Old 04-16-2010, 08:09 PM   #1
SC2zippo's
SC2zippo's is on a distinguished road
Dizzy odometer stopped working
i just a 1993 sc2 .the guy said the fuel gauge was outta wack and the odometer stopped working well i fixed the fuel gauge by buying a new cluster ,but the odometer is still not working, any idea what sensor is for the odometer ? i know it's gotta be some speed sensor on the wheel or on the tranny just need to know where it is or maybe a wiring on it would help too.
Add to SC2zippo's's Reputation
Rate the quality of this post and help SC2zippo's reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SC2zippo's is offline   Reply With Quote
Old 04-16-2010, 11:12 PM   #2
Default Re: odometer stopped working
The VSS is on the transmission. It sends a signal to the PCM, which in turn sends a signal to the cluster. But it's only one signal in each case. So if the speedometer works, then everything is good up to the cluster. Most common cause of an inop odometer with a working speedometer is a broken odometer gear. Check http://www.odometergears.com .
Add to madpogue's Reputation
Old 05-11-2010, 06:51 AM   #3
brico
brico is on a distinguished road
1993 SL2
Not to hi-jack this thread but my odometer stopped working yesterday - right after I zero'ed out the trip mileage after filling it up. The speedomoter, tach, fuel, and temp guages all work but neither mileage odo's work.
Am I correct to assume that the gears in the mileage odo's are damaged (most likely from the zero'ing out) and that new gears are required? (see link in previous post).
Is there a DIY for this somewhere? I need to replace the dash cluster bulbs anyway some I'm going to have to pull the cluster.
The car is a 1993 SL2.
Regards,
Brian
Add to brico's Reputation
Rate the quality of this post and help brico reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brico is offline   Reply With Quote
Old 05-11-2010, 06:57 AM   #4
brico
1993 SL2
Replying to myself - the site above www.odometergears.com has instructions on how to remove and disassemble the cluster to get to the gears. The link for this is located in the top left corner of their webpage once you've selected the Saturn model. Looks fairly compete.
Any other tips would be appreciated!
Brian
Old 05-11-2010, 08:51 AM   #5
2NDSOUT
2NDSOUT is a jewel in the rough2NDSOUT is a jewel in the rough2NDSOUT is a jewel in the rough2NDSOUT is a jewel in the rough
2NDSOUT's Avatar
1999 SL
Brian
You can thank me for the writeup. Odometer Gears gleaned the posts that I wrote for removing the Instrument Cluster from the Saturnfans website in August and December 2007. Now, my step by step has been featured in ebay ads for the Odometer Gear.
Where's my compensation
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 05-11-2010, 09:11 AM   #6
JCSC2
JCSC2 is on a distinguished road
JCSC2's Avatar
Regards,
Brian
Yup, mine quit a few months ago when I resit the trip odometer too.
1994 Saturn SC2 114,000
1985 MB 300SD 202,000
2000 Mazda 626 90,000
Add to JCSC2's Reputation
Rate the quality of this post and help JCSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JCSC2 is offline   Reply With Quote
Old 07-02-2010, 11:29 PM   #7
DG3
DG3 is on a distinguished road
DG3's Avatar
Sadly, mine did the same thing today. Right after I zeroed the trip odo as well. I just bought the car this morning.
Add to DG3's Reputation
Rate the quality of this post and help DG3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DG3 is offline   Reply With Quote
Old 07-02-2010, 11:33 PM   #8
DG3
DG3's Avatar
Originally Posted by 2NDSOUT View Post
You can thank me for the writeup. Odometer Gears gleaned the posts that I wrote.
That sucks. I guess posts can't be copyrighted, unless they're on your own blog?
Old 07-03-2010, 12:44 AM   #9
DG3
DG3's Avatar
Or actually, maybe I didn't see the odometer because it was dark later in the day. So I'm sure the bulb was out when I bought it this morning, I just didn't notice because I could see the LCD readout during the day.
Old 07-03-2010, 09:21 AM   #10
bttwracing
bttwracing is on a distinguished road
bttwracing's Avatar
i pickup my odometer gears from them to put ine and all myself very easy job actually any caveman could do it lol
86 T-TYPE
1.59 60 ft. on m/t street radials. 12.44@101 mph,letting off 3/4 track
93 saturn sl2 230k miles
MYSITE http://bttwracing.shutterfly.com/?role=-1
Add to bttwracing's Reputation
Rate the quality of this post and help bttwracing reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bttwracing is offline   Reply With Quote
My odometer stopped working. :( 1994Saturn S-Series Tech 5 11-07-2008 06:32 PM
94 sc1 odometer stopped working gman41 S-Series Tech 2 07-26-2007 05:12 AM
Odometer stopped working Rapsack S-Series Tech 2 09-07-2006 01:40 PM
Odometer Stopped working! knyks342 S-Series General 4 02-25-2006 09:26 PM
91 SL2 odometer stopped working... Dach S-Series Tech 3 04-01-2002 08:31 AM
