Old 05-07-2010, 06:30 PM   #1
jcardzcollects
jcardzcollects is on a distinguished road
Default SL2 Transmissin jumps in & out of gear
I have a 94 Saturn SL2 with automatic transmission and recently it has been jumping out of gear while driving then clunks back into gear, it happens at all speeds but mainly over 20 mph. then sometimes it stops happening? You feel it jump out, the rpms go way up then it jumps back into gear with a clunk, Does this mean my transmission is shot? or maybe the valve body?
I changed the transmission fluid and filter about 1 1/2 years ago, any help would be appreciated
Add to jcardzcollects's Reputation
Rate the quality of this post and help jcardzcollects reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jcardzcollects is offline   Reply With Quote
Old 05-08-2010, 07:43 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: SL2 Transmissin jumps in & out of gear
1) check your battery terminals for corrosion
2) check said battery terminals for these voltages:
* ~12.5v with the engine off
* ~14.4v with the engine, heater, and headlights on
3) you may also need to replace the input/output shaft nuts. instructions in the how-to library (HINT: DON'T bend the pipes on the bottom cover of the transaxle, or else you'll lose some gears).
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 05-08-2010, 07:45 PM   #3
westtntrucker
westtntrucker is on a distinguished road
2001 SL2
Low trans fluid maybe?
Add to westtntrucker's Reputation
Rate the quality of this post and help westtntrucker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
westtntrucker is offline   Reply With Quote
Tach jumps John T S-Series Tech 6 05-30-2008 06:10 AM
Transmission Jumps imahackster Outlook General 4 01-18-2008 02:49 PM
92 SL auto. jumps from 4th to 2nd matthewwp S-Series General 0 04-02-2006 08:35 PM
RPM jumps while braking on 00 SL2 smurf115 S-Series Tech 5 03-22-2005 03:43 PM
Transmissin no shift? moocow212559 S-Series General 0 06-22-2004 11:07 PM
