Old 03-24-2010, 11:02 AM   #1
Appalachian
Appalachian is on a distinguished road
Default Cranks, won't fire
I hate to start another one of these threads, but this one's got me stumped.
95 SL1.
couple months ago it started rough a few times in the cold. Seemed fine once it warmed up. Then a couple times it would fire and then quit in the cold. Then it wouldn't start at all.
I do have spark. I also *hear* a buzz when I put the key to RUN and I assume thats the fuel pump working. Also, I opened the air intake and sprayed some starter fluid in there, closed it, and then cranked it. Nothing. The starter is cranking about half speed now (and with starter fluid test) due to battery losing charge. Should I charge it up and try again?
Any help is appreciated. Commuting with the van is pricey.
Add to Appalachian's Reputation
Rate the quality of this post and help Appalachian reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Appalachian is offline   Reply With Quote
Old 03-24-2010, 11:44 AM   #2
Default Re: Cranks, won't fire
Welcome to Saturnfans!
1-Charge the battery.
2-Replace the engine coolant temperature sensor (ECTS) if the original one is still in there. They're plastic and crack, leading to continuous rich mixtures, hard starting and flooding. Buy the two-wire brass sensor from any auto store. Use the Forum Jump below to find the How-to library about it.
3-Remove the spark plugs and dry them if they're soaked with fuel. Blip the starter to blow out any raw fuel remaining.
Old 05-01-2010, 01:30 PM   #3
Appalachian
That did it. Thanks so much. Where do I send the check?
Old 05-01-2010, 02:06 PM   #4
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Always a pleasure to read fdryer's posts...
Add to BobbyP's Reputation
Old 05-01-2010, 11:43 PM   #5
Alas, I have no use for folding money or loose change!? No place to carry them under my wings and they're not very aerodynamic. I'd send you my duck bill (for feed) but I can't figure out how to hold a pencil with one of my wings.
95 sl2 cranks but won't start skii33 S-Series Tech 13 04-01-2010 04:43 PM
Cranks but won't start oden08 S-Series General 8 01-20-2010 10:05 PM
97 SL1 Needs 2 Cranks charliep S-Series Tech 4 10-04-2006 11:10 AM
Cranks but will not start..Help please loverboyred L-Series Tech 1 03-15-2006 04:11 PM
Cranks for a while before starting... TIMSPEED S-Series Tech 13 01-27-2005 09:52 AM
