#1 | |||||
![]() Join Date: Jun 2008
2008 VUE 2.4L
![]() Can anyone provide insight to where the three additional screws are located (in step 3)?
#2 | ||||
2008 VUE 2.4L
![]() Nevermind. I think I got it, I misread the directions and didn't realize they mentioned the two screws for the front fascia, before the screws for the headlamps.
#3 | ||||
![]() Join Date: Jul 2010
![]() I see the two screws (bigger ones) on the fascia and removed those, then the two on the headlamp assembly. But still no luck? What am I missing? Does anyone have a picture of this headlamp.
I uploaded two pics, marking in "Red" what I thought the fascia screws are.
#4 | |||||
2008 VUE 2.4L
![]() Quote:
Once I figure it out, I will post pics. (I've been able to delay the install until now, but am forced to figure it out since the driver's side low-beam is now out).
#5 | ||||
2008 VUE 2.4L
![]() Ok.. the catch is you have to remove all of the small retainer screws (unscrew the center to remove the screw, and then pull the clip out to avoid losing it when bending the "grill") on the plastic "grill" between the two headlights. Note, that you cannot remove the two "larger" retainer screws that attach to the bumper (trust me, I tried, and wound up breaking them slightly). From there, remove the two bolts on the top of each headlight, and the one that is located on the corner bracket facing inward towards the "grill". To remove each headlight housing, you will need to pull/pry the "grill" towards you as far as you can bend it w/o breaking. This has to do with the fact that the corner bracket on each of the headlights is lower than the "grill". You will need to wiggle the housings to ease them out, and bring the corner brackets over the "grill". However, but be very careful not to break one of the top brackets when attempting to manipulate the housing over the "grill".
Once off, there are caps on the back of each headlight. Twist to take the off, and do the same to remove the bulbs, once visible. Perform the reverse of the steps to complete.
#6 | ||||
![]() Join Date: Oct 2010
2008 VUE 2.4L
![]() If you have any photos of the last steps I would greatly appreciate them. I am trying to replace both lights due to passenger side burning out. Thanks in advance.
#7 | |||||
![]() Join Date: Apr 2010
![]() Quote:
2008 Vue Door Panel Removal | jpak24 | 2008 Vue | 1 | 05-17-2008 07:02 PM |
1997 sc1,headlamp houseing removal,,,anybody know? heres a pic! | maestro | S-Series Tech | 4 | 07-27-2007 07:25 AM |
HeadLamp removal for new Bulbs | Mr X | Vue General | 2 | 10-04-2003 08:02 PM |
Headlamp Help | IONicSaturn | S-Series Tech | 2 | 06-12-2003 11:26 AM |
headlamp removal | Space-Boy '97SL2m | Miscellaneous Tech | 1 | 09-18-2000 08:28 PM |
