Old 03-29-2010, 02:20 PM   #1
hoffman_BMX89
hoffman_BMX89 is on a distinguished road
hoffman_BMX89's Avatar
Default help P0137, P0140
i have these codes keep popping up and its getting annoying what could be the cause
P0137- Rear Heated Oxygen Sensor Low Voltage
P0140-02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
1997 Sl2 447000km sold
1998 Sl2 278000km sold
2005 Vue 178000km current car
Add to hoffman_BMX89's Reputation
Rate the quality of this post and help hoffman_BMX89 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoffman_BMX89 is online now   Reply With Quote
Old 03-30-2010, 10:52 AM   #2
hoffman_BMX89
Default Re: help P0137, P0140
anyone????
Old 03-30-2010, 12:31 PM   #3
OldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud of
Crawl under and see if its connected. Those 2 codes would indicate its dead or disconnected.
Old 03-31-2010, 03:20 PM   #4
hoffman_BMX89
i checked the connector its fine i even unpluged it to check for corosion everything is ok and i traced all the wires they are all ok too. so could this be a dead sensor? the light is on and of it keeps comming and going it gets annoying.
Old 03-31-2010, 03:58 PM   #5
bluesl2
bluesl2 is a jewel in the roughbluesl2 is a jewel in the roughbluesl2 is a jewel in the rough
bluesl2's Avatar
It's probably dead then.
Add to bluesl2's Reputation
Old 03-31-2010, 05:41 PM   #6
Dead is a likely bet. When you replace it buy a direct fit sensor. Denso will work well and is not incredibly expensive at RockAuto, http://www.rockauto.com/
Before spending $$ check the fuse, its the EGR fuse and check that the brown ground wires on the back of the block are connected. They are right above the starter under the #4 intake runner. You can see them from above.
04 ION DTC code P0140 auger Ion Tech 9 02-26-2010 03:43 PM
1998 SL2 OBD code P0140 CraigT S-Series General 3 05-15-2008 09:09 AM
Threw a P0137 madpogue S-Series Tech 4 07-05-2006 11:38 AM
97 Saturn SL2 P0137 and P0141 dave2nh S-Series Tech 3 04-17-2006 02:18 PM
Rear O2 Sensor (P0137) Mario Miscellaneous Tech 5 07-17-2004 10:12 PM
