Old 05-02-2010, 08:37 AM   #1
nbkyqks
nbkyqks is on a distinguished road
Devil 1996 Saturn Sl2 strange response to pressing the gas pedal
Thanks in advance!
Two issues that may or may not be related:
1) After driving for 3 or 4 miles, The Service Engine Light came on and I felt a distinct fluttering in the response of the car...while keeping the gas pedal at the same point. Felt like I was running out of gas...unfortunately I know what that feels like from the past in other cars...never ran out of gas in this car though.
This has happened to me alot lately, so I knew what was going to happen next...when I approach a stop light and am downshifting, the car is likely to stall out unless I throw it in neutral coasting in AND punch the gas. Once I do that, the car will idle fine for a while...but this will happen again shortly.
2) This problem went away but is back...From first gear to second up to 3K RPM...fine, Second gear to third fine, third to forth fine most of the time but if I'm pulling a hill I notice the RMP increasing fast (starting at around 2500), but not getting the response I would expect...bascially the car stays at the same speed while the RPMs are dramatically increasing...forth to fifth (especially on a hill) I almost always notice this dramatic increase in RPM's with no change in the power of the car. I expect to feel an acceleration when the RPMs increase this much.
Add to nbkyqks's Reputation
Rate the quality of this post and help nbkyqks reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nbkyqks is offline   Reply With Quote
Old 05-02-2010, 09:49 AM   #2
bluesl2
bluesl2 is a jewel in the roughbluesl2 is a jewel in the roughbluesl2 is a jewel in the rough
bluesl2's Avatar
Default Re: 1996 Saturn Sl2 strange response to pressing the gas pedal
The ses light and driveability problem sounds like it may be an egr problem but get the code read first.
Add to bluesl2's Reputation
Old 05-02-2010, 10:36 AM   #3
nbkyqks
I appreciate your response...I got the SES code from Advance Auto Parts...1406.
Does that tell you anything?
Old 05-02-2010, 02:52 PM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC1
year/model/trans type?
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 05-02-2010, 06:35 PM   #5
nbkyqks
1996 SL2...5 speed
Old 05-03-2010, 08:02 AM   #6
flyhop
flyhop is on a distinguished road
2000 SL2
P1406 EGR Valve Pintle Position Circuit - Read Our Article on EGR Valve Codes For Help With This Saturn Check Engine Light Code
from this site: http://www.engine-light-help.com/sat...ine-light.html
Use search engine in here for how-tos (i.e. How-To Library) on EGR cleaning.
Add to flyhop's Reputation
Rate the quality of this post and help flyhop reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
flyhop is offline   Reply With Quote
Old 05-03-2010, 05:24 PM   #7
bluesl2
bluesl2's Avatar
And if that don't work, change the egr valve.
Old 05-03-2010, 05:37 PM   #8
flyhop
2000 SL2
Before going to the expense of a new EGR valve, try this first.
Given you got the error code, I'd try cleaning our your EGR first. Put it back on, clear the codes, and go for a drive. Better? Then, problem solved. No better? Try blocking it off per Richpin's video. In essence, you block off the EGR valve ports, and then drive it. If the problem goes away, it's your EGR valve.
Rich's video is here. http://www.youtube.com/watch?v=8YRq2...e=channel_page
Let us know how things work out. If you have to get a new one and money's tight, try pulling one off a similar Saturn at a boneyard.
Old 04-27-2012, 12:29 PM   #9
ishekhar
ishekhar is on a distinguished road
I had a similiar pattern (hesitant start, typically takes 2-3 attempt to start the car) and the car runs heavy and the error code flashed p1406.
Tried cleaning the EGR value but no luck.
Put in a brand new EGR value but still no luck.
any idea what could go wrong ? Since the EGR valve is now brand new, that would make some other problem, right ? Why this P1406 code then ?
thx,
Add to ishekhar's Reputation
Rate the quality of this post and help ishekhar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ishekhar is offline   Reply With Quote
Old 04-27-2012, 01:14 PM   #10
GeeWiggles
GeeWiggles is on a distinguished road
GeeWiggles's Avatar
thx,
sounds like you have a connection issue. Try taking the connector off and spraying some electrical cleaner inside and dangle it down, letting it dry completely. Inspect the connection on the EGR for any residual corrosion too as it might have gotten on the terminals. I had this code a few weeks back after I removed and cleaned my EGR and found that some corrosion had come loose when I removed the connector. After cleaning it out code went away and hasn't come back.
IF this doesn't work I'd be checking your connector and the wires leading from it for shorts. It's rare, but possible.
Add to GeeWiggles's Reputation
Rate the quality of this post and help GeeWiggles reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GeeWiggles is offline   Reply With Quote
Old 04-27-2012, 03:46 PM   #11
jhall02sc2
jhall02sc2 is on a distinguished road
jhall02sc2's Avatar
Would these cars be able to run right with egr blocked off and not plugged in?
Add to jhall02sc2's Reputation
Rate the quality of this post and help jhall02sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhall02sc2 is offline   Reply With Quote
Old 04-27-2012, 04:13 PM   #12
Tofutti
Tofutti is on a distinguished road
1999 SC1
Originally Posted by nbkyqks View Post
Thanks in advance!
Does this sound to anybody else like a slipping clutch or other hydraulic problem? If the RPM's are spiking/increasing without a change of vehicle speed... Especially noticeable in higher gears and/or under higher load...
Just my two cents. I'm probably missing something if nobody else has mentioned it thus far.
Add to Tofutti's Reputation
Rate the quality of this post and help Tofutti reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tofutti is offline   Reply With Quote
Old 04-27-2012, 04:18 PM   #13
GeeWiggles
GeeWiggles's Avatar
Good point, if the engine is revving up and the car isn't accelerating, then there is a power transfer problem. This car ever had a new clutch installed?
Car stalled and dies when pressing on gas pedal snostorm S-Series Tech 20 01-11-2008 09:25 AM
1996 SC2 O2 Slow Response After Clutch Change kelley_foust S-Series Tech 1 10-07-2006 03:35 PM
Response from Saturn Corp. about SKY concept (Please Read) Saturn94SL2 Sky General 10 07-30-2002 02:58 PM
Brake pedal making a strange noise... erick295 General Saturn Discussion 4 01-30-2002 04:32 PM
