Old 04-17-2010, 02:57 PM   #1
kfo3141
kfo3141 is on a distinguished road
Default 2000 SL2 Timing Chain/Belt
Hello,
I've got a 2000 Saturn sl2. It is approaching 100,000 miles. I've been reading about timing chains/belts with with this model. It wasn't quite clear if it has a chain or a belt.
It sounded like if it has a chain it does not need to be changed at 100,000 miles. But if it has a belt it does need to be changed at about 100,000 miles.
Is this correct?
I previously has a 1993 sc2 and never changed the belt at 100,000...I had it until about 130,000 miles.
Thanks
kfo
Add to kfo3141's Reputation
Rate the quality of this post and help kfo3141 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kfo3141 is offline   Reply With Quote
Old 04-17-2010, 03:28 PM   #2
mr18436572
mr18436572 is on a distinguished road
2000 SL2
Default Re: 2000 SL2 Timing Chain/Belt
S cars have chains that should last the life of the engine
2000 SL2 auto - 167k - sold
1996 SL2 auto - 161k - sold
1997 SC2 auto - 105k - sold
2000 SC2 auto - 117k - sold
1996 SL2 auto - 250k - sold
2001 SC2 5sp - 160k - sold
Add to mr18436572's Reputation
Rate the quality of this post and help mr18436572 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mr18436572 is offline   Reply With Quote
Old 04-17-2010, 03:51 PM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
Just to add. It should last the life of the car as long as the oil was regularly changed every 3000-5000 miles and not let to run low.
If you cant say that it has for certain, then pretty soon is the time to start listening for odd tapping noises coming from under the left side of the valve cover.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 04-17-2010, 06:26 PM   #4
You didn't change the belt because it didn't have one. The engine in your 2000 car is nearly the same as the one in your old car.
Add to madpogue's Reputation
Old 04-17-2010, 06:49 PM   #5
kfo3141
Thanks for the info everyone...oil has been changed every 3000-5000 so hopefully won't have any issues coming up.
Is there a reason more cars use belts rather than chains? It seem to me it would be a hel1 of a lot easier to not worry about changing a timing belt at ~100,000 miles.
What other cars other than Saturns use chains as opposed to belts? Might help with whatever my next car purchase is...although I think my 2000 sl2 still has a lot of life left.
My mom has an ion but only about 20,000 miles on it. Is that a chain or a belt?
Thanks!
Old 04-17-2010, 07:52 PM   #6
The belt is cheaper initially. Belt replacement, although it can be done by an independent mechanic or (in most cases) by the owner in the driveway, is a potential revenue source for dealership service departments. And finally, engine failure from neglecting a belt replacement and allowing it to break sells more new cars.
Well, belt-timed engines do tend to be quieter.
Engines with pushrods (camshaft in the block) use very short timing chains, and in some cases gears. With cars with OHC engines, there's no "rhyme or reason"; IIRC there are even some cars with some available engines that are chain-timed and others that are belt-timed. Most notably, most small Hondas have belt-timed engines, and the timing belt also drives the water pump. So a timing belt replacement usually includes a prophylactic water pump replacement ("while we're in there"), making for a particularly expensive service.
Old 04-17-2010, 07:55 PM   #7
mr18436572
2000 SL2
My Toyota uses a chain. I try and stay away from cars with belts.
Old 04-18-2010, 02:14 PM   #8
adventureoflink
adventureoflink's Avatar
+1. XRL and myself recently had a small dicussion about chains vs. belts, and it's usually about trading in the car once it's time for a new belt.
also madpogue, don't you also have to change the tensioner as well since it's also "mission critical" and "while we're in there"?
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 04-18-2010, 08:50 PM   #9
Probably, on those cars so designed. Of all the 1.7L Omnis/Turismos/etc. I had, and the '89 Colt, none of them had tensioners. The 1.7s had an intermediate shaft/pulley that ran the oil pump and distributor, and IIRC, the Colt had an idler, but neither were adjustable. You just slipped the belt in place over the notched pulleys, making sure everything was lined up.
Old 04-18-2010, 11:40 PM   #10
SLCraig
Lots of cars use chains... And they are oh so much better.
My Nissan is chain, and because its a V6 with DOHC heads, it has a primary and secondary chain setup (3 chains total)
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-19-2010, 08:21 AM   #11
DonP
Is that engine dripping on someone's kitchen floor? I ask based on the sheet vinyl and carpet visible in the background.
Add to DonP's Reputation
Old 04-19-2010, 06:20 PM   #12
SLCraig
Haha, it looks like there is a catch pan below it, from my perspective
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
98 SL2 - Timing Chain or Belt? wscreate S-Series Tech 4 11-21-2009 07:25 AM
Timing Belt or Chain unit731 Ion Tech 6 03-07-2009 12:43 AM
Timing belt/chain? crystalmyth Ion Tech 10 01-08-2008 01:02 PM
Timing belt or chain?? Help! 01 hawk Vue General 8 05-09-2007 12:24 AM
Timing Belt or Chain warren38 Vue General 32 03-20-2004 05:25 PM
