Go Back   SaturnFans.com Forums > Models > Saturn Relay > Relay Tech
Old 03-16-2010, 09:30 AM   #1
torgy
torgy is on a distinguished road
Default Egr
My check engine light came on in my 05 saturn relay. I did a diagnostic which said my EGR pressure valve was messed up. I ordered the new valve and it will cost $250. Is there any way to fix this without it costing me an arm and a leg? I read on another post taking it out and using carb cleaner on it? Does it really work?
Add to torgy's Reputation
Rate the quality of this post and help torgy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
torgy is offline   Reply With Quote
Old 03-16-2010, 11:06 AM   #2
Default Re: Egr
Welcome to Saturnfans!
There are two types of egr valves; the older vacuum operated ones resembling a mushroom and the latest type, electrically operated with electronic feedback shaped like a cylinder. Only two issues affect these egr valves; carbon encrusted shaft preventing smooth opening/closing or the feedback circuit was damaged from mishandling or solvent entering past the shaft and shorting the circuit. Search for threads or the How-to library on cleaning the valve, making a temporary blocking gasket as a secondary test to cleaning to verify a faulty egr valve, and Google for how it works.
