#1 | ||||
![]() Join Date: Mar 2007
I'm about to do a tune up on my newly acquired '01 SL1 with 100k miles.
I was thinking of doing the following and wanted to know your recommendations on a few things. Spark plugs - NGK's? What part number? NGK 7755? What gap, .040? Wires - NAPA Premium Silicone is $20, NAPA Mileage Plus are $15. Both at 7mm, do you think it matters here? Transmission filter swap. Should I also drain the oil and put new in? Mercon 3 I assume? I have a "drill-pump" so I should be able to drain the trans fluid through the dipstick w/o dropping the pan, pretty convenient. Should I go that far though? Should I go ahead and do the fuel filter? I know they're expensive. Got a source for a cheaper one? I can get one through NAPA for $73. I've already replaced the old PS fluid w/ synthetic ATF. Coolant looks good so I'm not worried about flushing it. ECTS seems to work fine, I will keep a spare in the trunk. Belt appears to be okay. Thanks ... John '01 Saturn SL1 Auto '94 Camaro Z28 6sp, '96 Chevrolet C1500 5sp, '08 Kawasaki Vulcan 900 Custom, '01 KTM Duke 2
#2 | |||||
Doing a Trans fluid change; there is a drain plug on the bottom of the trans. Just drain as you would for an oil change, and then unscrew the ATF filter. I believe that the Auto trans take 6 or 7 quarts of ATF. You may want to double check that....the Manual transmissions take 2.6 Quarts of trans fluid. Fuel Filter is located on the inside of the driver's wheel well. I've heard it's a bit tough to get to, but changeable....you may see if there is anything in the how-to section. ... Bryan 94 SL2 215K Miles 97 SW2 246K Miles Garaged 94 SL2 HCE, "Pearl" Never Forget 94 SC1 340,501 Miles Original Engine/Auto Trans 02/97-10/08 Gone 03/12 92 SL1 05 VUE 91 SC
#3 | ||||
I get a discount through NAPA so I'd rather save the money than support a dealer who hires a-hole salesmen. I've been there for a few test drives and never had anything good to say upon leaving. They basically refused to find me an Ion 3 coupe 5sp also. Told me there was no market in them.
I never realized there was a drain plug on the bottom of the tranny. That'll make life pretty simple. Thanks for the tip! I know the fuel filter on my '96 is different from that on the '01, but it shouldn't be too tough. I will take your advice and read up on any tips a search reveals. Do you guys think it's worth it to pay the premium for a K&N air filter if I plan on keeping the car for 6 or 7 years? In that timespan I will have spend more money on paper filters and thrown them away than the cost of a K&N that can be cleaned and reused. Opinions? ... John '01 Saturn SL1 Auto '94 Camaro Z28 6sp, '96 Chevrolet C1500 5sp, '08 Kawasaki Vulcan 900 Custom, '01 KTM Duke 2
#4 | ||||
On the air filters; I have used WIX filters exclusively for the past 5 years with no issues. Sturdier made product than the FRAM parts.
I like the WIX filters because they are more heavy grade. They will run about $15 or so. Maybe a bit more. I've never been one for K & N filters. ... Bryan 94 SL2 215K Miles 97 SW2 246K Miles Garaged 94 SL2 HCE, "Pearl" Never Forget 94 SC1 340,501 Miles Original Engine/Auto Trans 02/97-10/08 Gone 03/12 92 SL1 05 VUE 91 SC
#5 | ||||
I was just inside Mitchel OnDemand and it says this '01 SL1 auto uses Dexron VI. Is this correct?
#6 | ||||
Also, I thought it was widely known the newer style fuel filters were really expensive??
I just found on AutoZone's website they list it as part number FF897 for $34.99. Everywhere else I've looked it's $75+ so why so cheap at AutoZone? Can that part be trusted? Anyone used it? It pics of it show it being identical to the one shown on NAPA's website. Rockauto.com doesn't list one but I sent an email and they replied telling me its PN 21009427 at $99.80 ... John '01 Saturn SL1 Auto '94 Camaro Z28 6sp, '96 Chevrolet C1500 5sp, '08 Kawasaki Vulcan 900 Custom, '01 KTM Duke 2
#7 | ||||
![]() Join Date: Dec 2007
2002 SL1
2002
Replace the ECTS you don't need a spare one in the trunk you need a new one in the cars cooling system and it's very easy to change and be sure it's good .
... 2013 Hyundai Sonata new 2003 Harley Davidson FXDWG wide glide. 2002 SL1 auto light blue has 207000 Km replaced engine. 2002 SL Manual Silver 254000KM replacing engine.
#8 | |||||
For an SL1, SOHC NGK BKR4ESA-11
You'll want Wix 33931 - recently renumberd to 33731 (NAPA FIL3931 is/was the same filter, dunno if NAPA renumbered or not). I think it was about $55 or so shipped from rockauto.com (get a 5% coupon code at retailmenot.com) edit: search for the Wix by part # at rockauto Dexron III is the original fill and Dex VI says it is backwards compatible on all automatic transmissions that called for Dex III. However, Dex VI is thinner at temp than Dex III. I went with a synthetic on my manual trans. I've read that you'll get 3.5~5 quarts out of draining the automatic transmission, out of a total of 6 or 7 qts in there. The How To Library has the exact amounts ... ...Wait, what, I actually won that eBay auction? Guess I now (12/2008) own a 1998 SL2, silver 5 spd :p And now (7/2010), a Craigslist 1997 SC2 5 spd
| Thread Tools | |
| Display Modes | |
| Complete tune-up: Recommendations? | Sevillian273 | S-Series Tech | 12 | 02-24-2010 12:31 PM |
| Dealer parts to buy --- Doing a tune up | Ultimate | S-Series Tech | 3 | 07-12-2008 03:17 PM |
| 2001 SL tune up | macdiesel | S-Series General | 0 | 03-18-2007 04:06 PM |
| Ordered parts for my tune-up today... | The Critic | S-Series Tech | 12 | 09-26-2006 01:54 AM |
| Recomended Engine "Tune-Up" Parts? | ProjectSW1 | Miscellaneous Tech | 8 | 06-09-2001 01:19 AM |
