Old 04-24-2010, 02:34 PM   #1
rjuza333
rjuza333 will become famous soon enough
Default 2000 Saturn L200, check engine light on
I have a 2000 Saturn L200 that I posted about a few months ago. The car wasn't running right and would shudder at idle between 800-1000rpm. The check engine light came on and sent a PO340/341 OBD code to the computer (camshaft sensor/engine misfire). Turns out the coil pack was bad so I replaced it and the shudder went away and the check engine light went off. I also replaced the plugs and boots at the same time. A few days later the light came on again but the car still ran fine. I took it to the parts store and hooked it up to the reader and it again gave a PO340 code. I exchanged the coil pack because it was under warranty but the light stayed on. I've been driving it like this because the car runs fine and I still get 28-30mpg so I don't think it's anything serious. I've also noticed that the light doesn't always come on and will sometimes stay off for a few days. The car doesn't run any different during these periods. Any ideas what this could be? Any help is appreciated, thanks in advance.
Add to rjuza333's Reputation
Rate the quality of this post and help rjuza333 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rjuza333 is offline   Reply With Quote
Old 04-24-2010, 09:21 PM   #2
Ex-GMtech
Ex-GMtech has a spectacular aura aboutEx-GMtech has a spectacular aura aboutEx-GMtech has a spectacular aura about
2000 L-Series 3.0L Wagon
Default Re: 2000 Saturn L200, check engine light on
I would suspect a possible bad cam position sensor. However, it could be it, the wiring, or the PCM itself.
OMG this car is easy to work on!
2000 LW2
2016 Impala
1986 GLHS
Add to Ex-GMtech's Reputation
Rate the quality of this post and help Ex-GMtech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ex-GMtech is offline   Reply With Quote
Old 04-25-2010, 10:39 AM   #3
KLS1P
KLS1P is on a distinguished road
2004 L-Series 3.0L Sedan
Have you replaced the camshaft position sensor?
Add to KLS1P's Reputation
Rate the quality of this post and help KLS1P reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KLS1P is offline   Reply With Quote
Old 04-25-2010, 12:24 PM   #4
A recent check doesn't show a camshaft sensor for the 2.2L 4cyl engine. The 3.0L V6 engine uses a crankshaft and camshaft position sensor.
Old 04-25-2010, 01:41 PM   #5
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
But could this be a crankshaft position sensor on the way out?
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-25-2010, 02:24 PM   #6
IMO, no. The engine runs. Period. Virtually every cps failure occurs with engine heat; the typical car drives fine then dies until some time passes, mostly for engine cool down, allowing a restart as if nothing happened. As this occurs more frequently, a post pops up.
Old 04-25-2010, 04:01 PM   #7
KLS1P
The OP stated p0340 / p0341 codes that point to the camshaft sensor. What engine does the OP have? No camshaft sensors on the ecotec 2.2l. Are we to assume it's a 6 cylinder or did the parts store code reader give a false reading, this happens often for the p0340 code. If it is the 2.2l I would ignore this erroneous code or hook it up to the GM Scantool.
Old 04-25-2010, 04:29 PM   #8
Well, I checked his previous posts and he has the L200, 2.2L engine. I can be wrong though........................
Old 04-25-2010, 06:22 PM   #9
Ex-GMtech
Oops. I really thought they had a cam sensor.
2000 LW2
2016 Impala
1986 GLHS
Old 04-25-2010, 06:58 PM   #10
rjuza333
It is the 2.2L engine and you're right the car doesn't have a cam/crank position sensor so it's not that. The only code I get now when I hook it up is PO340, so the PO341 must be cleared and it doesn't feel like it's misfiring anymore anyway.
I wonder if it is a false code because it does disappear intermittently. I'm at a loss. Could this be a different sensor gone bad?
Thanks
Also, it seems like if the car sits for a few days the check engine light stays off for a while when I drive it again.
Old 04-25-2010, 07:30 PM   #11
Consider the parts replaced to get the engine to run; ignition module and ignition coil pack. You had trouble in the past and it may be repeating again. The best you can do is to ensure electrical connectivity; clean electrical connections to both modules and some dielectric grease on the plug boots that connect the ignition coil pack to the plugs. Look over the wiring harness' for any possibility of a wiring break from chafing against metal, stretching from incorrect harness routing, etc..
Old 04-26-2010, 09:22 PM   #12
born again
It couldn't hurt to put in new spark plugs, if this hasn't been done since the new coil pack was installed.
2004 Saturn ION 'Check Engine Light' JunkYardSaint Ion General 15 12-12-2015 02:06 PM
L200 Check Engine Light Stylesguy469 L-Series Tech 2 11-30-2009 05:06 PM
2007 Saturn Ion Check Engine Light BuckyBadger Ion Tech 6 04-05-2008 03:38 PM
199 saturn check engine light nuwt S-Series General 4 11-02-2005 09:09 PM
Saturn SC2 2001 clicking noises / check engine light SaturnSC2_01 S-Series General 16 02-13-2005 07:55 PM
