Old 05-25-2010, 07:49 PM   #61
Signmaster
Signmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to behold
Default Re: What did you do to your S-Series today...
Originally Posted by SaturnNJeep View Post
I tried to do this..... sprayed the bottom of the cover with some sticky gasket stick stuff, stuck the gasket on the cover, put it on CAREFULLY, tightened the bolts, only to find that the back side of the gasket had come out. Then, I couldn't find the stupid torx socket that I had used, so, it's sitting. Probably going to have to get another gasket tomorrow because, by the time I get the cover off to get the gasket out after work, it'll be deformed,
Go figure, I can tear apart several Jeep trannies and transfer cases and put them back together, but I can't even do a simple valve cover gasket replacement!! Looks like I'll have to sell the Saturn, and give back my Saturn Owner's Card, because I'm not worthy!! I'll get it straight, just frustrated.
Jerry
Tell you what, we won't require you to get rid of the Saturn or turn in your owners card. But if you screw up that cam cover gasket replacement again, we're meeting half way between VA and FLA and trading cars. After all my single cammer is a '95 too, and more important the cam cover doesn't leak!
But at some point, all of us have had a basic job kick our tails.
Old 05-25-2010, 07:53 PM   #62
adventureoflink
adventureoflink's Avatar
Originally Posted by 92SL25SPD View Post
why not do this yourself?
See my "at a crossroads with my Saturn" thread for the info.
basically, I had little choice. not to mention my dad kept doubting my mechanical abilities, so what can you do.
Oh well, at least I didn't get taken to the cleaners (some of you might say I did anyway, but still) and they gave me a slick deal on it.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 05-25-2010, 08:04 PM   #63
SaturnNJeep
SaturnNJeep is on a distinguished road
SaturnNJeep's Avatar
LOL, you know the funny thing is, this Saturn was originally sold new at Saturn of VA Beach!!! It would be going back home!!
Anyway, found out the problem, there is no gasket for a '95 DOHC with the aluminum cam cover, just RTV!! What Advance sold me was for a DOHC with the plastic com cover, which I didn't think they had both in '95, I went to my local Napa to see if they had a different gasket, and they told me it takes the black RTV. Here's a pic of the finished product, and, yes, I'm keeping the Saturn, sorry,
Jerry
Add to SaturnNJeep's Reputation
Rate the quality of this post and help SaturnNJeep reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnNJeep is offline   Reply With Quote
Old 05-25-2010, 08:55 PM   #64
guy_450
guy_450 will become famous soon enough
guy_450's Avatar
2001 SW2
Jerry
Congrat, nice came cover
2000 SW2 5MT silver
2001 SW2 4AT silver (garaged)
2012 VOLT Electric instant torque & regen braking go so well together !!
Add to guy_450's Reputation
Rate the quality of this post and help guy_450 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
guy_450 is offline   Reply With Quote
Old 05-25-2010, 09:07 PM   #65
eRic 02sc2
eRic 02sc2's Avatar
today I replaced my engine coolant temperature sensor in my Saturn then slowly poured a 1/3 can of Sea Foam into the throttle body while the engine was running. I let it sit for 5 minutes then started it and drove around the block fogging mosquitoes.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 05-25-2010, 09:34 PM   #66
Merlin3
Merlin3 is on a distinguished road
New OEM O2 sensor and a rotate and balance on the tires.
Stuck a gauge on the A/C. Low/Low - High/High
2002 SC2 3 door 170,600 (05/2/11)
Add to Merlin3's Reputation
Rate the quality of this post and help Merlin3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Merlin3 is offline   Reply With Quote
Old 05-25-2010, 10:16 PM   #67
Low Saturn
Low Saturn's Avatar
2000 SC2
there is no gasket for a '95 DOHC with the aluminum cam cover, just RTV!!......
.....and they told me it takes the black RTV.
Sounds like they lied to you or dont know what they're talking about. Did you finally get the gasket or did you use RTV as the gasket? Using just RTV is OK if you plan on selling the car and know you'll never see it agian or to someone you have a deep hatred for.
I swear if I ever buy another S-Series where someone has used RTV instead of the proper gasket, I'll find the person who did the work and give them a sex change operation via my left foot.
Having to pry and beat an RTV's cover off = not fun
Having to use a wire brush wheel to get all the gobbed on RTV off the recess on the cover = not fun
Finding RTV boogers in the head, between the timing chain cover and block, in the oil pan, and clogging up the oil pick up tube because it oooozed out on installation = not fun.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 05-25-2010, 10:53 PM   #68
SaturnNJeep
I didn't like the idea either. This was what Felpro had listed on their list, and the gasket that was given to me wasn't going to cut it, it was made for a different cover, even though the outline matched perfectly. Believe me, I would rather have the gasket if I could get the correct one. Anyone know a good part number? Thanks!
Jerry
Old 05-25-2010, 10:57 PM   #69
Low Saturn
Low Saturn's Avatar
2000 SC2
Jerry
Felpro part #vs50451r
For the 1992-1995 DOHC aluminum valve covers.
http://www.autozone.com/autozone/cat...Text=vs50451r+
Sounds like they originally gave you the Felpro VS50454R for the 1996-1998 composite DOHC covers.
Mike
-2000 Saturn SC2
Old 05-26-2010, 08:47 AM   #70
Jerryy, might be my aged eyes, but why does it look like there's a straight line where your exhaust manifold is gray on the left (#1) and rusty on the right in the picture?
And it might be the angle, but I only see 2 of the timing cover to engine mount studs?
I still think you have a great looking car, even better with the red cam cover. I was contemplating painting mine when I had it off, but I was too lazy to really clean it off
Old 05-26-2010, 04:51 PM   #71
SaturnNJeep
Thanks, Low Saturn! You're a lifesaver!! You're right, that's what happened, I just found the Felpro box, and it clearly states "VS 50454 R" on the end. The RTV looks like it's sealing (for now), but, I'm going to go ahead and get the REAL Felpro gasket next week. Thanks again for the part number,
Jerry
Old 05-26-2010, 04:56 PM   #72
SaturnNJeep
Originally Posted by alordofchaos View Post
Jerry, might be my aged eyes, but why does it look like there's a straight line where your exhaust manifold is gray on the left (#1) and rusty on the right in the picture?
Not sure what exactly you're talking about. My eyes might be going too,
Your eyes are not playing tricks, I need to take care of that.
Thanks, like I said, it was more orange then I had wanted, but, it still looks better then the battle ship gray!!!
Jerry
Old 05-27-2010, 08:00 AM   #73
The section in the yellow area... looking a little closer, it looks like it might be some kind of heat shield?
I'm pretty sure I don't have one in my car (or I'm just not paying attention )
Old 05-27-2010, 10:57 AM   #74
blackeagle1
blackeagle1 is on a distinguished road
blackeagle1's Avatar
2000 SL2
That's the bracket that attaches the A/C compressor to the block. If you have A/C on your car, then you would have this also.
Current Fleet:
97 Black Gold SC2 Manual
97 Silver SC2 Auto
98 White SL2 Auto
00 Silver SL2 Auto
03 Pontiac Montana
00 Yamaha SUV1200 Waverunner
Add to blackeagle1's Reputation
Rate the quality of this post and help blackeagle1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blackeagle1 is offline   Reply With Quote
Old 05-27-2010, 12:52 PM   #75
KingRex
KingRex will become famous soon enoughKingRex will become famous soon enough
KingRex's Avatar
Checked my gas and filled the oil!
"The Homecoming King"
Saturns Saved: 18
Saturns Owned: 2
1999 SL2 HCE 175K
1994 SL2 HCE 135K
1999 SL2 Silver 125K
Add to KingRex's Reputation
Rate the quality of this post and help KingRex reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KingRex is offline   Reply With Quote
Old 05-27-2010, 04:20 PM   #76
SaturnNJeep
What he said, LOL!
Jerry
Old 05-28-2010, 08:17 AM   #77
Heh, never really paid attention to that AC bracket before.
Picture threw me off because it looked like part of the exhaust manifold was taped off and painted gray at first. then when I looked at it again, it looked like something that was molded and shaped right over the exhaust.
Thanks! (I went and looked closer at my engine last night, and yep, I have that there)
Old 05-28-2010, 07:49 PM   #78
saturnsctwo
spent most of the day claying my car, then coating it with liquid glass & rain-x on all glass surfaces. i'm burnt from the sun like hell! next thursday it goes in to ziebart for it's annual underbody inspection & re-spray of sound deadner...
Old 05-30-2010, 03:51 PM   #79
guy_450
guy_450's Avatar
2001 SW2
Put a new battery into my ex 1995 SW1,which I gave to my sister last year. She appreciates my after-sales service
New fuel filter & synthetic oil change for my SW2 last week
2000 SW2 5MT silver
Old 05-30-2010, 04:00 PM   #80
ruffiano
ruffiano is on a distinguished road
Washed and waxed! first time ever.. since I've owned it (about 5 days, haha).
But it was in desperate need of a wax job!! This NM sun was beating it up and now it looks great!
K&N filter later this week.. then I'm waiting for my 6.5" speakers to come in.
Add to ruffiano's Reputation
Rate the quality of this post and help ruffiano reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ruffiano is offline   Reply With Quote
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 03:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 07:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 01:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 07:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 08:03 PM
