Old 01-12-2020, 02:22 PM   #6421
454cid
Default Re: What did you do to your S-Series today...
Originally Posted by me.theuser View Post
I mean the metal plate under the balljoint where the zerk is mounted to.
Oh wow, so it's coming apart. That can't be good.
2000 SL2 Automatic 200,XXX miles.
1999 Chevy K3500
Old 01-13-2020, 01:24 PM   #6422
Highmile
Highmile's Avatar
ho hum... oil change, washer fluid top off, check all other fluids, check lights, vacuum floors, air up tires.
Highmile
'95 SL1 699k and counting
Old 01-17-2020, 12:08 PM   #6423
focusofheart
focusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nice
My long time mechanic came over to replace the original rear sway links and had me help him.
The NAPA replacement links were so much beefier and the car drives even better than after the front control arms and tie rods were replaced.
Now I get to look for something else to replace.
P.S. I sprayed the electrical connections to the horn 9 days ago with no results, so I ordered a new horn. I get into the car yesterday and the horn works. Explain that to me.
Saturn 1998 - SL2 automatic
Singer 1952 - 301A knee driven
Singer Serger 1985 - 14U64A & 14U34B
Old 01-17-2020, 12:52 PM   #6424
onlinebiker
It's like my ex brother in law.
It works when it feels like it....
Currently owned
93 SC2
96 SC2
97 SL2
98 SL2
99 SC2
01 SC2 auto
01 SC2 5 sp
02 SC2
02 SL2 auto
02 SL2 5 sp
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 01-17-2020, 02:03 PM   #6425
focusofheart
LOL!
At least I will now have a backup horn for when it actually decides to stop working altogether.
Old 01-18-2020, 12:17 PM   #6426
454cid
We got snow overnight, so when I went out to shovel my way to the car this morning, I sprayed the door seals with silicone.... the driver's side any way, front and back.
I wonder if the over spray will fade any plastic... I had some interior parts on my truck fade after I sprayed it. Must be something in this brand I bought. The Saturn is already faded in areas, so I'm not super worried about it.
I also checked the voltage at the battery when running and not..... 12.6v when not running, and 14.36v when running. Grounding at the head actually was higher than at the battery at 14.4v.
1999 Chevy K3500
Old 01-22-2020, 08:01 PM   #6427
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
I received some inner and outer tie rods, an inner tie rod end tool and a couple of Motorcraft filters from RockAuto last week.
Goggles Pisano is offline   Reply With Quote
Old 01-23-2020, 01:42 AM   #6428
me.theuser
me.theuser is on a distinguished road
2002 SL1
2001 SL2
What brand?
me.theuser is offline   Reply With Quote
Old 01-23-2020, 10:43 PM   #6429
38TransAM
38TransAM has a spectacular aura about38TransAM has a spectacular aura about38TransAM has a spectacular aura about
In last month:
One new fuel pump set up, went with the Delphi, 9 yr old assisted in the driveway, lucked out and had like a 50 deg. day.
#965 reman wiper motor? Lost track of how many I've swapped, Appears I got a good one this time. Next will be new now that they are available, but not of course when I actually need one to get the car back on the road in winter. 9 yr old also assited in the driveway, this time in the snow...............
Saturn OEM GM reman. engine NO LONGER AVAILABLE (SOLD OUT)
96 SL2 still kicking at 186k???(for sale, needs brake line)
99 HCE 63k Now at 97k and new GM reman engine, 132k
38TransAM is offline   Reply With Quote
Old 01-24-2020, 12:58 PM   #6430
Goggles Pisano
1999 SL1
What brand?
Old 01-24-2020, 06:41 PM   #6431
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
Picked up a leather wheel from a 96 this morning at the junkyard. Installed it this afternoon. Feels a lot nicer than the plastic one.
There was also a nice 2002 SL2 manual with a black interior I havenít seen before . They write the date and reason for junking on the side of the cars at this yard. Was just a brought in on the 21st and the reason was ďDriven inĒ. Wish I knew the story behind it.
File Type: jpg 336C1CFD-9AB3-402F-84F1-ACF807398B9F.jpg (112.8 KB, 16 views)
97 SL2, auto, 123K miles
Old 01-25-2020, 08:01 AM   #6432
dummo
dummo's Avatar
1997 SW2
Originally Posted by 38TransAM View Post
In last month:
Thatís one fortunate kid!
ē 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
ē 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
ē 1994 SL1 new traded
ē 1992 SL2 new traded for above
Old 01-29-2020, 03:26 PM   #6433
Zeebins
Zeebins's Avatar
Itís nice to be able to post here again. I had my doubts about it coming back but Iím glad I was wrong.
Iíve been slowly converting the bulbs to LED when I feel like putting money into in. All the rear bulbs have been converted as well as the front side markers, PRND32 light, and the cup holders. Today I decided to do the HVAC bulbs. I took the whole thing out of the car to make working with it easier. When I looking at it inside I discovered that there was a 3rd bulb hole molded into the plastic that is unused. I have a second HVAC unit from a 99 and that one has it too.
I was curious how much it would actually light up with a bulb in it and the answer to that is not very much.
Bulb only in right
Bulb only in left
Bulb only in center
I think itís kinda weird that Saturn molded a bulb hole just for it to go unused but I had one theory and my dad had another. Mine was that they thought they originally thought they would need more light than just 2 bulbs but 2 ended up being fine. My dad thinks they had originally designed a different faceplate that would have needed all 3 bulbs, but ended up using the one we have now instead that only needed 2.
No one probably really cares about an unused bulb hole but I thought it was kinda interesting, lol.
Old 01-29-2020, 04:53 PM   #6434
alakai66
alakai66 will become famous soon enough
alakai66's Avatar
Thumbs Up Re: What did you do to your S-Series today...
Changed all the mounts, tensioner pulley, knock sensor, and valve body electrical connector gasket.
Next project: Front and rear suspension (still good but going out slowly), JBL concert speakers to replace the stock ones, maybe brakes?
"I find your lack of faith...disturbing!" - Darth Vader *Probably*
alakai66 is offline   Reply With Quote
Old 01-29-2020, 07:30 PM   #6435
silentdude56k
silentdude56k is on a distinguished road
1994 SW2
In early December on the way to work one day, every single gear shift resulted in a violent slam. There were no apparent problems the day before. Forward and reverse. Once in gear the car drove just fine, so I dropped it down to 2nd for one last slam before turning around and limping it home.
I suspected it was the line pressure solenoid in the valve body, and sure enough a resistance test at the connector on the top showed it was wildly out of spec. I popped the valve body open and tested the solenoid directly. This time it read fine. I decided to pull it out and test it again: out of spec, but a different value than before. It turned out the connection between the leads and the coil was sketchy and the ohm reading would change depending on how much pressure I put on the leads. The bad solenoid was also the odd one out - it was definitely a different design from the others. It must have been a replacement since I got this valve body from Special Forces several years ago. I ended up replacing all of the solenoids with the ones from another valve body I have sitting around since they all measured almost exactly the same. I swear the transmission is shifting smoother than it ever has before, but it could be just the placebo effect.
A couple of weekends ago I changed my oil with the AmazonBasics 5W-30 full synthetic instead of my usual Chevron 5W-30 conventional from Costco. I'll be keeping a close eye on the oil burn rate (~1200 mi/qt), but so far so good.
Purple 1994 SW2 auto. 324k+ miles. Head gasket replaced due to an overheat at ~261k. Timing chain replaced before putting the engine back together.
silentdude56k is offline   Reply With Quote
Old 01-31-2020, 12:51 PM   #6436
Neat! Like when I found the CAT OVER TEMP warning light socket on teh back of my '98
http://www.saturnfans.com/forums/sho...d.php?t=154888
Or KingRex finding a "LOW TIRE PRESS" in his 95
From your fellow bulb nerds
Old 02-08-2020, 10:49 PM   #6437
454cid
Finally changed the oil and installed the new GM plug.... I used Supertech synthetic this time.
I have a Fram synthetic filter, but used a cheap Champion Labs filter since I plan to change the oil again when it gets warm.
1999 Chevy K3500
Old 02-10-2020, 11:30 AM   #6438
Waiex191
Waiex191's Avatar
Yesterday my kid rolled this:
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 02-10-2020, 12:56 PM   #6439
bumpdraft
bumpdraft's Avatar
1998 SW2
Bought two new Blizak tires in the wider 195 width so that I can run front tire pressure closer to the Saturn factory door sticker recommend pressure.
I supplied new ebay steel wheels
After the tires were mounted, I noticed one wheel had a lump It never occurred to me that a new wheel could be bent
So, I bought another ebay steel wheel from the same people and I will keep the bent one for a spare. Maybe all it needs is a 5-pound sledge hammer.
Old 02-13-2020, 08:02 PM   #6440
focusofheart
I've been having my car vinyl wrapped, piece by piece and I was finally able to get the driver side doors and all handles done. It took a little over 4 hours just to do those doors due to the prep work the technician did. Hopefully I am able to get the passenger side doors done in a couple weeks.
The bumpers, rain gutters and top of the spoiler will be the last to complete.
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
