Old 07-17-2011, 04:59 PM   #61
2006 ion2
2007 ION-2 Sedan
Default Re: suggested PM/services for ions by year and engine
you may be able to get it back. all you can really try is: cleaning all the sensors and TB, only run top tier gas and run more fuel system cleaner through it, make sure your air cleaner is clean. also, if your plugs looked that bad, you may have gunked up your o2 sensors and cat, not to mention the damage that could have been done to your ignition system.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
2006 ion2 is offline
Old 07-20-2011, 10:00 PM   #62
idriveasaturn
idriveasaturn is on a distinguished road
2006 ION-3 Sedan
Ok, I have more fuel system cleaner, and will run higher grade fuel at the next fill up.
I've never had to buy/or use sensor cleaner before. Any specific brand that you would recommend? Recommended TB cleaner? Also, is there a specific o2 sensor cleaner? or, will MAF sensor cleaner work for that as well? Would you recommend a direct fit Cat converter replacement?
I hate to throw so many questions at you, but I want to get this right. Your knowledge on these cars is invaluable to me, and I highly appreciate having a sort of go-to guy for repair tips. So thank you.
Add to idriveasaturn's Reputation
Rate the quality of this post and help idriveasaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
idriveasaturn is offline
Old 07-21-2011, 01:34 AM   #63
2006 ion2
2007 ION-2 Sedan
just use MAF sensor cleaner (or even just "sensor cleaner"). just use a rag and rubbing alcohol or the sensor cleaner to clean the TB. no brand is really that different from another. there is only one way to replace the cat, which is to buy the downpipe it's attached to, so you're stuck with stock unless you want to change your whole exhaust.
2007 Saturn Ion 2
Old 07-21-2011, 07:41 AM   #64
dave380
dave380 is on a distinguished road
I noticed in the first post you also mentioned to rub, not spray. I cleaned my TB a few weeks ago and sprayed to clean inside it (with the TB removed from the engine and sensors removed from the TB). I hadn't seen this thread when I did, so now I'm curious, why rub and not spray? Since I did spray, is there anything I should be looking for to go wrong?
Add to dave380's Reputation
Rate the quality of this post and help dave380 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dave380 is offline
Old 07-21-2011, 10:06 AM   #65
2006 ion2
2007 ION-2 Sedan
You may remove any lubricant in the pivots, damage the sensors if not removed, or on throttle by wire ions you can break down the seal protecting the electronics. It's just much safer. Now, if you don't have any luck cleaning out the sensor holes (use a pipe cleaner), or need to clean out the cavity the sensor lives in, careful spraying may be in order, but be careful.
Old 12-17-2011, 05:44 PM   #66
2006 ion2
2007 ION-2 Sedan
*bump*
2007 Saturn Ion 2
Old 01-25-2012, 10:02 PM   #67
Zosozeppelin
Zosozeppelin is on a distinguished road
Zosozeppelin's Avatar
2006 ION-3 Quad Coupe
This needs to be a sticky in the Tech/General forums. It would save a lot of time and questions
Elizabeth
'06 Level 3 Quad Coupe. 140K as of 5-3-15. Traded for 2015 Chevy SS. Gone but not forgotten.
Current: 2017 2LT/RS 50th Anniversary Camaro
Add to Zosozeppelin's Reputation
Rate the quality of this post and help Zosozeppelin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Zosozeppelin is offline
Old 01-25-2012, 10:11 PM   #68
2006 ion2
2007 ION-2 Sedan
I've asked charlie, and he wouldn't do stickies, which is stupid, but it's the way it is
2007 Saturn Ion 2
Old 01-25-2012, 11:18 PM   #69
Zosozeppelin
S-Series has stickies...Newer ones at that.
Elizabeth
Old 01-26-2012, 12:14 AM   #70
Zosozeppelin
And while I'm thinking about it, do we have a timing belt or chain? And when should this be changed, 100k?
Elizabeth
Old 01-26-2012, 07:24 AM   #71
2006 ion2
2007 ION-2 Sedan
I've asked, if you want to spend time asking, go for it. Chain, and it's not a scheduled maintenance item. That being said, I'm probably going to look into getting mine changed around 150k (about half the expected life of the engine), if I still have the car. Timing chains don't seem too failure prone in ecotecs since they fixed the oiler issues.
2007 Saturn Ion 2
Old 01-26-2012, 11:10 AM   #72
Zosozeppelin
So it's not really something I should worry about then. That's good to know.
Elizabeth
Old 01-26-2012, 12:06 PM   #73
2006 ion2
2007 ION-2 Sedan
not for quite a while if you do change it.
you might want to see if you can use your "girlish charm" on charlie and get him to sticky some more popular topics (I'm assuming you're a woman, since your signature says elizbeth), it would eliminate a lot of questions.
2007 Saturn Ion 2
Old 01-26-2012, 04:43 PM   #74
Zosozeppelin
Haha, I am, but I don't know if that'd work or not
Elizabeth
Old 01-27-2012, 12:15 AM   #75
Zosozeppelin
Sent him a PM. Hopefully we get this stickied.
Elizabeth
Old 01-31-2012, 08:49 PM   #76
snakes
snakes has a spectacular aura aboutsnakes has a spectacular aura about
snakes's Avatar
2005 ION-1 Sedan
Thumbs Up Re: suggested PM/services for ions by year and engine
I spoke to two service depts 1 Saturn (no longer exists) and another chevy GM which still has old timer saturn techs working there and they have never heard of/had a chain go, snap or jump in an Ion according to there records. However I am sure it has happended in the past at other places. I may do mine at at 125 or 150K myself.
Add to snakes's Reputation
Rate the quality of this post and help snakes reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
snakes is offline
Old 08-24-2012, 11:26 AM   #77
Zosozeppelin
Ok. So it's getting close to that time that I need to change out my spark plugs (I'm at 93,500 right now). I know to go with iridium over platinum, but what brand should I go with? I was thinking either http://www.autozone.com/autozone/par...er=940700_0_0_ , this one, http://www.autozone.com/autozone/par...er=940700_0_0_ or should I just go with the good ol' AC Delco plugs?
Elizabeth
Old 08-24-2012, 12:12 PM   #78
DigitalSaturns
DigitalSaturns is on a distinguished road
Seeing we know the AC/Delco's are 100% correct for the car. Seeing we know they last about 100,000 miles. Seeing we know they perform quite well. Why would we go and change that?
Add to DigitalSaturns's Reputation
Rate the quality of this post and help DigitalSaturns reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DigitalSaturns is offline
Old 08-24-2012, 02:42 PM   #79
jason_
jason_ is on a distinguished road
2003 ION-2 Quad Coupe
Thank you all for the great information! I was about to put Bosch plugs in my Saturn and my Ford truck this week until I read about these issues for both vehicles on forums.
Time to return them and get something else
Add to jason_'s Reputation
Rate the quality of this post and help jason_ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jason_ is offline
Old 08-24-2012, 09:35 PM   #80
Zosozeppelin
Never heard of anything bad about the NKG plugs, either. A good bit of the S-Series owners use them. Either contribute and tell my why they wont be a good choice, or don't comment and leave it up to 2006 ion2 to explain it to me.
Elizabeth
How can I tell what year my engine is? joe1stsaturn S-Series Tech 0 01-22-2010 10:28 PM
Engine year lszack S-Series Tech 2 02-28-2009 08:17 AM
What year is engine? marchand6@veriz S-Series Tech 15 12-30-2008 07:08 PM
Last year of 1.9L Engine wscreate S-Series Tech 10 05-27-2007 08:07 PM
engine year. . . .?? 1995SC2 S-Series Tech 0 07-08-2003 01:00 AM
