Old 08-15-2015, 06:32 PM   #1
Couleesmi
Couleesmi is on a distinguished road
Dizzy Saturn ion won't "shift"
Just bought a 2004 Saturn ion quad coupe. It won't "shift" out of low gear. Starts and goes into drive and reverse fine, just won't "shift" up and can only go 20mph or so before it sounded like it was winding up and needed to "shift".. I ran an obd scan that gave me code P0700. Any ideas? Any fixes? Any help is appreciated thanks!
Add to Couleesmi's Reputation
Rate the quality of this post and help Couleesmi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Couleesmi is offline   Reply With Quote
Old 08-15-2015, 07:34 PM   #2
billysvue
Default Re: Saturn ion won't "shift"
You didn't go over 20 on your test drive?
TAke it back to the stealer to get your money back, if you can, if not, change the trans fluid- don't flush, then research TSB's and recalls for it and befriend a good mechanic.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 08-15-2015, 07:40 PM   #3
Couleesmi
The seller disclosed it, I got it reallly cheap, since I got it so cheap I'm alright with Putting some money into it. Just not super car smart and just wanted some opinions on what it could be before I take it to the shop Monday.
Old 08-15-2015, 07:42 PM   #4
Couleesmi
Will definitely research the recall though!
Old 08-16-2015, 12:15 AM   #5
Which xmission? AF23-5 speed or VT25-E cvt?
Old 08-16-2015, 12:19 AM   #6
billysvue
Uh oh dreaded CVT trans? car is going to the boneyard.
https://www.google.com/search?q=P070...700+saturn+ion
'17 Suby Forester
Old 08-16-2015, 07:04 AM   #7
Couleesmi
It is the cvt.
Old 08-16-2015, 09:07 AM   #8
Cvt's are relatively new for Saturns. Either try searching within this forum (Ions only) to find more Ion cvt issues or search Vues with their cvt problems. Vues only ran this cvt for two years, every one of them failed to be reliable. GM quietly discontinued cvt Vues (same 2.2L engine).
With no gears to shift like conventional automatic xmissions, cvt's use a steel belt with two variable pulleys (search snowmobile drive system) for unlimited gear ratios. It's already complicated to diagnose and troubleshoot and will cost money to find out if it's damaged beyond repair/rebuilding value or worth it to replace it with another cvt that may fail.
Old 08-16-2015, 09:07 AM   #9
billysvue
YOu bought a money pit to part out. Many before you have tried and failed( along with the factory).
NO amount of money will fix it.
R.I.P.
'17 Suby Forester
Old 08-16-2015, 03:47 PM   #10
Citation84
Citation84 has a spectacular aura aboutCitation84 has a spectacular aura about
Citation84's Avatar
2005 ION-1 Sedan
Couleesmi: check out the conversion thread in ION Tech. It will explain an option you can take to switch the CVT for an Aisin 5 speed auto that came in the sedans and is much more reliable.
Thread title: VTi To AF23 Transmission Swap
Add to Citation84's Reputation
Rate the quality of this post and help Citation84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Citation84 is offline   Reply With Quote
Old 08-17-2015, 11:53 AM   #11
kevin.st56
kevin.st56 has a spectacular aura aboutkevin.st56 has a spectacular aura about
kevin.st56's Avatar
2003 ION-2 Sedan
you would be better off swapping the trans for the 5 speed auto.
its definitely doable, as stated already, there is a thread on details of the swap.
youll be wasting money if spent on trying to fix the cvt.
03 ion-2 Sedan 5sp
94 Honda civic automatic "VTEC yo"
05 Santa Fe 2.7L (Fefe) {Wrecked}
"A problem clearly stated, is a problem half solved."
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kevin.st56 is offline   Reply With Quote
Old 08-17-2015, 09:28 PM   #12
VentureForth
VentureForth has a spectacular aura aboutVentureForth has a spectacular aura aboutVentureForth has a spectacular aura about
VentureForth's Avatar
2006 ION-3 Sedan
According to http://engine-codes.com/p0700_saturn.html, it's a faulty Transmission Control Module. It may be worth a $20-$40 gamble to buy a TCM from eBay. THEN, it MAY require reprogramming at a dealership (probably around $100-$150).
Ensure you have the EXACT same part number located under the bar code.
If this fixes it, I think it's a cheap repair and you got a great deal on a good car.
Add to VentureForth's Reputation
Rate the quality of this post and help VentureForth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VentureForth is offline   Reply With Quote
Old 08-17-2015, 09:53 PM   #13
billysvue
Yeah, good luck with that . You should tell the factory so they know how to fix it...
'17 Suby Forester
Old 08-18-2015, 09:37 AM   #14
Couleesmi
cvt's are relatively new for saturns. Either try searching within this forum (ions only) to find more ion cvt issues or search vues with their cvt problems. Vues only ran this cvt for two years, every one of them failed to be reliable. Gm quietly discontinued cvt vues (same 2.2l engine).
does it make any sort of difference if the engine light isnt lit?
Old 08-18-2015, 09:57 AM   #15
billysvue
just won't "shift" up and can only go 20mph or so before it sounded like it was winding up and needed to "shift".does it make any sort of difference if the engine light isnt lit?...
I doubt it if your still stuck to going 20 mph, or what is it's top speed?
'17 Suby Forester
Old 08-18-2015, 03:06 PM   #16
Couleesmi
That's just as fast as it would go, then it sounded as if it needed to "shift"
Reverse works fine, and I can drive just 20mph is about top speed at the moment :/
Old 08-18-2015, 04:10 PM   #17
billysvue
How much will JY's scrap it for in your area?
Of did you want to part it out or are you willing to research and follow through with a AF23 trans swap project as previously mentioned?
HOw rusted is it?
'17 Suby Forester
Old 08-18-2015, 05:09 PM   #18
Whether its cvt problems or anything else, there are many issues without a check engine light ever turning on. Nothing made is perfect and error codes do not cover every problem. If this were true then there would be no need for repair shops or dealers if everyone can use tools for home repairs. You many be trying to describe the same scenario of two Korean commercial pilots that crashed their airplane short of the runway two years ago in California; the second pilot made the mistake of attempting to switch from auto landing control to manual (actually controlling the landing) too late while the captain was too late in assessing the flight to take over, resulting in crashing the plane at the waters edge destroying the aircraft and killing some people. Automated flight can now operate almost without a pilot placing more training on pilots learning the computer systems that can take off, fly to a destination and land without a pilot ever flying the plane. This now allows inexperienced pilots to fly when flying skills (not computer skills) are still needed for every phase of flying. Younger pilots without any experience in every flying phase relying on computer controls lose the ability to actually fly to stay in the loop. The second pilot never landed at the airport and was never given training to allow the transition from simulated flying to actual flying. Usually two people are flying, one doing the actual flying while the co-pilot monitors everything else as a team concept. Unfortunately this team didn't communicate well together to avoid the crash. Not everything is set in stone. Error codes can not cover everything that can go wrong. If you expect error codes to pop up to tell you what's wrong, you may not be aware of a need to learn about car maintenance to become familiar with many things going wrong without an error code turning on the cel.
While not 100% familiar with cvt's but do understand how they work, no one has ever posted cvt error codes here while in the Vue forums with many cvt failures, no one posted error codes pointing directly to cvt failure. Any error codes that were generated were always indirect without providing the "the whatchmacallit snapped and is sounding like a water hammer" definition". Your description without any error code(s) may be describing cvt failure similar to Vue cvt's failing - error codes never pointing to cvt failure but the car drives wrong. Seat of the pants descriptions still goes a long way to figuring out many things when error codes don't appear.
Old 08-19-2015, 08:20 AM   #19
Couleesmi
HOw rusted is it?
No rust on it, it's actually a nice looking car
I had thought about scraping, but I don't know how much I'd get, I've only scraped once before and that was a long while ago. And parting out wouldn't be bad, but I'd almost like to get it fixed and just sell it.
I did find the same transmission for $294 on eBay free shipping and 6 mo warranty.. Or there is one that might work on Craigslist in my area..
Old 08-19-2015, 10:09 AM   #20
billysvue
YOu're rolling the dice...
'17 Suby Forester
Saturn vue 2008 with a "W" as a shift position in panel Dondeivi 2008 Vue 7 04-26-2015 01:08 PM
Saturn S Series Photo Contest!- April- Car "Selfies" and "Twin Cars"!!! blackbeard S-Series General 18 05-04-2014 10:06 AM
2000 Saturn SL manual shift is "loose" dfehr45 S-Series General 19 03-04-2013 07:06 PM
2002 Saturn L300 ECM Wiring "Clamp" or "Fastner" busboy99 L-Series Tech 1 09-06-2011 06:18 PM
Former Saturn Owner Struck by "Unresponsive" and "Inattentive" Treatment from Toyota Charlie General Saturn Discussion 20 02-25-2011 04:11 PM
