Old 03-31-2010, 09:57 PM   #1
hamz98
hamz98 is on a distinguished road
Default 6000rmp constant idle - so confused!!!
Hey guys,
first post, been creeping the board for a weeks now. I have a 1994 SL1 (Stick), that ran fine untill one morning. i woke up and it has been idling at 6000rpm since. I cant get it down. i cleaned the throttle body, its not stuck.
No error codes where present (but the coolent level did light up when i was checking the codes), not sure if this means anything since the oil and battery stayed lite during the whole process?
I cleaned the IACV and TPS. Is there anyway to test to see if these are possible issues? I powered up the car without starting it and the IACV went from about an inch to 4 inches in a matter of seconds. is this normal?
thanks!!!
Add to hamz98's Reputation
Rate the quality of this post and help hamz98 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hamz98 is offline   Reply With Quote
Old 03-31-2010, 10:28 PM   #2
bbarbulo
bbarbulo is on a distinguished road
Default Re: 6000rmp constant idle - so confused!!!
don't think this is an IACV problem, given that you're looking at 6K rpm. is the PCV valve hose from the valve cover to the intake manifold cracked? you have a massive vacuum leak somewhere probably. also check the gasket on the EGR valve as well. running the car without the EGR valve present (or gasket gone) would result in very very high rpm as well.
Add to bbarbulo's Reputation
Rate the quality of this post and help bbarbulo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bbarbulo is offline   Reply With Quote
Old 03-31-2010, 10:31 PM   #3
hamz98
hey thanks for the quick reply!
I checked the pcv valve it is fine and still sucks air.
is there anyway to test if it is the EGR Valve??
Old 04-01-2010, 09:07 AM   #4
dcc81187
dcc81187 is on a distinguished road
1996 SC1
get a can of throttle body cleaner and start spraying it around your intake manifold gasket, vacuum lines, egr, throttle body, and brake booster. if you have a leak the idle will change when the cleaner hits it.
Add to dcc81187's Reputation
Rate the quality of this post and help dcc81187 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcc81187 is offline   Reply With Quote
Old 04-01-2010, 09:29 AM   #5
hamz98
Thanks! I will try that and post the results.
I added some seafoam to see if that would do anything, and as the PVC was sucking up the liquid seaform the car started to idle at under 2k. do you guys think this symbolizes anything? or maybe it was just about to stall thus the low idle.
Old 04-01-2010, 09:38 AM   #6
MikeNW
MikeNW's Avatar
1997 SL
Letting it idle at 6,000 RPM can't be good.
To see it it's the PCV valve leaking, maybe remove its hose from the intake manifold and plug the opening there.
You can test EGR valve, use a piece of a soda can to block off the EGR opening, at the EGR gasket, then reassemble it.
08 Burgman 400
Add to MikeNW's Reputation
Old 04-01-2010, 09:58 AM   #7
+1 on a MASSIVE vacuum leak. But the weird thing is, the PCM should limit the engine speed to 4000-ish while the car is not moving.
Add to madpogue's Reputation
Old 04-01-2010, 10:09 AM   #8
Have you looked for a vacuum leak from the brake booster hose? This hose is the largest diameter vacuum line connecting the vacuum boost unit to the intake manifold.
Old 04-01-2010, 10:41 AM   #9
hamz98
no i havent, where is it located? I found the PCV near the oil cap. since the pvc still sucks air wouldnt that mean the vacuum system is fine-- is it a closed system or are all vacuums dependant?
ps. thanks for the all the help! greatly appreciated!
Old 04-01-2010, 11:00 AM   #10
Like the starter that's hidden on the back side of the engine, the vacuum boost hose for the brake canister is hidden unless you look for it between the firewall and engine intake manifold. Just locate the brake boost unit, the large black round unit behind the brake master cylinder, then locate the vacuum port near the bottom of the canister and attached is either the hose sticking out or a right angle elbow with the hose attached. Now trace that hose back to the intake manifold. Normally we all overlook this hose because its sturdy and is out of the way and doesn't interfere with engine access since the hose is the only attachment to the engine for vacuum.
When an engine revs so high at idle its usually a vacuum leak - the intake system is always creating a vacuum so any vacuum used will be attached as a hose fitting. A hose can crack, fall off, left off from maintenance and forgotten about until firing up the engine. If the throttle plate is nearly closed and the only place for air to enter, the higher rpm just means air is getting into the engine someplace else; loose throttle body attachment, loose intake manifold improperly mounted, intake manifold gasket leak from incorrect factory assembly ('01's), vacuum port leaking from hoses cracking/falling off/left off/whatever. A vacuum leak means using the old school technique of hands-on feeling for dry rotted hoses, hose cracks, loose fittings, etc..
Old 04-01-2010, 07:40 PM   #11
hamz98
solution found!!!
was just a vacuum unplugged
Old 04-02-2010, 10:35 AM   #12
MikeNW
MikeNW's Avatar
1997 SL
Success is a good thing.
Check the brake booster hose anyway. I just R&R mine. It wasn't easy but it can be done. I cut off the cracked end at the manifold and re-attached.
08 Burgman 400
Constant rev at 4???? HELP!!! Elementkng20 S-Series Tech 7 03-31-2008 03:44 PM
2001 sl1 constant idle at 4k jivxx S-Series Tech 4 03-10-2008 12:25 AM
Constant "ticking" noise; same at idle same at 5.5k RPM last year - THREAD FOLLOW UP SR20FL S-Series General 0 08-11-2007 06:28 PM
Idle problems I’m still confused! chilson2002 S-Series Tech 2 08-28-2006 12:41 PM
Constant "ticking" noise; same at idle same at 5.5k RPM SR20FL S-Series General 10 03-01-2006 07:41 AM
