Old 04-04-2010, 07:21 PM   #1
Mitchell93
Mitchell93 is on a distinguished road
Question 2002 Saturn SL1 lock horn cherp doesnt work
on my ex girlfriends car, her horn works fine, the panic alarm works from her key fob, but when she locks her doors with the fob, it locks, lights flash, and the horn chirps, but it suddenly stopped working... i want to impress her and her parents by fixing it for her, i don't know much about Saturns, never worked with one, or drove one for that madder... i looked at it last night, i checked her fuses and her relays, replacing them with the ones from my blazer, and it still didn't chirp, it makes the effort too, if it were the only thing the horn did, id say its the horn itself, but it put my hand over it, and its the same for the press down horn on her steering wheel, so the horn is fine i guess, but the lock chirp makes a ugg sound instead of a nice beep... i was hoping it could get some advice...
thanks
Mitchell
Add to Mitchell93's Reputation
Rate the quality of this post and help Mitchell93 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mitchell93 is offline   Reply With Quote
Old 04-04-2010, 09:46 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: 2002 Saturn SL1 lock horn cherp doesnt work
Try swapping the relay for the horn for another one that's identical in the underhood fuse box, then re-test. (Pretty sure your year has a horn relay under the hood, but there are some years that do not - it is integrated into the horn itself. If there are 2 wires going into the horn itself, you should have an external relay, if you have 3 wires going to the horn, the relay is internal.)
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 04-04-2010, 10:10 PM   #3
Mitchell93
Dizzy Re: 2002 Saturn SL1 lock horn cherp doesnt work
i did switch out the relays for one i know worked, it was black, and had 5 pins, same results, and it does have 2 wires going to the horn...
Old 04-04-2010, 10:35 PM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC1
The horn may be just getting weak if it barely makes a noise when getting momentary power for the chirp, but still does fine if the horn button is held. If that's the case, fortunately you can easily swap the horn out for an inexpensive new universal horn. Might wait to see if anyone else chimes in with ideas tho.
Someone doesnt want me to work on my car... collegephotoboi S-Series General 7 06-13-2008 11:17 AM
Gas Gauge doesnt work? XxRizzLexX S-Series Tech 4 01-29-2007 08:45 PM
DRL notification doesnt work SaturnManiac S-Series General 16 12-19-2006 09:00 PM
Horn dosen't work for 2002 SL2 latestgood S-Series Tech 1 06-10-2006 05:17 AM
Lighter doesnt work. agoldslsaturn S-Series Tech 19 05-20-2006 08:57 AM
