Old 03-17-2010, 10:18 AM   #1
brucea52
brucea52 is on a distinguished road
Default 03 L300 headlight replacement
Hello everyone!
I just purchases a used '03 L300 and the only problem I have found (which I knew about) is that someone bumped the right front and kind of messed up the headlight assembly and the bracket that holds it to the body. I'm ready to order a new assemply and the bracket but I have 2 questions for the forum. How do you uninstall/install the bracket and currently the headlight is dim but the driver side is normal/bright. Where could the ground be that could be causing the lights to be dim? Thanks in advance for any help you can give.
Add to brucea52's Reputation
Rate the quality of this post and help brucea52 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brucea52 is offline   Reply With Quote
03 L300 headlight hognfrog L-Series Tech 1 08-07-2009 09:13 PM
95' SL2 Headlight Switch Replacement wlipford S-Series Tech 5 10-03-2006 09:25 AM
94 Pop-up headlight replacement rugersc2 S-Series General 0 08-15-2006 10:57 AM
Headlight Replacement ranger2k Vue General 3 03-25-2005 01:36 AM
Headlight Replacement on a 1993 SC-2 mpost S-Series Tech 6 12-31-2004 04:00 AM
