Old 04-15-2010, 10:50 PM   #1
walboy
walboy is on a distinguished road
2002 VUE 3.0L
Default Saturn Vue AWD v6 - door problems..really need help
I posted this before. I really need help. My front passenger door will not open. I started having problems with door opening a few weeks ago. you would have to slightly press the unlock button while someone pulled the handle. it would open if u did this. I need to know how to get the door open so I can assess whats wrong. Are there any tricks to get the door open? I really need someones help. I just had to drop about $1200 on other problems and must fix this one myself. Any help would be appreciated. Thanks.
Add to walboy's Reputation
Rate the quality of this post and help walboy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
walboy is offline   Reply With Quote
Old 04-16-2010, 09:05 AM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Saturn Vue AWD v6 - door problems..really need help
walboy ... I've noted a few posts on this forum with stuck doors and don't recall (nor could I search and find) an easy solution. We know people eventually get the door open but no one appears to post how.
You may have to resort to brute force to remove the inner panel. There are several screws retaining the panel but I don't know how many are accessible with door closed and pax seat in place.
I'll attach a few service manual extracts which supposedly pertain to the 03.
I'll provide any other document which you think will help you.
Good luck.
Old 04-16-2010, 09:22 AM   #3
SoundGuy
SoundGuy is on a distinguished road
SoundGuy's Avatar
2007 AURA XE
The door is easy to take apart - just watch the screw in the door handle cover on the inside. Place a thin blade picket knife tip in the round part and pop it out. It doesn't come completely off, it's hinged.
Once you get it out per grump's instructions, it should be easy to see the problem. Could just be a bend rod.
Add to SoundGuy's Reputation
Rate the quality of this post and help SoundGuy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SoundGuy is offline   Reply With Quote
Old 04-16-2010, 03:08 PM   #4
Someclown
Someclown is on a distinguished road
Someclown's Avatar
2002 VUE 3.0L
Walboy, if you didn't already try this, remove the inner door handle via phillips screw and try pulling the rods manually (door handle rod and lock mechanism rod), they are held on the handle with plastic clips that lock on the plastic door handle itself.Maybe have someone use the outer door handle while someone uses the inner handle or inner rods.
Add to Someclown's Reputation
Rate the quality of this post and help Someclown reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Someclown is offline   Reply With Quote
Old 08-27-2010, 04:14 PM   #5
sarahsmom
sarahsmom is on a distinguished road
I just came from the body shop the guy there told me it would be a 2-3 day job. I can't have my car tied up that long came home thought about it for 5 minutes stuck a yard stick down into the window well, jiggled it for about 10-15 seconds and it popped right open, saving a ton of cash i assume
Add to sarahsmom's Reputation
Rate the quality of this post and help sarahsmom reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sarahsmom is offline   Reply With Quote
Old 08-27-2010, 04:36 PM   #6
Routs
Routs is on a distinguished road
Routs's Avatar
Awesome!
Sounds like the body shop that wanted to charge me 4 hours for two bodymen to replace my sunroof on one of my cars. 20 minutes and six screws and I had it done myself. I'm not real trusting of body shops anymore...
Add to Routs's Reputation
Rate the quality of this post and help Routs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Routs is offline   Reply With Quote
2006 ION Door problems duffbeer Ion General 21 03-17-2008 05:13 AM
door problems on 92 sl rgin2020 S-Series Tech 0 11-15-2005 08:40 PM
door problems rgin2020 S-Series General 0 11-01-2005 08:55 PM
door problems on 93 sl rgin2020 S-Series General 1 10-23-2005 09:07 PM
Vue Door Problems frankgstump Vue General 4 08-07-2003 04:12 PM
