Old 04-30-2010, 12:17 AM   #1
OUman63
OUman63 is on a distinguished road
1998 SC1
Default 98 SC1 transmission
Hello all!
I was driving on the interstate two days ago, stepped on the gas to get around a car, and then heard a loud bang and a lot of grinding. Pulled over and all of my transmission fluid was leaking out of a 2-inch hole in the pan. It rolled downhill in park.
I towed it to a shop nearby and they told me something about a third something or other was missing and that the transmission would have to be replaced. They found a used tranny with 89k miles for $680 and they want $800 to install it.
The car itself has 110k miles, 1.9L SOHC, idles smoothly, doesn't have any unusual noises or any other problems except for an exhaust leak in the flange behind the cat. I'm looking for some opinions to see if it's worth the repair or not. What do you guys think?
Add to OUman63's Reputation
Rate the quality of this post and help OUman63 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OUman63 is offline   Reply With Quote
Old 04-30-2010, 01:48 AM   #2
Default Re: 98 SC1 transmission
That wasn't the pan; there isn't one. That was the case that broke. A pin worked loose in the differential and centrifugally shot through your tranny. Do a search here on "diff pin" for similar horror stories. It's typically caused by spinning the front tires (burnouts, spinning on snow/ice) followed by abrupt regaining of traction, but on a few occasions, folks who have never done anything like this report throwing the diff pin.
A used tranny shouldn't cost more than $200-300. Not sure about the labor, but that number seems high. If it totals out at more than $1000, you're likely better off buying another Saturn and keeping this one as a parts donor.
Add to madpogue's Reputation
How to change transmission fluid in VUE with manual transmission David 93 SL2m Vue Tech 35 06-30-2017 06:47 PM
rebuild mp7 transmission, Saturn TAAT transmission, Locks up in reverse, help mordo2 S-Series Tech 5 05-23-2016 08:28 AM
Transmission cooler/radiator replacement when transmission is bad? infinitewisdumb S-Series Tech 2 04-16-2010 08:59 AM
122,000 miles on transmission with no transmission fluid change in car's history. foo General Saturn Discussion 10 04-22-2008 05:04 PM
'95 Transmission Operation Debrief: Transmission stuck in 2nd gear rc1488 S-Series General 0 01-12-2008 12:28 AM
