirt with 29 mpg.
Old 06-01-2010, 03:54 PM   #96
SaturnNJeep
You're the man, a Jeep, a Mini, AND a Saturn!! If I didn't have to sell my '02 Cooper S when I moved down here, I would have that trifecta too, Oh, and by the way, my '92 Jeep Wrangler is at 242K, so, there's hope,
Jerry
Old 06-01-2010, 04:01 PM   #97
MINICooperS
I heard that! Of the 3, the Saturn still gets overall points.
Old 06-01-2010, 04:09 PM   #98
SaturnNJeep
Well, for me, the Jeep is my first love. I've had it since '97 when it had 57k miles on it. Loved the Mini as well, great DD!! Whooped Mustang GT's with it, and STILL got about 40mpg, . Eventually, I'll be looking for a Clubman S, but, for now, the Saturn works great as a DD, and I don't have a car payment on it, . Have to wait until the wifey's '04 Grand Cherokee is paid off, then, I'll get a Mini.
Jerry
Old 06-01-2010, 09:41 PM   #99
eRic 02sc2
eRic 02sc2's Avatar
today I de-stickered my Saturn and cleaned the windscreen, sunroof, mirrors, backlite, and windows with Stoner invisible glass.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 06-02-2010, 01:28 AM   #100
96sctwo
96sctwo is on a distinguished road
Everything to try and fix it.....
Add to 96sctwo's Reputation
Rate the quality of this post and help 96sctwo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
96sctwo is offline   Reply With Quote
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 03:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 07:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 01:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 07:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 08:03 PM
