Old 12-17-2010, 02:29 PM   #41
2006 ion2
2007 ION-2 Sedan
Default Re: suggested PM/services for ions by year and engine
Replace your brake fluid. I'm 99% sure it's covered on here
Add to 2006 ion2's Reputation
2006 ion2 is offline
Old 12-17-2010, 02:34 PM   #42
munky000527
munky000527 is on a distinguished road
Yeah but I meant mechanical parts that I should purchase. Like brake lines or something.
I'm doing the brake fluid flush when I change out the rotors and pads.
Should I try to stick with OEM parts?
Add to munky000527's Reputation
Rate the quality of this post and help munky000527 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
munky000527 is offline
Old 12-17-2010, 05:04 PM   #43
2006 ion2
2007 ION-2 Sedan
Nothing else is scheduled to be changed. I would
Old 12-18-2010, 12:02 PM   #44
munky000527
You would....
lol
Old 12-18-2010, 04:57 PM   #45
munky000527
What would you do? What parts should I be buying for the rear drum brakes?
Old 12-18-2010, 11:33 PM   #46
munky000527
I am an idiot. I didn't reread my post before I read yours and I thought that you forgot to finish your post. Sorry for all the posts. :/
I'm still curious about the drum brakes though. I've never serviced drum brakes before and I don't know what parts to replace.
Old 12-19-2010, 10:38 AM   #47
bmxracerchamp12
bmxracerchamp12 is on a distinguished road
bmxracerchamp12's Avatar
2005 ION-3 Sedan
it depends. i replaced my shoes with the mid grade autozone ones 2 months ago. before they were squealing upon braking. now its doing the same thing. the shoes have chunks missing out of the sides. so im going to replace the drum and shoes again to see if this helps any.
2004.5 2500HD LT
-Tow Pig
2005 Turbo Ion 3 Sedan
-Lots of mods (parting out)
2004 Honda CBR 1000RR
-Summer toy
1995 Honda CX
-DD
Add to bmxracerchamp12's Reputation
Rate the quality of this post and help bmxracerchamp12 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bmxracerchamp12 is offline
Old 12-19-2010, 07:02 PM   #48
2006 ion2
2007 ION-2 Sedan
^^ what he said. you have to look at them, and see what's going on with the current ones before you can tell what to replace if you replace just the pads, you need to deglaze the drums.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 01-23-2011, 04:50 PM   #49
munky000527
What about battery replacement? Best kind and type for 03-04 and 05 and up, etc.
Old 01-23-2011, 05:50 PM   #50
2006 ion2
2007 ION-2 Sedan
the one from a dealer or parts store with a vent
Old 01-25-2011, 03:45 AM   #51
munky000527
No specific brand to look for? I've seen you post about Optima batteries before.
Old 01-25-2011, 01:05 PM   #52
2006 ion2
2007 ION-2 Sedan
if you'd read my posts on optimas, you would recall they were saying to buy any brand BUT optima, since they don't make the special vented type battery our cars require. all I can say for sure is use common sense when you buy one. buy a brand you're comfortable with or the one with the most warranty available in your area. ac delco batteries have proven to overall be quite reliable from the factory.
another note is, when looking for dealer sourced parts, chevy dealerships have taken over responsibility for parts.
2007 Saturn Ion 2
Old 03-30-2011, 10:38 AM   #53
lgodave
lgodave will become famous soon enough
2003 ION-3 Sedan
RE: Battery
When I replaced my factory ACDelco a couple years ago I found a vented model at a regional chain for $60-$70 while the ACDelco and limited other models seemed to be well over $100.
My point is as 2006 ion2 mentioned get the vented battery, it can be found for the same price as a non-vented.
RE: TOP TIER Detergent Gasoline
Do check/recheck the posted link occasionally for new retailers offering the fuel. ExxonMobil has joined the standard in the last year after dragging it's feet ever since it's introduction in 2004.
Hoping to perform a cleaning of the MAF and TB on my 2003 very soon. I'll try and take some pics. Probably still can't post pics to my Gallery (has anyone been able to?) but I'll try and link them anyway. I'm assuming the MAF Sensor Cleaner is safe for the Sensors I need to clean on the TB or do I need a third can of cleaner?
Add to lgodave's Reputation
Rate the quality of this post and help lgodave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lgodave is offline
Old 03-30-2011, 12:54 PM   #54
2006 ion2
2007 ION-2 Sedan
umm, good luck cleaning the MAF sensor on an 03. also, MAF sensor cleaner is safe for all sensors.
2007 Saturn Ion 2
Old 03-30-2011, 06:57 PM   #55
lgodave
2003 ION-3 Sedan
Didn't find a MAF sensor ('05-'07 IONs have 'em?) like the one I found on an '05 Equinox but I did clean all the sensors found with the MAF cleaner. TB didn't seem as dirty as I'd have expected... cleaned that and reassembled everything. With luck it'll fire up without issues after I clean up myself.
lgodave is offline
Old 04-03-2011, 11:15 PM   #56
lgodave
2003 ION-3 Sedan
yes, if you have the stock iridium plugs (not the platinum ones) and your engine runs like it should, your plugs should last 100K miles. I believe the earlier ions came with platinum plugs, which do not last as long. check your manuals to confirm. inspections for gap and completeness of the electrodes should be done at 50K, 75K, and 100K, also, if they smell like gas or oil, you have a problem. on 2.2s and 2.4s, .043 is the gap, 2.0s are .040. do not put bosch plugs in these engines, iridium plugs come pre gapped and are NOT gap adjustable, you will damage the plug if you try this.
Swapped out my 2003's Platinums (41-981) for Iridium plugs (41-105) today. After almost 92000 miles they seemed "normal" but I'm not entirely sure how "complete" the electrode really is, since I never checked them earlier at 50k/75k for comparison.
Seen several pics of other ION plugs that show electrodes that have eroded significantly more... (Were a pair were significantly more eroded then the other two) mine were very consistent between cylinders and near original spec. gap.
RE: "pre-gap"
My AC Delcos mention to gap to spec. but I did read warnings elsewhere that I must not "touch" the very hard, yet brittle iridium electrode or the insulator. Otherwise it does adjust like a traditional plug. You just have to be more careful with the electrode.
lgodave is offline
Old 05-10-2011, 02:30 PM   #57
2006 ion2
2007 ION-2 Sedan
bumpus
2007 Saturn Ion 2
Old 07-17-2011, 02:21 AM   #58
idriveasaturn
idriveasaturn is on a distinguished road
2006 ION-3 Sedan
Question about the Throttle body. Is there an affect on gas mileage if the Throttle body is dirty? If so, any idea how much so?
The reason why I ask is because when I first started reading this thread, I saw that Bosch spark plugs are bad mojo in the Ecotec. Silly me had those spark plugs, got terrible gas mileage (12-16 on average).Made the switch to AC Delco Iridiums and didn't it didn't look like there was any damage. The bosch plugs were a little burnt when I pulled them out, kind of like they were in there for 20K, after only about 9 thousand. The problem is that after switching, I haven't seen any improvement in gas mileage... if it helps I used techron fuel system cleaner the last time I changed the oil, which was less than 1k miles ago.
I don't think there is any significant damage, because I'm posting 2 weeks after the change and the car still functions normally minus the bad gas mileage
any thoughts?...
Add to idriveasaturn's Reputation
Rate the quality of this post and help idriveasaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
idriveasaturn is offline
Old 07-17-2011, 08:10 AM   #59
2006 ion2
2007 ION-2 Sedan
You might never get the mileage back. The throttlebody being dirty only effects how long it will last, and in extreme cases, how elk the car idles and the plate moves. The bosch plugs damage the ignition system and the engine, good luck.
Old 07-17-2011, 01:33 PM   #60
idriveasaturn
2006 ION-3 Sedan
so, did I ruin the gas mileage indefinitely? or can you think of any way I can fix it?
Also I remember that you posted about not gapping Iridium plugs. I didn't know this at the time I installed them on this car, so I used a gap tool to check them, and all four gaps were too narrow. I moved them to .043 with the tool. Could that be the reason for bad mileage?
I'm really hoping I didn't ruin a good engine...
and thanks for your help.
How can I tell what year my engine is? joe1stsaturn S-Series Tech 0 01-22-2010 09:28 PM
Engine year lszack S-Series Tech 2 02-28-2009 07:17 AM
What year is engine? marchand6@veriz S-Series Tech 15 12-30-2008 06:08 PM
Last year of 1.9L Engine wscreate S-Series Tech 10 05-27-2007 07:07 PM
engine year. . . .?? 1995SC2 S-Series Tech 0 07-08-2003 12:00 AM
