Old 05-02-2010, 08:00 PM   #1
SaturnSL2Guy
SaturnSL2Guy is on a distinguished road
SaturnSL2Guy's Avatar
2002 SL1
Default Coolant issue
Hey guys, I am wondering if I can get some help with my coolant issues. It's starting to get warm here in New England and I have been having some cooling issues with my car. During normal driving, my temp gauge hovers a little above 1/4. Thats fine, and usually, it won't go past that. However, lately, if I get stuck at a long red light, the temp of the car jumps way up past halfway, sometimes almost 3/4 within a minute of me being stopped. It cools down as I start driving again, and does it again if I sit for more than a minute or two. I tested the fan, I know it works, but I have a hunch the relay or my thermostat is bad. I am just curious as to why my fan isn't coming on sooner? At what point on the gauge does the fan typically turn on? I have a good coolant level, and everything seems ok, so why is it heating up so fast? It hasn't even broke 75 degrees yet? thanks for the help!
SaturnSL2Guy is offline   Reply With Quote
Old 05-02-2010, 08:02 PM   #2
SaturnSL2Guy
2002 SL1
Default Re: Coolant issue
I should also add that I have gotten no coolant light or engine light on the dash. Do I have a thermostat/fan relay issue, or do they usually run this hot?
Old 05-02-2010, 08:29 PM   #3
If you haven't already, replace your ECTS - engine coolant temperature sensor. Visit our How-To Library and check the "sticky" threads on this sensor, along with links to videos by member richpin06. Otherwise, as long as the fan comes on before the gauge reaches the red zone, and this brings the temperature down, the car is not overheating.
Old 05-02-2010, 08:53 PM   #4
SaturnSL2Guy
2002 SL1
Thanks. I replaced the ECTS about three months ago when it started messing with my idle. I know it's not overheating, it just seems unusual for it to heat up that much in a short period of time
Old 05-03-2010, 02:48 PM   #5
DonP
There is not a lot of coolant in the system, does not take long to heat up from normal operating temperature when stopped or moving very slowly (e.g., below 25 mph) thanks to reduced air flow through the radiator.
If the temp gauge is holding at/below 1/4 scale on the open road (and the ECTS is OK) you may have a stuck open t-stat. It normally should sit at about 3/8 scale.
Old 05-04-2010, 01:28 AM   #6
mjoekingz28
mjoekingz28 is on a distinguished road
Ask Wolfman about his manual radiator fan switch if it bothers you looking at the needle rise.
For me, I just switch on the AC.
mjoekingz28 is offline   Reply With Quote
Old 05-04-2010, 06:34 PM   #7
megaman8x
megaman8x is on a distinguished road
I am having the same problem with my sc2 where it would heat up at idle first i changed the ECTS and then the radiator cap then the next week i noticed my raditor was streaming huge amounts of fluid on the driver side, I would suggest getting your raditor checked...
megaman8x is offline   Reply With Quote
Old 05-17-2010, 07:48 PM   #8
srigg
srigg is on a distinguished road
I thought I had a problem when I first noticed the guadge going up to 2/3 when I idled for 2 or 3 minutes but I only heard the fan after climbing a 5 mile long hill on a 100 degree day so I think the the behavior I described is normal.
srigg is offline   Reply With Quote
REALLY frustrating coolant issue aimeesnyder Ion Tech 5 03-03-2010 06:34 PM
Coolant Issue deacon20 S-Series Tech 5 02-20-2010 02:06 AM
Coolant issue tempomental S-Series Tech 26 02-12-2010 05:13 PM
Another Coolant Issue Matt4572 S-Series Tech 2 12-30-2009 04:18 PM
Coolant Issue w/L300 Shadowless L-Series General 1 03-09-2007 06:25 PM
